Surface 4 Pro BIOS locked
  • rioreno
    • Feb 2009
    • 540
    • Indonesia
    #41
    Re: microsoft surface pro 4
    Originally posted by alihomee
    anyone can help
    try this...
    goodluck
    • yakumot
      • Aug 2016
      • Ialoveni
      #42
      Re: Microsoft Surface Pro 4 clean bios backup
      Hi guys.
      I need a bios dump for Surface Pro 4 1796
      128Gb
      Procesor intel core M3
      Please help me!!!!
      thanks in advance
      • sapkad
        • Feb 2019
        • 6
        • Lietuva
        #43
        Hi
        can you help to remove password from bios Surface Pro model 1796
        • alihomee
          • Dec 2012
          • 1596
          • malaysia
          #44
          need to remove efi password
          • RethoricalCheese
            • Mar 2013
            • 1519
            • Estonia
            #45
            This should do it.
            • uvaiz
              • Jan 2014
              • 113
              • saudi arabia
              #46
              surface pro efi password
              hel me to remove efi password
              • alihomee
                • Dec 2012
                • 1596
                • malaysia
                #47
                thanks so much it works for me perfectly
                • RethoricalCheese
                  • Mar 2013
                  • 1519
                  • Estonia
                  #48
                  Re: surface pro efi password
                  Try this.
                  • mattpd
                    • Oct 2012
                    • 302
                    Reflashed Surface Pro 4 BIOS to remove UEFI password. Now it boots SLOW
                    I have a Surface Pro 4 that was UEFI locked.
                    It worked normally, but you just couldn't get into BIOS without a password.
                    I stole the BIOS from another identical board and flashed it. I didn't edit the BIOS at all.
                    Now when I turn it on it takes 30 seconds to get Surface logo (before I flashed it took 1 second)
                    Then it takes about 15 seconds before you get the Windows 10 spinning dots. (normally it's almost immediate)
                    Once it's booted into Windows 10 it runs normally. I have also tried a fresh install of Win 10 since the BIOS flash.
                    I am not very experienced with BIOS flashing. Was there something I needed to edit in the donor BIOS to make this work correctly? Clear ME?
                    • RethoricalCheese
                      • Mar 2013
                      • 1519
                      • Estonia
                      #50
                      Re: Reflashed Surface Pro 4 BIOS to remove UEFI password. Now it boots SLOW
                      You should upload original locked bios, get it unlocked and flash that.
                      • mattpd
                        • Oct 2012
                        • 302
                        Surface Pro 4 - UEFI password removal please?
                        Could someone remove the password from this dump?
                        Also, if you have time can you point me to any resources that I can learn to do it myself?
                        • peste
                          • 13747
                          • ROMANIA
                          #52
                          Re: Surface Pro 4 - UEFI password removal please?
                          try...
                          • mattpd
                            • Oct 2012
                            • 302
                            Originally posted by peste
                            try...
                            No, it's still locked.
                            I have a clean ME dump for this BIOS. Would that help?
                            I can't use the clean ME BIOS directly though, because it makes the touch screen stop working. There must be something in the original BIOS that allows touch to function... I somehow need to combine them I think.
                            • RethoricalCheese
                              • Mar 2013
                              • 1519
                              • Estonia
                              #54
                              Nah, don't mess with ME and such.
                              Try this.
                              • mattpd
                                • Oct 2012
                                • 302
                                Try this.
                                YES! Thank you.
                                Touch works, starts up fast, and no more BIOS password.
                                Can you tell me how you did it?
                                EDIT: I ran it though hex compare. The only difference between the two files are a single character at offset 00606620. Is that all it takes?
                                • RethoricalCheese
                                  • Mar 2013
                                  • 1519
                                  • Estonia
                                  #56
                                  Yes, that's all it takes. The tricky part is knowing the exact byte to modify
                                  • mattpd
                                    • Oct 2012
                                    • 302
                                    Wanna give a clue?
                                    • RethoricalCheese
                                      • Mar 2013
                                      • 1519
                                      • Estonia
                                      #58
                                      Originally posted by mattpd
                                      Wanna give a clue?
                                      I think the clue was "AWord"
                                      • mattpd
                                        • Oct 2012
                                        • 302
                                          VIP Moderator
                                          • Aug 2018
                                          • 4386
                                          • Bulgaria 🇧🇬
                                          #60
                                          Become a Badcaps supporter
                                          Thanks to all supporters.​
                                          • FalconPunch
                                            Surface Pro X 1876 Bios corrupted
                                            by FalconPunch
                                            Hello everyone, I happen to have a Microsoft Surface Pro X 1876 in my hands. It was brought to me by a friends which happen to have taken off the bios chip to test another motherboard. Upon putting back the bios chip on the original motherboard, The PC is stucked on Windows logo and won t boot to bios or anything. I suspect that the changes of bios chip somehow corrupted the firmware inside. Is the hypothesis correct?
                                            Also i extracted the bios inside the chip which was on Winbond 25R128JWPQ you can find the file attached if you can fix it (if possible, I would like some insight on...
                                            08-09-2025, 03:56 AM
                                          • HighSkai
                                            Surface Laptop 5 Locked Bios Password
                                            by HighSkai
                                            Hi, can someone help me with unlocking the bios password on my bios locked Microsoft Surface Laptop 5
                                            Surface Laptop 5 - 15 in. i7/16/256
                                            Serial number:
                                            0F01D7E23283FB
                                            Thanks!​
                                            06-30-2024, 01:53 PM
                                          • Cosmin Adrian
                                            Surface go 2 locked bios
                                            by Cosmin Adrian
                                            Hi guys! So i bought a used Surface Go 2 and it came with a password locked bios.I really wanna remove the lock because they disabled USB booting and disabled SD card which is really weird. I read the forums about the ME tools and fptw but i just cant find one that works for my version of ME. Thanks in advance!
                                            Intel ME Version: v11.8, Build 4494, Hotfix 94
                                            Product Name: Surface Go 2
                                            Product Version: 1
                                            Product Serial Number: 023875311051
                                            UUID: {5C754E9E-0971-4B86-9221-C7D877AED9CD}
                                            SKU Number: Surface_Go_2_1927
                                            Family: Surface​...
                                            03-03-2024, 12:48 PM
                                          • muhuruu
                                            Surface pro 4 bios request
                                            by muhuruu
                                            Hey. Sometime ago i bought broken surface pro 4 supposedly it was dead. But turns out it was just a faulty charger. Although when it powered on and after all updates, touchscreen didn't work it also doesn't work in UEFI. On my original bios in device menager it shows yellow triangles on Surface ME and Surface Touch, hid-compliant touchscreen was missing. I already replaced touchscreen and touchscreen board, i've broken the orginal screen when trying to open surface. I already tried diffrent bios files from internet. With the latest one i was able to install the drivers for Surface ME and Surface...
                                            01-22-2024, 05:38 AM
                                          • cr4zychriss
                                            by cr4zychriss
                                            • Rebrand: PC Specialist
                                            Yesterday, 04:04 PM
