HP Probook 11 X360 G1 EE bios dump
  • qayyum786
    • Aug 2018
    • 1959
    • INDIA
    Re: HP Probook 11 X360 G1 EE bios dump
    Originally posted by elbtonet
    hi friend i have a bios dump with a problem
    full fan spin no screen motherboard is
    g1 13 amd x360 18740-1 0ga05
    here you go
    • hoaca388
      Badcaps
      • Jan 2022
      • 12421
      Hi friend I have A bios dump with a problem
      Full fan spin no screen Motherboard is
      HP ENVY X360 - 13-ar0019nn
      Serial number : 8CG0252SFD ????????
      • volinakis
        • Jan 2021
        • 2875
        • N/A
        If I have a HP ProBook x360 11 G1 with no pass and save bios with no pass then I put a password and save bios with password would it be of help? Someone with more experience can analyze them and see where is diference. At a glance it seems to be in DevExp1 region/IVBP.
        • hoaca388
          Badcaps
          • Jan 2022
          • 12421
          Why you don't post both files here ?
          • volinakis
            • Jan 2021
            • 2875
            • N/A
            just asked if would be of help. if so please tell us wht has to be modified, many thanks. please edit SN with yours.
            • hoaca388
              Badcaps
              • Jan 2022
              • 12421
              #26
              The difference between the 2 files is in DevExp1_region. I think with this model just flashing the virgin bios file from HP should be able to remove the password. I attach virgin bios file from HP, can you try?
              • volinakis
                • Jan 2021
                • 2875
                • N/A
                #27
                sorry, I had laptop for a brief period to replace thermal paste and reinstall OS. But ppl with bios locked can do it.
                • Jaffar Ali
                  • Oct 2022
                  • 9
                  • Pakistan
                  #28
                  Hi there
                  I have HP 11 X360 G1 with bios password!
                  HP Unlocker not working for this device.
                  • RethoricalCheese
                    • Mar 2013
                    • 1519
                    • Estonia
                    #29
                    Use hp config utility to read config, flash clean dump to eeprom, use hp config utility to write back config.
                    • Thangviet
                      • Apr 2023
                      • 9
                      I have ProBook x360 11 G1 EE with BIOS Administrator password.
                      Please explain the steps I need to do to give you my BIOS backup.
                      Thanks!
                      • peste
                        • Dec 2016
                        • 13785
                        • ROMANIA
                        #31
                        Thanks!
                        use rcunlocker..you need a SPI programmer...look at an example how to use it..
                        https://www.youtube.com/watch?v=DWWigscuQDY
                        • Thangviet
                          • Apr 2023
                          • 9
                          HP ProBook x360 11 G1 EE
                          I have HP ProBook x360 11 G1 EE with Administrator password.
                          How do I provide a dump of my BIOS?
                          Thanks!
                          • Vesko356
                            VIP Moderator
                            • Aug 2018
                            • 4386
                            • Bulgaria 🇧🇬
                            #33
                            Re: HP ProBook x360 11 G1 EE
                            Thanks!
                            BIOS guides, methods, resources and tools
                            Become a Badcaps supporter
                            Thanks to all supporters.
                            • RethoricalCheese
                              • Mar 2013
                              • 1519
                              • Estonia
                              #34
                              Probook 11 g1 is a special snowflake.
                              You need to use HP biosconfigutility to read bios config. Then use spi programmer to dump that bios. Clean TXE region. Program that new bios. Then use biosconfigutility to write back config.
                              • Thangviet
                                • Apr 2023
                                • 9
                                Thanks peste & RethoricalCheese!
                                • Thangviet
                                  • Apr 2023
                                  • 9
                                  Thank you Vesko356 as well!
                                  @RethoricalCheese, when you say "read bios config", what's the file format?
                                  I saved my config as "config.txt" but my spi programmer (ezp2010 programmer v3) gives me error "file is too long".
                                  • RethoricalCheese
                                    • Mar 2013
                                    • 1519
                                    • Estonia
                                    #37
                                    You got something mixed up.
                                    Use biosconfigutility in windows, save config as .txt file.
                                    Then shut down, open up the laptop, use spi programmer to read bios dump (.bin file).
                                    Clean TXE region (or find a clean one from the internet.)
                                    Write clean .bin file to laptop. Put it back together.
                                    Boot into windows and use biosconfigutility to write back the config (.txt) file you created in step 1.
                                    • Thangviet
                                      • Apr 2023
                                      • 9
                                      Thanks! I'll try that and let you know my result.
                                      • Thangviet
                                        • Apr 2023
                                        • 9
                                        I believe I have done this?
                                        I flashed my laptop (ProBook x360 11 G1 EE) with the latest BIOS using HP's .exe file and I still get the admin password after rebooting and trying to access BIOS to make changes.
                                        It looks like I will need to clean the TXE region and re-flash.
                                        Will try to use the clean TXE region file provided (in previous post somewhere) and test and post my result.
                                        • Thangviet
                                          • Apr 2023
                                          • 9
                                          I think I managed to get a dump of my BIOS however, it is a little smaller than the "clean txe" bios posted here in previous post.
                                          Attached is my BIOS dump, does it have a password?
                                          thanks
                                          • Ahari
                                            by Ahari
                                            I...
                                            08-13-2025, 06:12 AM
                                            HP ProBook ProBook x360 11 G1 EE Notebook PC Notebook Specification for Upgrade or Repair
                                            This specification for the HP ProBook ProBook x360 11 G1 EE Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ProBook x360 11 G1 EE Notebook PC boardview and ProBook x360 11 G1 EE Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                            09-06-2024, 06:40 AM
                                          • mkdj
                                            by mkdj
                                            Dear all,
                                            10-19-2025, 04:41 AM
                                          • Habble7
                                            by Habble7
                                            Suspected Cause:
                                            Troubleshooting Attempts:
                                            05-22-2025, 07:28 AM
                                            HP ProBook x360 Pro x360 Fortis 11 inch G9 Notebook PC Hybrid (2-in-1) Specification for Upgrade or Repair
                                            This specification for the HP ProBook x360 Pro x360 Fortis 11 inch G9 Notebook PC Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pro x360 Fortis 11 inch G9 Notebook PC boardview and Pro x360 Fortis 11 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum....
                                            09-07-2024, 05:50 AM
