Microsoft Surface Pro 7 NEED BIOS. HELP!
  • hans153
    • Aug 2025
    • 5
    Any suggestions?
    • Sami Saeed Alariqi
      • Sep 2025
      • Yemen
      #462
      I need to unlock bios password for surface pro 7 1866
        • 22159
        Post your backup and laptop serial number and we might be able to help.
        Quote of the day: When in rome do as the romans do.
        • crowntoy99
          • Oct 2012
          • 267
          • india
          #464
          windows log an off plz fix
          sn 080654502853
          jalama_icl_mb b\dv:2.0b
          • hoaca388
            Badcaps
            • Jan 2022
            • 12423
            #465
            sn 080654502853
            Fixed
              • Sep 2025
              • Yemen
              #466
              surface pro 7 sn 010577101353
              • Handy Planet
                • Nov 2024
                • Austria
                #467
                Hello could anyone Help me pls ?
                Windows Logo shows for 5 sec and goes off
                Surface 7 Pro
                SN: 059678704853
                BIOS Dump attached
                • Siyahcay11
                  • Sep 2025
                  i have a Surface 7 Pro shows Win Logo for few sec than off..
                  the Battery is full 8.4v measured
                  i tried it connecting Mainboard with Power Supply Standby about 10mAh then when i press Power Button it goes up tp 130mAh and than off
                  The only strange thing is that when I plug in the charging cable and check with a thermal camera, I can see the charging IC BQ25713 lighting up when I press the power button. Windows Logo goes off but the IC still lights up under the Thermal Cam. I'm not sure if this happens just because the charger is connected, or if it's normal.
                  maybe is my BIOS broken can anyone check it pls ? i uploaded it
                  SN: 059678704853
                  Thanks in advance guys
                    SMDFlea commented
                    Editing a comment
                    Thread merged.
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 12423
                  #469
                  Surface 7 Pro
                  SN: 059678704853
                  BIOS Dump attached
                  Try
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 12423
                    #470
                    SN: 059678704853
                    Try
                    • Handy Planet
                      • Nov 2024
                      • Austria
                      #471
                      Originally posted by hoaca388
                      Try
                      thanks but still same... tried both files
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12423
                        #472
                        Since I don't know where to download bios for Surface line, there's nothing more I can do.
                        • Handy Planet
                          • Nov 2024
                          • Austria
                          #473
                          hi i found a new BIOS but need to clean ME.. could u please help?
                          SN: 037778302353
                          if its work i will let u know.
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 12423
                            #474
                            SN: 037778302353
                            Here
                            • Handy Planet
                              • Nov 2024
                              • Austria
                              #475
                              Here
                              THANK U!!!
                              now device working booting but touch not working.
                              can u copy the touch section from old bios to the new bios dump ?
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 12423
                                #476
                                THANK U!!!
                                MS Surface không có màn hình cảm ứng sau khi vệ sinh ME Firmware **FIX**
                                Tải xuống trình điều khiển và chương trình cơ sở cho Surface
                                https://support.microsoft.com/en-gb/...pdate-manually
                                Nếu bạn cần trích xuất chương trình cơ sở từ trình cài đặt MSI
                                Trình điều khiển cần được trích xuất bằng công cụ dòng lệnh MSIEXEC
                                Khởi chạy CMD với quyền nâng cao
                                cd đến thư mục mà bạn đã tải xuống gói trình điều khiển MSI
                                Nhập msiexec /a SurfacePro6_Win10_16299_1900307_*.msi TARGETDIR=C:\SurfacePro6Drivers /qn (* cần
                                được thay thế bằng số chính xác có trong tên tệp và bạn có thể sử dụng
                                thư mục đích của riêng mình)
                                Thư mục đích sẽ được tạo tự động nếu chưa tồn tại Trình
                                điều khiển sẽ được trích xuất và lưu tại vị trí C:\SurfacePro6Drivers\SurfaceUpdate\Drivers
                                ------------------------------------------------------------------------------------------------- Hình
                                ảnh phục hồi Surface https://support.microsoft.com/en-us/...recovery-image
                                Bộ công cụ chẩn đoán Surface https://support.microsoft.com/en-us/...0-1982eb16f7b5
                                Chỉnh sửa lần cuối bởi SMDFlea ; 06-10-2023, 04:15 AM .
                                • gabi200
                                  • Nov 2013
                                  • 20
                                  Hello
                                  the patient is a surface pro 7 that starts with the logo for a few seconds then shuts down
                                  sn:01900204153
                                  could anyone help me please?
                                  Thx
                                  • virusok
                                    • Dec 2023
                                    • Россия
                                    #478
                                    Hello everyone 🤗, Can anyone help clean the me on surface pro 7+ 1960, it starts,but shows only logo, consumption 1A, and CPU heating, SN 001140932853
                                    • flusher
                                      • Oct 2015
                                      • 58
                                      #479
                                      Surface Pro 7+ model 1960
                                      039121513653
                                      Shows logo, bootloops after 5-10 seconds
                                      Doesn't boot into OS
                                      Doesn't go into UEFI
                                      All power rails voltages are present, no shorts on main rails.
                                      Tried clearing NVRAM - did not work
                                      Attaching both dumps
                                      Please help with fixing dump or at least tell me what I can try to do myself
                                      • luvbe3
                                        Chicken
                                        • Oct 2017
                                        • 154
                                        • JAPAN
                                        #480
                                        my bios sometimes runs fine. but after a while the screen goes dark. is it a bios error?
                                        SN: 003335610753
