T470 bios needed
  • bob1101
    replied
    Hello can I get Help with clean me late display
    this is my old bios
    SN: PF0VJALW
    Thank you.
  • princeas50
    replied
    Originally posted by hoaca388
    T470 Laptop (ThinkPad) - Type 20JM
    THANK YOU hoaca388 works perect
  • hoaca388
    replied
    Originally posted by princeas50
    S/N: PF-11WAKX
  • princeas50
    replied
    HELP CLEAN ME LATE DISPLAY
    LENOVO T470
    ATTACHED BIOS
    S/N: PF-11WAKX
  • princeas50
    replied
    LENOVO T470
    ATTACHED BIOS
    commented on 's reply
    Great, happy to help :-)
  • Andreasbest
    replied
    Originally posted by SMDFlea
    Unpatched bios, updated to 1.79 + clean Corp LP C 11.8.94.4494 ME firmware
    At first it didn't work either BUT i was very curious and i decide to remove everything from the board, first i removed both RAM sticks, laptop powered on with beeping, then i insterted again the RAM and everything worked
    Thank you SMDFlea for once again!
    replied
    Originally posted by Andreasbest
    Hello.
    I came to a very weird situation with a T470.
    Laptop worked great but locked, backed up the BIOS, successfully verified it, patched it with Autopatcher, boot successfully and completed the DXE procedure, flashed back the old unpatched bios and now only the green led of power button turns on and nothing else.
    Tried CMOS reset but no luck. No physical damage around BIOS chip, i was very careful and checked MB on microscope.
    Any ideas?
    Both bios attached
    S/N: PF-10A0VQ
    Thank you in advance!
  • Andreasbest
    replied
    Hello.
    Any ideas?
    Both bios attached
    S/N: PF-10A0VQ
  • faisalhabib
    replied
    About T470 bios needed REPAIR THIS BIOS PLEASE SIR
    NO POWER PROBLEM
    LENOVO T470 MB MODEL : NM-A931
    SN: PF-12ANPY
  • bhatt
    replied
    Re: T470 bios needed
    bro do u have t470 -nm-a931 u15 bios bin file (c-port )
  • zmezm1995`
    replied
    Originally posted by peste
    S/N ???
    pf-0u7leu
  • peste
    replied
    Originally posted by zmezm1995`
    need bios lenovo t470
    bord number nm-a931
    proplem no screen
    and this my dump
    S/N ???
  • zmezm1995`
    replied
    bord number nm-a931
    proplem no screen
    and this my dump
  • mferna14
    replied
    Dear hoaca388 you are always on the mark. Thank you brother, all worked fine. Even ​Markus1741 thanks for your bin file, I did not try it but surely yours too might work well. Thanks for all the help.
  • Markus1741
    replied
    Originally posted by mferna14
    Dear Friends., working on a Lenovo T470. All required voltages are present & the require Amps (.95mili amps), Also goes through the start process, turns off & then turns on but no display or any beeps. I think the BIOS Bin files are corrupted & has to be re-build. Can some pls. re-build the Bin File, Original Bin uploaded. Thanks in advance.
    Lenovo T470 Model Type: 20HE-S2K100 Serial #: PF-0SLUUS​
    Hello you can try that too ... Good luck
  • hoaca388
    replied
    T470 Laptop (ThinkPad) - Type 20HE
  • mferna14
    replied
  • hoaca388
    replied
    Originally posted by Nino RIcca
    Hello.
    This laptop starts normally, the power button lights green, and the fan turns on. A few seconds later the power button light goes out and the fan stops spinning, the laptop never boots and the screen stays black. The laptop was working untill a windows BIOS update failed, I'm looking for a clean BIOS bin file or a clean up of the corrupted BIOS dump. Any help would be greatly appreciated Thank You.
    Lenovo Thinkpad T470
    Type: 20JN-S1470A
    S/N: PF-0VP714
    T470 Laptop (ThinkPad) - Type 20JN
    Thread merged.
  • tlindi
    Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
    by tlindi
    Sublect line continuation: ... Jaguar IDS PC aka Panasonic
    Ack
    Ack
    01-30-2025, 04:26 AM
  • macabook
    by macabook
    🧩 Initial Issue
    07-24-2025, 02:17 PM
  • lofton
    Lenovo t470 20jn-sv2vnoe PF1Q63B0 Bios/EC needed
    by lofton
    Hello, I was flashing the bios but now the machine does not come, the battery indicator turns orange when charge is plugged in. As soon as it plugged by charger or battery the power button and escape blinks once then fade out Sometime it blinks 3 timess . With the back case off i can see the fan spins a little then top, but once i press the button it spins a little then stop and repeat for a while until stops. I have attached the bios dump. I had read the chip next to the cmos battery (25q80jvsiq) then i realize that it wasn't the bios. as the bios is next the memory slot. By doing that could...
    04-17-2024, 09:27 AM
  • DynaxSC
    by DynaxSC
    11-17-2023, 10:56 AM
  • pirati
    by pirati
    10-27-2025, 04:20 PM
