hi, I'm looking for the bios for a hp 350 g2 L8B07ES, serial number 5CG6113FHM, Winbond chip 25Q128fv, it turns on and loads the system but with black screen, also tried external monitor
hp 350 G2 bios
Re: hp 350 G2 bios
this is the old dump, but the ch341a says: chip main memory with the contents are in desagreementAttached FilesComment
Re: hp 350 G2 bios
Attached FilesDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
Re: hp 350 G2 bios
does not work, turns on, turns the fan mo does not see the ram and the screen is black, with the other bios it did everything except that there was no video signal output, I state that there is no display, I tried only with monitor externalComment
Re: hp 350 G2 bios
Try AsProgrammer software,it works better with winbond chips.The CH341A software will often say its verified even when it hasnt written anything.If the virgin bios posted by @peste isn`t working then the problem is somewhere else.
https://github.com/nofeletru/UsbAsp-...mmer_1.4.1.zipComment
Re: hp 350 G2 bios
Re: hp 350 G2 bios
When you use a virgin bios it will have no DMI info,serial number etc. To fix that use HP DMI tools ,BCU (bios config utility) and/or wndmifit/nbdmifit .Comment
Re: hp 350 G2 bios
try..Attached FilesDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Re: hp 350 G2 bios
replaced the bios chip programmed with the virgin file 08007, it turns on recognizes the ram in fact it turns off after a second that I pressed the on / off button, but nothing is seen on the external screen, I remind you that the internal one is not there because it had the connector burned and I had to unsolder it, usually by connecting the external monitor you can see it even without the operating system installed, but in this case no, what can this depend on some hardware problem or some keyboard setting?Comment
Re: hp 350 G2 bios
try theseComment
Re: hp 350 G2 bios
The same 512Kb .Just different chip.
Datasheets:
Try this EC,extracted from the 08007 virgin bios posted by @peste .Attached FilesLast edited by SMDFlea; 09-03-2020, 06:35 AM.Comment
Re: hp 350 G2 bios
help pro hp 350g2 on screen but not receiving hddAttached FilesComment
by Vesko356First of all thanks to all of our members who have posted previously all methods posted here.
Operating system and OS version.If...-
Channel: BIOS Requests ONLY!
by TechMark1I was searching the BIOS on this Alienware Area-51m laptop to try to find the info for a customer, but could not find it. I discovered that info is encrypted and hidden only Dell can pull it up. So then I thought, there may be someone who needs a working BIOS dump bin file for that laptop. So, I am uploading it to help others who may need this to unbrick the laptop or fix their Area-51m. The BIOS chip was a Winbond 25Q80DVSIG. If this helps someone out there, then my labor was not wasted.
I just zipped it so I could attach it....
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
by lucaszmn
Summary of BIOS Whitelist Removal Problem
Problem:
Initial Findings:- My current BIOS version is N1KET58W (1.45).
- I have a CH341A programmer and have successfully created two full backups of my BIOS.
- I have the ability to use command-line tools on a Linux machine.
- I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
- I concluded that the
08-12-2025, 03:01 PM - Loading...
