LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal
  • Cod king
    • 25
    • Uk
    #661
    Re: LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal
    Originally posted by Markus1741
    Hello, I can already see the problem.
    It is important to either use the absolute path like this.
    python3 $HOME/Desktop/lenovo_autopatcher/patch/autopatch.py $HOME/Desktop/lenovo_autopatcher/patch/Left1st.BIN
    Or you are rich in the same folder than like this
    python3 autopatch.py Left1st.BIN
    Even what does not work in UNIX systems is insufficient information, the system cannot add it itself.
    sudo python3 autopatch Left1st is not correct.
    python3 autopatch.py Left1st.BIN is correct.
    Good luck!!
    I've tried everything and Still having the same error even with trying a dump that i was able to successfully patch 10 minutes before hand on windows 10, on ubuntu it still throws up the same error message.
    fyi: i know enough on ubuntu cli to to understand what I'm doing but I'm no expert with it
    • leva2407
      • Jul 2016
      • 89
      • tbilisi
      #662
      need help to patch lenovo t480 dump
      • Markus1741
        • Sep 2020
        • 842
        • N/A
        #663
        Try ...
        • Markus1741
          • Sep 2020
          • 842
          • N/A
          #664
          I just used the autopatcher for leva2407 in Ubuntu and had no problems with it.
          Maybe with a little patience it will eventually work.
          • lktech
            • Jan 2021
            • 39
            • algeria
            #665
            hello guys i need to patche this dump .. lenovo thinkpad L450 please some one
            • 69d0b913
              • Mar 2018
              • 146
              • BR
              #666
              dump is corrupt, repeat the extraction, if using ch341 use the Colibri program or version 1.34
              • lktech
                • Jan 2021
                • 39
                • algeria
                #667
                Try with this thank you
                • lktech
                  • Jan 2021
                  • 39
                  • algeria
                  #668
                  i am using the tl866II Xgpro
                  • 69d0b913
                    • Mar 2018
                    • 146
                    • BR
                    #669
                    corrupt!
                    see
                    dump corrupt vs dump good
                    • lktech
                      • Jan 2021
                      • 39
                      • algeria
                      #670
                      corrupt!
                      see
                      And what is the solution in your opinion? I also downloaded from the internet and had the same problem with all the firmwares of l450 😑 ?!!
                      • 69d0b913
                        • Mar 2018
                        • 146
                        • BR
                        #671
                        send version mother board model
                        • 69d0b913
                          • Mar 2018
                          • 146
                          • BR
                          #672
                          you are looking in the wrong place, and your DUMP is corrupt.
                          • 69d0b913
                            • Mar 2018
                            • 146
                            • BR
                            #673
                            And what is the solution in your opinion? I also downloaded from the internet and had the same problem with all the firmwares of l450 �� ?!!
                            your dump has to be healthy, because if it's bad it's going to be a problem and your machine won't work with another DUMP because of the ME region which is corrupt.
                            • Ghamidi
                              • Mar 2020
                              • 303
                              • France
                              #674
                              upload backup of PS2408 chip (PCA24S08)
                              the password in this chip
                              • lktech
                                • Jan 2021
                                • 39
                                • algeria
                                #675
                                Can you give me l450-cust-pca24s08-bin plz 📢
                                • Ghamidi
                                  • Mar 2020
                                  • 303
                                  • France
                                  #676
                                  try this file
                                  • lktech
                                    • Jan 2021
                                    • 39
                                    • algeria
                                    #677
                                    try this file
                                    Thank you
                                    • Ghamidi
                                      • Mar 2020
                                      • 303
                                      • France
                                      #678
                                      Thank you
                                      Good luck
                                      • Markus1741
                                        • Sep 2020
                                        • 842
                                        • N/A
                                        #679
                                        Maybe that will help.
                                        I'm working on an installed system.
                                        I am not using a virtual machine, I cannot provide any information.
                                        I think there are unfulfilled dependencies in your virtual machine.
                                        https://askubuntu.com/questions/1034...ch-file-or-dir
                                        Good luck
                                        • ntstest
                                          • Jan 2021
                                          • Turkey
                                          #680
                                          • Vesko356
                                            by Vesko356
                                            08-11-2023, 03:27 AM
                                          • jbonavita
                                            by jbonavita
                                            Some issues
                                            Things I tried
                                            04-29-2025, 09:38 PM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • Wahaz
                                            by Wahaz
                                            10-30-2023, 08:42 PM
                                          • Bloodhoundje
                                            HP Pavilion Gaming Laptop 15-ec2523nd - Dimm2 slot disabled after corrupt bios repair? Advice requested.
                                            by Bloodhoundje
                                            I have been doing hardware repair as a hobby for some years now and recently decided to learn about repairing laptops as a fun challenge.
                                            I managed to get my hands on a "HP Pavilion Gaming 15-ec2523nd" notebook that only shows a white power LED and doesnt respond to anything.
                                            After initial testing I concluded the bios seems to be corrupted since all voltages are normal and there are no shorts. HP has a feature for a bios restore from USB with winkey+B for this model. This did not work.
                                            I have desoldered the bios chip (GigaDevice...
                                            03-16-2024, 03:12 PM
