T470 bios needed
  • Nino RIcca
    • May 2024
    • canada
    #101
    Hello.
    This laptop starts normally, the power button lights green, and the fan turns on. A few seconds later the power button light goes out and the fan stops spinning, the laptop never boots and the screen stays black. The laptop was working untill a windows BIOS update failed, I'm looking for a clean BIOS bin file or a clean up of the corrupted BIOS dump. Any help would be greatly appreciated Thank You.
    Lenovo Thinkpad T470
    Type: 20JN-S1470A
    S/N: PF-0VP714​
      SMDFlea commented
      Editing a comment
      Thread merged.
  • hoaca388
    Badcaps
    • Jan 2022
    • 12433
    #102
    Originally posted by Nino RIcca
    Hello.
    Type: 20JN-S1470A
    S/N: PF-0VP714
    T470 Laptop (ThinkPad) - Type 20JN
    • mferna14
      • Jun 2018
      • 1050
      Dear Friends., working on a Lenovo T470. All required voltages are present & the require Amps (.95mili amps), Also goes through the start process, turns off & then turns on but no display or any beeps. I think the BIOS Bin files are corrupted & has to be re-build. Can some pls. re-build the Bin File, Original Bin uploaded. Thanks in advance.
      Lenovo T470 Model Type: 20HE-S2K100 Serial #: PF-0SLUUS​
      • hoaca388
        Badcaps
        • Jan 2022
        • 12433
        #104
        T470 Laptop (ThinkPad) - Type 20HE
        • Markus1741
          • Sep 2020
          • 981
          • N/A
          #105
          Hello you can try that too ... Good luck
          • mferna14
            • Jun 2018
            • 1050
            Dear hoaca388 you are always on the mark. Thank you brother, all worked fine. Even ​Markus1741 thanks for your bin file, I did not try it but surely yours too might work well. Thanks for all the help.
            • zmezm1995`
              • Nov 2020
              • 99
              • iraq
              #107
              need bios lenovo t470
              bord number nm-a931
              proplem no screen
              and this my dump
              • peste
                • 13899
                • ROMANIA
                #108
                bord number nm-a931
                proplem no screen
                and this my dump
                S/N ???
                • zmezm1995`
                  • Nov 2020
                  • 99
                  • iraq
                  #109
                  Originally posted by peste
                  S/N ???
                  pf-0u7leu
                  • bhatt
                    • Dec 2015
                    • 95
                    • pakistan
                    #110
                    Originally posted by hoaca388
                    Re: T470 bios needed
                    bro do u have t470 -nm-a931 u15 bios bin file (c-port )
                    • faisalhabib
                      • Apr 2017
                      • 29
                      • Bangladesh
                      #111
                      About T470 bios needed REPAIR THIS BIOS PLEASE SIR
                      NO POWER PROBLEM
                      LENOVO T470 MB MODEL : NM-A931
                      SN: PF-12ANPY
                      • Andreasbest
                        • Aug 2014
                        • 1218
                        • Hellas ( Greece )
                        #112
                        Hello.
                        I came to a very weird situation with a T470.
                        Laptop worked great but locked, backed up the BIOS, successfully verified it, patched it with Autopatcher, boot successfully and completed the DXE procedure, flashed back the old unpatched bios and now only the green led of power button turns on and nothing else.
                        Tried CMOS reset but no luck. No physical damage around BIOS chip, i was very careful and checked MB on microscope.
                        Any ideas?
                        Both bios attached
                        S/N: PF-10A0VQ
                        Thank you in advance!
                          • 22241
                          Originally posted by Andreasbest
                          Hello.
                          Any ideas?
                          Both bios attached
                          S/N: PF-10A0VQ
                          Unpatched bios, updated to 1.79 + clean Corp LP C 11.8.94.4494 ME firmware
                          • Andreasbest
                            • Aug 2014
                            • 1218
                            • Hellas ( Greece )
                            #114
                            At first it didn't work either BUT i was very curious and i decide to remove everything from the board, first i removed both RAM sticks, laptop powered on with beeping, then i insterted again the RAM and everything worked
                            Thank you SMDFlea for once again!
                              SMDFlea commented
                              Editing a comment
                              Great, happy to help :-)
                          • princeas50
                            • Feb 2021
                            • 28
                            • Ghana
                            #115
                            HELP CLEAN ME LATE DISPLAY
                            LENOVO T470
                            ATTACHED BIOS
                            • princeas50
                              • Feb 2021
                              • 28
                              • Ghana
                              #116
                              LENOVO T470
                              ATTACHED BIOS
                              S/N: PF-11WAKX
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 12433
                                #117
                                S/N: PF-11WAKX
                                T470 Laptop (ThinkPad) - Type 20JM
                                • princeas50
                                  • Feb 2021
                                  • 28
                                  • Ghana
                                  #118
                                  THANK YOU hoaca388 works perect
                                  • bob1101
                                    • Sep 2017
                                    • 5
                                    • lebanon
                                    #119
                                    Hello can I get Help with clean me late display
                                    this is my old bios
                                    SN: PF0VJALW
                                    Thank you.
                                    • bob1101
                                      • Sep 2017
                                      • 5
                                      • lebanon
                                      #120
                                      this is my old bios
                                      SN: PF0VJALW
                                      Thank you.
                                      Type:20HE
                                      • tlindi
                                        Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
                                        by tlindi
                                        Sublect line continuation: ... Jaguar IDS PC aka Panasonic
                                        >Read BIOS guides, methods, resources and tools
                                        Ack
                                        >Try the method at BIOS guides, methods, resources and tools before requesting help
                                        Ack
                                        >Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
                                        python ./main.py "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.BIN" --output-dir "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.txt"
                                        01-30-2025, 04:26 AM
                                      • macabook
                                        by macabook
                                        🧩 Initial Issue
                                        07-24-2025, 02:17 PM
                                      • lofton
                                        Lenovo t470 20jn-sv2vnoe PF1Q63B0 Bios/EC needed
                                        by lofton
                                        Hello, I was flashing the bios but now the machine does not come, the battery indicator turns orange when charge is plugged in. As soon as it plugged by charger or battery the power button and escape blinks once then fade out Sometime it blinks 3 timess . With the back case off i can see the fan spins a little then top, but once i press the button it spins a little then stop and repeat for a while until stops. I have attached the bios dump. I had read the chip next to the cmos battery (25q80jvsiq) then i realize that it wasn't the bios. as the bios is next the memory slot. By doing that could...
                                        04-17-2024, 09:27 AM
                                      • DynaxSC
                                        by DynaxSC
                                        11-17-2023, 10:56 AM
                                      • pirati
                                        by pirati
                                        10-27-2025, 04:20 PM
