T470 bios needed
  • Jetro007
    replied
    Re: T470 bios needed
    Yeah, i get mixed reactions from different usb ports. Maybe the chip is drawing to much power. got a 90% read one time.
    The laptop doesn't realy turn on.
    The keyboard illumination and power button briefly turn on, then everything shuts down.
    I'll try to desolder it tomorrow.
    If i get succesfull reads, schould i flash the bios posted in the beginning of this thread?
    Thx for the advice so far
  • Vesko356
    replied
    Originally posted by Jetro007
    I'm not sure my solder skills are up to it.
    isn't the fact it starts reading a sign the spi communication is ok?
    Can the reason be it hangs, it is corrupt?
    No, if it was "corrupt", the laptop wouldn't turn on.
    It's just the crappy chinese clip doesn't make a good contact at some of the chip legs, or/and the cable has become unsoldered on one of the pins (the cable is also thin and crappy), that's why.
    Edit; You have to read the chip, then erase it, then program it with the patched dump, then erase it again and program it again with the original dump. I just don't see how it's going to happen with that crappy clip...
  • Jetro007
    replied
  • Vesko356
    replied
    it was sitting next to the cmos battery, smiling at me
  • Jetro007
    replied
    Yep, I bet that's exactly why.
    Maybe it's time to put in my signature - "Do not touch the 25Q80JV chip"
  • Vesko356
    replied
    They probably assume it will be 8MB. Also sometimes it has the same package as the BIOS chip (SOP8/SOIC8).
    Maybe it's time to put in my signature - "Do not touch the 25Q80xxxx chip"
    Edit:
    desolder?
    Absolutely.
  • Jetro007
    replied
    25Q80JV is the most famous spi chip around here.
    I don't understand why rookies likes him the most, probably because of the number 80 on the marking.
    Edit:
    Yes it is, that's the right one. Are you using a clip to read the chip?
    Yep, the full aliexpress package.
    Freezes sometimes in the beginning, sometimes halfway.
    desolder?
  • hardware1
    replied
  • Vesko356
    replied
    "25Q80JV" size is (1MB/8Mbit/1024KB) and it's a Wrong chip, search for another chip on the Motherboard (Both sides).
    Edit:
    I found an other one ; 25Q128FVSQ
    seems to be the right size, but the read freezes (neo 2.2.0.10)
  • Jetro007
    replied
    Current programmer: CH341 Black
    SPI ID: EF4018
    Currently selected: W25Q128FV [3.3V] 128 Mbits, 16 Mbytes
    i'm reading on board, the chip gets detected
  • hardware1
    replied
    I got my t470 20HE corrupted in a bad flash (no boot).
    The winbond is a 25Q80JV 8Mb chip, but all I see here is 16Mb files for this bios.
    I used Neo programmer and a ch341 to read the bios.
    Am i missing something?
    is there a way to extract a bin file from a bios update?
  • Vesko356
    replied
    101.4 KB is far away from a good read. Try again be more careful.
    Use NeoProgrammer V2.2.0.10
  • Jetro007
    replied
  • hussaka
    replied
    Thank you
  • andresi
    replied
    hello,
    i try to unlock bios with patcher, but now i cant enter bios. its just blank screen when i enter bios. can you help fix my bios ?
  • ravenmx
    replied
    Originally posted by mazoot
    try and give reply
    how i can patch it sr?
  • ravenmx
    replied
    try and give reply
    power on but only stay on entering setup ..... and blocked on lenovo logo.. sr
  • mazoot
    replied
    Originally posted by ravenmx
    hello , please help this bk have computrace, any can helpme to remove please. thanks you
    try and give reply
  • ravenmx
    replied
  • x16
    replied
    I have a T470. The Bios is corrupted. It starts, i see logo and then it show the normal screen that there is no system on hard drive.
    But when i press F1 to go to bios, the screen is black. I cant go to bios.
    Hope you guys can help.
  • tlindi
    Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
    by tlindi
    Sublect line continuation: ... Jaguar IDS PC aka Panasonic
    Ack
    Ack
    01-30-2025, 04:26 AM
  • macabook
    by macabook
    🧩 Initial Issue
    07-24-2025, 02:17 PM
  • lofton
    Lenovo t470 20jn-sv2vnoe PF1Q63B0 Bios/EC needed
    by lofton
    Hello, I was flashing the bios but now the machine does not come, the battery indicator turns orange when charge is plugged in. As soon as it plugged by charger or battery the power button and escape blinks once then fade out Sometime it blinks 3 timess . With the back case off i can see the fan spins a little then top, but once i press the button it spins a little then stop and repeat for a while until stops. I have attached the bios dump. I had read the chip next to the cmos battery (25q80jvsiq) then i realize that it wasn't the bios. as the bios is next the memory slot. By doing that could...
    04-17-2024, 09:27 AM
  • DynaxSC
    by DynaxSC
    11-17-2023, 10:56 AM
  • pirati
    by pirati
    10-27-2025, 04:20 PM
