Microsoft Surface Pro 7 NEED BIOS. HELP!
  • mops
    • Mar 2023
    • 5
    • nz
    #421
    Hello.
    I also need a BIOS cleaned/rebuilt for Surface 7 pro i5/8/256 serial# 067245401453
    This device is flashing windows logo for about 2 seconds then shuts off.
    I have tried the guide for cleaning BIOS, but I ran into issues.
    1. Using CMSE 13.3r7, decomposed BIOS does not have "ME Region.bin" file. There's file "ME Sub Partition.bin" (3.3MB). I assume this is the same, but differently named.
    2. I downloaded surface pro 7 firmware and drivers from MS and there's file there "SurfaceME_13.0.2436.2.bin" (4MB). I assume this is the 'clean' ME file. it is NOT the same version as the file in original bios. I was not able to find the same version.
    3. When I swap the original file with the MS one and try to load CSME project I get "error 209: Failed to get image metadata sub partition"
    4. So I tried decomposing, swapping the file and building bios (without exiting fit.exe), and it built a bios file. I compared original with this one using hex editor and I can see that there's block that is different, so I assume the swap was succesfull.
    5. resoldered the bios. Now the machine stays on windows logo for about 3~4 seconds, then shuts down. cant get into the bios.
    Attached bios is the original as it came from faulty machine.
    • volinakis
      • Jan 2021
      • 3229
      • N/A
      #422
      Originally posted by mops
      Hello.
      are you sure this is original bios? Because it has other serial. (071473602453)
      please support this forum
      • mops
        • Mar 2023
        • 5
        • nz
        #423
        This is the original bios. I must read the serial number of a different tablet frame. I have several of them (sp7's, also sp5's and sp4's)
        • volinakis
          • Jan 2021
          • 3229
          • N/A
          #424
          try this one
          • Behindikus
            • Apr 2024
            • 5
            Originally posted by Behindikus
            Hi!
            I inherited a Surface 7 Pro (1866) from my Father in law and it's bricked.
            Keeps rebooting / flashing Logo.
            The Serial is 028134302953
            If its possible we need a fresh bios without Passwords.
            Thank's a lot!
            I tried some BIOS files from this Forum but i am still at the flashing Windows Logo. At First IT was visible for about a second, now i See the Logo for about 3 Seconds. Seems Like Something changed.
            But i still need Help
            • minhdigital
              • Nov 2022
              • 778
              • Vietnam
              #426
              Send to you, try
              • khayal9
                • Feb 2025
                • 7
                • azerbayjan
                #427
                I found a bios from the forum, the computer turned on before but the touch screen was not working and the SSD was not visible, I tried different bios, all of them failed, now even if I write the bios that worked before, it stays at the logo, I tried with new EPROMs, still failed, the Windows logo appears for 3-4 seconds.
                Can someone tell me how the image comes to the motherboard without the bios chip? I think the problem is not the bios, there is something different
                Please help
                • Behindikus
                  • Apr 2024
                  • 5
                  Originally posted by minhdigital
                  Send to you, try
                  Thanks a lot, but its still the same behavior. I think i have to order a new bios Chip.. my ch340 recognized it as a JQ Chip not as a JW. Something seems to be wrong...
                  • khayal9
                    • Feb 2025
                    • 7
                    • azerbayjan
                    #429
                    Microsoft Surface Pro 7 BIOS 1866 128GB 021775602353 anakart modeli JALAMA_ICL_MB DV:2 0B
                    SLP_S4# no signal 0v please help where is the problem?
                    • peste
                      peste commented
                      Editing a comment
                      here only "bios requests"...if you have another problem, move the discussion to the main forum...
                  • vetal3vetal4687
                    • Jun 2025
                    • Ukraine
                    #430
                    Good day! Please help me remove the password in the bios dump.
                    Surface Pro 7 (1866) i5 / 8 / 128
                    Serial number 024762704553
                    • volinakis
                      • Jan 2021
                      • 3229
                      • N/A
                      #431
                      try
                      • vetal3vetal4687
                        • Jun 2025
                        • Ukraine
                        #432
                        try
                        Thank you! All settings are saved, no password.
                        • volinakis
                          • Jan 2021
                          • 3229
                          • N/A
                          #433
                          you are welcome
                          • mops
                            • Mar 2023
                            • 5
                            • nz
                            #434
                            try this one
                            Tried.... same behaviour - windows logo for about 3~4 seconds, then switches off :/
                            • farouk_1994
                              • Mar 2021
                              • 405
                              • algeria
                              • electronics and computer sciences
                              #435
                              Hello i have this surface pro 7 1906 bios locked
                              SN: 017178922453
                              • shiyab
                                • Sep 2023
                                • 2826
                                • india
                                #436
                                SN: 017178922453
                                hi try
                                • farouk_1994
                                  • Mar 2021
                                  • 405
                                  • algeria
                                  #437
                                  Thank you bro it's work like sharm
                                  • AE Soft
                                    • Mar 2024
                                    • 10
                                    • MALAYSIA
                                    #438
                                    Hello i have this surface pro 7 1866 bios locked
                                    SN: 030327601453
                                    • hoaca388
                                      Badcaps
                                      • Jan 2022
                                      • 12687
                                      #439
                                      SN: 030327601453
                                      Unlocked
                                      If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our bios, boardview & schematic archive.
                                      Subscribe to support us. It only takes 1 minute:
                                      https://www.badcaps.net/settings/subscriptions
                                      • AE Soft
                                        • Mar 2024
                                        • 10
                                        • MALAYSIA
                                        #440
                                        Originally posted by hoaca388
                                        Unlocked
