Asus zenbook UX490u bios
  • danieltoader69
    • Apr 2013
    • 39
    • romania
    Hy my friends
    Maybe someone help me with administrator password. Motherboard UX490UA rev 2.1.I have identical motherboard but not working with this bios dump.This is my original dump.Thanks in advanced
  • Claudiomfa
    • Nov 2015
    • 455
    • Portugal
    Re: Asus zenbook UX490u bios
    try and report
    • danieltoader69
      • Apr 2013
      • 39
      • romania
      Thanks Claudiomfa ! Bios works. No password.
      • lngcs
        • Jul 2011
        • 71
        Hi Everyone, i have ux490u no post. motherboard ux490ur rev 2.0. i try the above bios fan blast high but no screen. i've attached my original dump here.thanks
        • peste
          • 13430
          • ROMANIA
          try..
          • lngcs
            • Jul 2011
            • 71
            Hi peste, thanks for helping. clean me make no different. just power up and blank screen no backlight.
            • Claudiomfa
              • Nov 2015
              • 455
              • Portugal
              Try and report..
              • lngcs
                • Jul 2011
                • 71
                Hi Claudiomfa, this one keyboard backlight falsh once and cpu fan spin for a few second then shutdown and nothing else can't turn back on by power button.
                • Claudiomfa
                  • Nov 2015
                  • 455
                  • Portugal
                  Try this file and report..
                  • lngcs
                    • Jul 2011
                    • 71
                    Ok this one is exactly like the original one. power no screen, cpu get warm then fan will turn on. thanks everyone for helping. i think this one mostly hardware fault.
                    • odtech
                      • Jul 2023
                      • 52
                      • South Africa
                      Multi chip bios recovery
                      Hello friends.
                      Sorry if this has been asked before but i searched and didn't see the answer, maybe i used wrong search term.
                      I have a Asus UX490U that i suspect has a bad bios because the power rails are all present and no short circuits and it responds to the power button and it seems to charge the battery but it has nothing on the screen and it behaves oddly.
                      I want to flash the bios with a programmer but it has a couple of the same bios chips. How does one go about flashing?
                      Just a link to an post here is fine too.
                      Thanks in advance
                        • 21679
                        Re: Multi chip bios recovery
                        Thanks in advance
                        Mkae a backup of all of them ,making a note of where each one came from on the board,and post them all here.
                        • odtech
                          • Jul 2023
                          • 52
                          • South Africa
                          Hello.
                          I've finaly gotten around to doing this but i've got a small issue.
                          One of the bios chips isn't listed on Asprogrammer.
                          25Q80JVIQ
                          The two closest in the list is
                          25Q80BV
                          25Q80DV
                          Would it be OK to use either or should i get software with the JV chip support?
                          Any suggestion on software to try?
                            • 21679
                            Hello.
                            25Q80JVIQ
                            25Q80BV
                            25Q80DV
                            Leave that one,just post the others.
                            • odtech
                              • Jul 2023
                              • 52
                              • South Africa
                              Here it is.
                              I put the chip name in the file name in case it matters.
                              The 25Q80DV chip dumped suspiciously fast, assuming the 80 stands for flash size. The 64 chip dump took 2 to 3 times longer. Just mentioning it in case it's relevant.
                              Thanks for the assistance.
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 12269
                                here it is.
                                The 25q80dv chip dumped suspiciously fast, assuming the 80 stands for flash size. The 64 chip dump took 2 to 3 times longer. Just mentioning it in case it's relevant.
                                ux490uar
                                • odtech
                                  • Jul 2023
                                  • 52
                                  • South Africa
                                  Originally posted by hoaca388
                                  ux490uar
                                  I programmed this bios on the 25Q64JV chip and it made a difference but the laptop is still not coming on. Now when i connect the battery it immediately goes to max fan speed and the f2 button led comes on. The cpu does not get warm so the laptop didn't start.
                                  Is there anything else i can try bios related or should i get back to troubleshooting hardware?
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 12269
                                    You should get back to troubleshooting hardware.
                                    • odtech
                                      • Jul 2023
                                      • 52
                                      • South Africa
                                      Ok will do.
                                      Thanks friends for taking the time to look at my request.
                                      • odtech
                                        • Jul 2023
                                        • 52
                                        • South Africa
                                        I would like to share something with everyone that might end up here looking for bios help on the Asus UX490U laptop. I have only the CH341 programmer with the green board so not sure if this will apply to other programmers.
                                        The 25Q64JVIQ bios chip on this laptop has a large ground/thermal pad underneath that is wider than the gap between the row of pin pads on my CH341 programmer so 100% sure the pins will short to ground and it made me get all FF readings from the chip or the software reported it's in protected mode. At first i thought i just had dry solder joints so I went back over the pads with my iron and some flux but the issue persisted.
                                        The result of this issue was that the laptop would immediately power on and go to full fan rpm but not post.
                                        To resolve it I put some kapton tape over the ground/thermal pad then soldered the chip back and got it to program properly and it also programmed much faster than earlier apparent successful attempts which led to the power on/max fan speed issue.
                                        TL : DR The 25Q64JVIQ bios chip has a large ground/thermal pad that will very likely short on one or all of the pins so isolate it before attaching to your programmer if necessary.
                                        • razor_amd
                                          by razor_amd
                                          12-15-2020, 07:07 PM
                                        • grimacelord
                                          by grimacelord
                                          07-10-2025, 02:52 PM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • throwaway327
                                          by throwaway327
                                          Model No: RC72LA
                                          Serial No: SBNVKD001014459
                                          06-18-2025, 05:52 PM
                                        • ceridwen
                                          Asus Zenbook UX425JA bios help needed
                                          by ceridwen
                                          I'm having difficulty figuring out how to get a working and properly sized bios for an Asus Zenbook UX425JA. The bios from Asus is 16.25 MB, whereas the XM25QH128A on the motherboard - which I am attempting to program with a CH341A - is 16 MB in size.
                                          SN: L833NBLP0002CXMB
                                          Thanks.
                                          The bios from the website can be found here:...
                                          09-21-2025, 10:38 PM
