Surface 4 Pro BIOS locked
Good day, friend. Thank you very much. My Surface is unlocked. I have looked through and compared many locked and unlocked firmwares for these Surfaces, I have seen that 3F is changed to 3C, but in all firmwares this change is at different addresses. I still do not understand the pattern, there must be a change. Maybe you can tell me how to find the addresses that need to be changed? -
HELLO
I have Surface Pro 4 1724
There is a password set on BIOS.
Can anyone help me remove it, please.
SN 041334670253
Attached Filesif you find these attachements useful please consider making a small donation to the site
TRYAttached Filesif you find these attachements useful please consider making a small donation to the site
hi try 2 fileAttached Filesif you find these attachements useful please consider making a small donation to the site
tryAttached Filesif you find these attachements useful please consider making a small donation to the site
please help me to clean my bios password?
Thanks and Advance!
Serial 036990154153Attached Filesif you find these attachements useful please consider making a small donation to the site
try..Attached Filesif you find these attachements useful please consider making a small donation to the site
Every donation made will go towards server fees and maintenance costs.Comment
Hi, I have a Surface Pro 4 - 256GB i5 8GB with no power issue. All voltages are available. I´ll like to check if it is a bios issue before I replace the Power-Ic.
The original bios is attached.
Serial: 038574160553Attached Filesif you find these attachements useful please consider making a small donation to the site
can any one help bios have password + SMME LOCKsurface 4 pro 1724 bios W25Q128 locked password and SEMM UEFI settingsAttached Filesif you find these attachements useful please consider making a small donation to the site
sorry about that
sn: 002482561553
bios password + SMME LOCKAttached Filesif you find these attachements useful please consider making a small donation to the site
HI tryAttached Filesif you find these attachements useful please consider making a small donation to the site
by FalconPunchHello everyone, I happen to have a Microsoft Surface Pro X 1876 in my hands. It was brought to me by a friends which happen to have taken off the bios chip to test another motherboard. Upon putting back the bios chip on the original motherboard, The PC is stucked on Windows logo and won t boot to bios or anything. I suspect that the changes of bios chip somehow corrupted the firmware inside. Is the hypothesis correct?
Also i extracted the bios inside the chip which was on Winbond 25R128JWPQ you can find the file attached if you can fix it (if possible, I would like some insight on...-
Channel: BIOS Requests ONLY!
by HighSkaiHi, can someone help me with unlocking the bios password on my bios locked Microsoft Surface Laptop 5
Surface Laptop 5 - 15 in. i7/16/256
Serial number:
0F01D7E23283FB
Thanks!-
Hi guys! So i bought a used Surface Go 2 and it came with a password locked bios.I really wanna remove the lock because they disabled USB booting and disabled SD card which is really weird. I read the forums about the ME tools and fptw but i just cant find one that works for my version of ME. Thanks in advance!
Intel ME Version: v11.8, Build 4494, Hotfix 94
Product Name: Surface Go 2
Product Version: 1
Product Serial Number: 023875311051
UUID: {5C754E9E-0971-4B86-9221-C7D877AED9CD}
SKU Number: Surface_Go_2_1927
Family: Surface...-
by muhuruuHey. Sometime ago i bought broken surface pro 4 supposedly it was dead. But turns out it was just a faulty charger. Although when it powered on and after all updates, touchscreen didn't work it also doesn't work in UEFI. On my original bios in device menager it shows yellow triangles on Surface ME and Surface Touch, hid-compliant touchscreen was missing. I already replaced touchscreen and touchscreen board, i've broken the orginal screen when trying to open surface. I already tried diffrent bios files from internet. With the latest one i was able to install the drivers for Surface ME and Surface...
by cr4zychrissHello everyone,
I have successfully used a CH341A programmer and can read/write/verify both flash chips, but using my backups/extractions has failed to restore power. The root cause is likely a corrupted Intel Management Engine (ME) region or an incompatible EC/BIOS pairing. System & Hardware Details- Barebone / Chassis: TongFang GK7MRFR
- MB: MB: GK5MP5X V1.0 Prod :GK5MRFV10T04201310281
- Rebrand: PC Specialist
- Loading...
