hp 350 G2 bios
  • poweron
    • May 2019
    • 365
    • italy
    hp 350 G2 bios
    hi, I'm looking for the bios for a hp 350 g2 L8B07ES, serial number 5CG6113FHM, Winbond chip 25Q128fv, it turns on and loads the system but with black screen, also tried external monitor
  • lapfix
    • Mar 2020
    • 2719
    • my workshop
    Re: hp 350 G2 bios
    Post your old dump
    • poweron
      • May 2019
      • 365
      • italy
      Re: hp 350 G2 bios
      this is the old dump, but the ch341a says: chip main memory with the contents are in desagreement
      • peste
        • Dec 2016
        • 12729
        • ROMANIA
        Re: hp 350 G2 bios
        bios extracted from the HP site update ... this model has two versions of the bios, yours is 08007 ..
        • poweron
          • May 2019
          • 365
          • italy
          Re: hp 350 G2 bios
          does not work, turns on, turns the fan mo does not see the ram and the screen is black, with the other bios it did everything except that there was no video signal output, I state that there is no display, I tried only with monitor external
            • 20781
            Re: hp 350 G2 bios
            Try AsProgrammer software,it works better with winbond chips.The CH341A software will often say its verified even when it hasnt written anything.If the virgin bios posted by @peste isn`t working then the problem is somewhere else.
            https://github.com/nofeletru/UsbAsp-...mmer_1.4.1.zip
            • poweron
              • May 2019
              • 365
              • italy
              Re: hp 350 G2 bios
              ok i try, main board SNOWI20-6050A2677101-MB-A01
              • poweron
                • May 2019
                • 365
                • italy
                Re: hp 350 G2 bios
                is there any operation to do after loading the new bios?
                  • 20781
                  Re: hp 350 G2 bios
                  When you use a virgin bios it will have no DMI info,serial number etc. To fix that use HP DMI tools ,BCU (bios config utility) and/or wndmifit/nbdmifit .
                  • poweron
                    • May 2019
                    • 365
                    • italy
                    Re: hp 350 G2 bios
                    yes ok, but the display should turn on
                    • peste
                      • Dec 2016
                      • 12729
                      • ROMANIA
                      Re: hp 350 G2 bios
                      try..
                        • 20781
                        Re: hp 350 G2 bios
                        The bios backup is corrupt.Maybe the bios chip is dying. Try another bios chip,and the virgin bios.If it doesn`t boot with a new chip and the virgin bios its not a bios problem.
                        • poweron
                          • May 2019
                          • 365
                          • italy
                          Re: hp 350 G2 bios
                          ok ,thank you
                          • poweron
                            • May 2019
                            • 365
                            • italy
                            Re: hp 350 G2 bios
                            for the moment I suspend waiting for the new chip
                            • poweron
                              • May 2019
                              • 365
                              • italy
                              Re: hp 350 G2 bios
                              replaced the bios chip programmed with the virgin file 08007, it turns on recognizes the ram in fact it turns off after a second that I pressed the on / off button, but nothing is seen on the external screen, I remind you that the internal one is not there because it had the connector burned and I had to unsolder it, usually by connecting the external monitor you can see it even without the operating system installed, but in this case no, what can this depend on some hardware problem or some keyboard setting?
                              • fddizon
                                • Sep 2011
                                • 555
                                • Philippines
                                Re: hp 350 G2 bios
                                try these
                                • poweron
                                  • May 2019
                                  • 365
                                  • italy
                                  Re: hp 350 G2 bios
                                  in mi case the ec-flash it's 25L512E , it's the same?
                                    • 20781
                                    Re: hp 350 G2 bios
                                    The same 512Kb .Just different chip.
                                    Datasheets:
                                    Try this EC,extracted from the 08007 virgin bios posted by @peste .
                                    • poweron
                                      • May 2019
                                      • 365
                                      • italy
                                      Re: hp 350 G2 bios
                                      Datasheets:
                                      this is identical to the file that is present on the chip, after reading it I have compared them and they are identical
                                      • duc.hiep.94@gmail.com
                                        hiep tran the
                                        • Apr 2022
                                        • 9
                                        • việt nam
                                        Re: hp 350 G2 bios
                                        help pro hp 350g2 on screen but not receiving hdd
