asus N551JM BIOS NEED PLS
  • ismaelstepheno
    • Jun 2020
    • 226
    • UE
    hi please i need bios asus G551J
    mainboard asus N551JM REV 2.0
    when i plug it its turn on alone the fan working slowley aften 2 munites the fan speed up without image
    i attached my backup
    thanks
  • peste
    • 13451
    • ROMANIA
    Re: asus N551JM BIOS NEED PLS
    Originally posted by ismaelstepheno
    hi please i need bios asus g551j
    mainboard asus n551jm rev 2.0
    thanks
    try..
    • ismaelstepheno
      • Jun 2020
      • 226
      • UE
      thank you not working still the same
        • 21692
        Try this one .
        • ismaelstepheno
          • Jun 2020
          • 226
          • UE
          thanks for you help but still the same when plugged the power button lights up, black screen the fan starts slowly then sounds very loud
            • 21692
            Post clear pictures of the green/white stickers on the motherboard.
            • ismaelstepheno
              • Jun 2020
              • 226
              • UE
              Ok
              • ismaelstepheno
                • Jun 2020
                • 226
                • UE
                Stickers in the case
                model:g551j
                f2n0cj00322806b
                g551jm-dm180h
                cn:8651
                • peste
                  • 13451
                  • ROMANIA
                  model:g551j
                  f2n0cj00322806b
                  g551jm-dm180h
                  cn:8651
                  try post # 3
                  https://www.badcaps.net/forum/showthread.php?t=55751
                  • ismaelstepheno
                    • Jun 2020
                    • 226
                    • UE
                    thanks this is the first one i tried but the same problem
                      • 21692
                      Your serial matches the one in your bios backup. Try this new bios,its a known working one from a different site,so if it isn`t working for you the problem is somewhere else.
                      • peste
                        • 13451
                        • ROMANIA
                        maybe not the bios is the problem..you checked the voltages ?? Turn on the laptop without hdd, wifi, dvd keyboard, etc..see what happens ..
                        • ismaelstepheno
                          • Jun 2020
                          • 226
                          • UE
                          ok thanks yes i disconnect dvd keyboard....etc but still the same, i think its a problem of the board as you said i weill check the voltages
                          • Toxic9996
                            • May 2022
                            • 32
                            Hello, I also have a corrupted bios, can you help me with it? thank you
                            Asus G551JM-CN113D
                            ECN0CJ035112499
                            MB:N551JM REV.2.0
                            • razor_amd
                              by razor_amd
                              12-15-2020, 07:07 PM
                            • grimacelord
                              by grimacelord
                              07-10-2025, 02:52 PM
                            • jbonavita
                              by jbonavita
                              Some issues
                              Things I tried
                              04-29-2025, 09:38 PM
                            • throwaway327
                              by throwaway327
                              Model No: RC72LA
                              Serial No: SBNVKD001014459
                              06-18-2025, 05:52 PM
                            • lrouw84
                              Asus vivobook s510ua bios changed to x510un
                              by lrouw84
                              Hi there,
                              I know there is somebody who can tell me what is happening with my laptop. For start, it is an asus vivobook s510ua with an asustek x510ua motherboard with an intel i5 7200u cpu and 16gb ram.. i have a screenshot from speccy before strange things started.. as you can see the laptop type and bios version x510ua.302.I don’t manually update the bios because i don’t like to having a bricked bios, i know what troubles that gives..
                              I did a fresh win 11 install, and after the automatic updates, windows rebooted and automatically started asus ez flash.....
                              01-28-2023, 01:31 PM
