Surface 4 Pro BIOS locked
Re: Surface 4 Pro BIOS locked
you buy a programmer... open the laptop... take out the bios chip from the board... read the content of the chip and post here... someone will delete your password... take the content from the website and write it back on chip...stick the chip back on the board...do a test...see if it's ok...and if it's ok...thank you and close the laptop case...and that's it..
for example, you have a video at station #174...now you understand???!!!Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
I've been researching this tablet for a while now. I have a UEFI password locked SP4 but it boots to Windows fine just without admin access. Is my only solution to open up and dump bios and then reflash to reinstall windows and have full admin access again?
It's too bad these are annoying to be opened, maybe I can find a repair shop in the area to do itComment
yes... the only solution..I've been researching this tablet for a while now. I have a UEFI password locked SP4 but it boots to Windows fine just without admin access. Is my only solution to open up and dump bios and then reflash to reinstall windows and have full admin access again?
It's too bad these are annoying to be opened, maybe I can find a repair shop in the area to do itDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Can you tell me wich programer i must bay for read my bios please
Someone send me a linkLast edited by surface2023; 01-07-2023, 08:18 AM.Comment
dump_surfacePro4.zip - original bios with password
dump_surfacePro4.new.rar - made by paste no password. I flash this bios but surface is not start. but if I flash original bios is start but password is here
@www111www
Try it!Attached Filesif you find these attachements useful please consider making a small donation to the site
try this..Attached Filesif you find these attachements useful please consider making a small donation to the site
Greetings everyone... I'm new to the forum, however I took the time to read the entire thread, as well as all the attached links to avoid asking unnecessary questions.
Like the vast majority, I am here for the same reason, bios locked by password, so I am attaching my 16Mb .bin waiting for the collaboration of the wise experts for its modification, always thanking them in advance for the valuable work they do for all of us who come here looking for help.
I also leave a silly concern... Should I delete the IC and check before recording again?
I await your responses...
I never delete the bios chip before writing and I've never had problems...others delete it...Greetings everyone... I'm new to the forum, however I took the time to read the entire thread, as well as all the attached links to avoid asking unnecessary questions.
try..Attached Filesif you find these attachements useful please consider making a small donation to the site
After flashing the new file it never turns on again, then re flash original file and it doesn't turn on either.
Definitely the problem is not the IC, it's good, neither is the soldering.
You might think it was a bad copy even though you did it with three different programs and they were all the same.
The flash was done with AsProgrammer_2.0.3a from CH341A with 3.3 Volt mod since CH341A Programm and NeoProgrammer couldn't unlock the write or maybe I didn't know how with those.
SP4/1724 - I5/8Gb/128Gb
Any suggestions that might help would be welcome?Comment
Ok... I forgot comment the model of motherboard: x911788-009 i5 8GB 256GB
Does anyone have an original dump of this model that I can compare and test?Comment
by FalconPunchHello everyone, I happen to have a Microsoft Surface Pro X 1876 in my hands. It was brought to me by a friends which happen to have taken off the bios chip to test another motherboard. Upon putting back the bios chip on the original motherboard, The PC is stucked on Windows logo and won t boot to bios or anything. I suspect that the changes of bios chip somehow corrupted the firmware inside. Is the hypothesis correct?
Also i extracted the bios inside the chip which was on Winbond 25R128JWPQ you can find the file attached if you can fix it (if possible, I would like some insight on...-
Channel: BIOS Requests ONLY!
by HighSkaiHi, can someone help me with unlocking the bios password on my bios locked Microsoft Surface Laptop 5
Surface Laptop 5 - 15 in. i7/16/256
Serial number:
0F01D7E23283FB
Thanks!-
Hi guys! So i bought a used Surface Go 2 and it came with a password locked bios.I really wanna remove the lock because they disabled USB booting and disabled SD card which is really weird. I read the forums about the ME tools and fptw but i just cant find one that works for my version of ME. Thanks in advance!
Intel ME Version: v11.8, Build 4494, Hotfix 94
Product Name: Surface Go 2
Product Version: 1
Product Serial Number: 023875311051
UUID: {5C754E9E-0971-4B86-9221-C7D877AED9CD}
SKU Number: Surface_Go_2_1927
Family: Surface...-
by muhuruuHey. Sometime ago i bought broken surface pro 4 supposedly it was dead. But turns out it was just a faulty charger. Although when it powered on and after all updates, touchscreen didn't work it also doesn't work in UEFI. On my original bios in device menager it shows yellow triangles on Surface ME and Surface Touch, hid-compliant touchscreen was missing. I already replaced touchscreen and touchscreen board, i've broken the orginal screen when trying to open surface. I already tried diffrent bios files from internet. With the latest one i was able to install the drivers for Surface ME and Surface...
by cr4zychrissHello everyone,
I have successfully used a CH341A programmer and can read/write/verify both flash chips, but using my backups/extractions has failed to restore power. The root cause is likely a corrupted Intel Management Engine (ME) region or an incompatible EC/BIOS pairing. System & Hardware Details- Barebone / Chassis: TongFang GK7MRFR
- MB: MB: GK5MP5X V1.0 Prod :GK5MRFV10T04201310281
- Rebrand: PC Specialist
- Loading...
