asus N551JM BIOS NEED PLS
  • ismaelstepheno
    • Jun 2020
    • 226
    • UE
    hi please i need bios asus G551J
    mainboard asus N551JM REV 2.0
    when i plug it its turn on alone the fan working slowley aften 2 munites the fan speed up without image
    i attached my backup
    thanks
  • peste
    • Dec 2016
    • 12238
    • ROMANIA
    Re: asus N551JM BIOS NEED PLS
    Originally posted by ismaelstepheno
    hi please i need bios asus g551j
    mainboard asus n551jm rev 2.0
    thanks
    try..
    • ismaelstepheno
      • Jun 2020
      • 226
      • UE
      thank you not working still the same
        • 20299
        Try this one .
        • ismaelstepheno
          • Jun 2020
          • 226
          • UE
          thanks for you help but still the same when plugged the power button lights up, black screen the fan starts slowly then sounds very loud
            • 20299
            Post clear pictures of the green/white stickers on the motherboard.
            • ismaelstepheno
              • Jun 2020
              • 226
              • UE
              Ok
              • ismaelstepheno
                • Jun 2020
                • 226
                • UE
                Stickers in the case
                model:g551j
                f2n0cj00322806b
                g551jm-dm180h
                cn:8651
                • peste
                  • Dec 2016
                  • 12238
                  • ROMANIA
                  model:g551j
                  f2n0cj00322806b
                  g551jm-dm180h
                  cn:8651
                  try post # 3
                  https://www.badcaps.net/forum/showthread.php?t=55751
                  • ismaelstepheno
                    • Jun 2020
                    • 226
                    • UE
                    thanks this is the first one i tried but the same problem
                      • 20299
                      Your serial matches the one in your bios backup. Try this new bios,its a known working one from a different site,so if it isn`t working for you the problem is somewhere else.
                      • peste
                        • Dec 2016
                        • 12238
                        • ROMANIA
                        maybe not the bios is the problem..you checked the voltages ?? Turn on the laptop without hdd, wifi, dvd keyboard, etc..see what happens ..
                        • ismaelstepheno
                          • Jun 2020
                          • 226
                          • UE
                          ok thanks yes i disconnect dvd keyboard....etc but still the same, i think its a problem of the board as you said i weill check the voltages
                          • Toxic9996
                            • May 2022
                            • 32
                            • Romania
                            Hello, I also have a corrupted bios, can you help me with it? thank you
                            Asus G551JM-CN113D
                            ECN0CJ035112499
                            MB:N551JM REV.2.0
                            • razor_amd
                              by razor_amd
                              12-15-2020, 07:07 PM
                            • throwaway327
                              by throwaway327
                              Model No: RC72LA
                              Serial No: SBNVKD001014459
                              06-18-2025, 05:52 PM
                            • jbonavita
                              by jbonavita
                              Some issues
                              Things I tried
                              04-29-2025, 09:38 PM
                            • lrouw84
                              by lrouw84
                              Hi there,
                              01-28-2023, 01:31 PM
                            • DynaxSC
                              by DynaxSC
                              06-14-2024, 03:49 PM
