    • 24127
    Originally posted by linxz
    Hello Maxpower3
    i got Lenovo M910q with password protected BIOS
    Can you help me to patch the bios.thanks!
    Off-topic .Desktop pc bios requests go here -> https://www.badcaps.net/forum/forumdisplay.php?f=15 .The patcher does not support it.
    • adin
      • Aug 2021
      • 39
      • australia
      #822
      worked perfect x280 !
      • danandrei96
        • Dec 2018
        • 21
        #823
        @AAAC well I'm embarrassed. Sorry about that. It seems that pressing "Enter" at the boot screen freezes the machine completely, so it won't respond if you press F1 after. I just powered it down and pressed F1 straight away at the lenovo logo, worked like a charm. Thanks a lot
        • sabah
          • Jun 2018
          • 6
          • iraq
          #824
          thanks for the file I download it ,but not working in my laptop win 10 64bit. any help please
          • linxz
            • 24
            Thank you!
            • MeoT
              • Aug 2021
              Which tools do you recommend to backup and flash the BIOS on a lenovo P72 ?
              • atomx
                • Aug 2021
                #827
                So I'm trying to give it a go but getting stuck here:
                Code:
                Using UEFIReplace to inject 2 DXE drivers...
                [1/2] BootOption (GUID e0746c42-d3f9-4f8b-b211-1410957b9ff5)
                [2/2] LenovoTranslateService (GUID 826bcf56-bac4-43f4-8ea1-8cdf0a121abd)
                Looking for volumes to patch...
                Traceback (most recent call last):
                 File "c:\lenbios\lenbios\patch\autopatch.py", line 301, in <module>
                  patch(filename)
                 File "c:\lenbios\lenbios\patch\autopatch.py", line 171, in patch
                  clean(patched_filename)
                 File "c:\lenbios\lenbios\patch\autopatch.py", line 188, in clean
                  volume = load_patched_volume(p)
                 File "c:\lenbios\lenbios\patch\autopatch.py", line 234, in load_patched_volume
                  size = int.from_bytes(header[16:19], 'little')
                AttributeError: type object 'int' has no attribute 'from_bytes'
                To add up, all of my IC reads return the same md5 regardless of the software used
                  • 24127
                  Laptop model number ?
                  • atomx
                    • Aug 2021
                    #829
                    Oops, my bad. It's an X280, Winbond 25Q128JVSQ, using a CH341a + clip.
                    • atomx
                      • Aug 2021
                      #830
                      Can't edit the post so just following up with the fix: because it was an obvious python issue, placed all the auto-patcher files in the /AppData/Local/Programs/Python folder and ran from there with zero issues.
                      Thanks!
                      • Maxpower3
                        Bad Veteran
                        • Feb 2018
                        • 1602
                        • France
                        #831
                        Code:
                          patch(filename)
                        try may be
                        https://www.badcaps.net/forum/showpo...postcount=1444
                        • MeoT
                          • Aug 2021
                          Hello, can someone guide me on how to remove the supervisor password on a lenovo P72.
                          Thank you!
                          • neverexisted
                            • Nov 2012
                            • 76
                            I just get this no matter what I do:
                            1.bin is corrupted or does not contain a valid dump.
                            There was an error... Aborting.
                            T420i and E531 / E530
                            • Maxpower3
                              Bad Veteran
                              • Feb 2018
                              • 1602
                              • France
                              #834
                              model with P24s08 ?
                              autopatcher don't work
                              look
                              http://www.ja.axxs.net/eeprom_location.htm
                              • albodriy
                                • Aug 2021
                                • Russia
                                #835
                                Hello everyone! I have bad English, sorry. I have a laptop Thinkpad t480s type 20L7-001LGE.
                                And it looks like I broke it. I made a dump but didn't check it. I tried to flash it and got a black screen.
                                The script did not work, saying that the dump: "Is corrupted or does not contain a valid dump".
                                I tried to flash someone else's dump from a user post from this forum. I got to 7 points,
                                but then when I flashed someone else's original dump I got a black screen. Everything is bad? Here is my broken dump.
                                • malangg
                                  • Sep 2014
                                  • 34
                                  #836
                                  Hi, I tried on x390, but getting beep and back screen only..
                                  any help will be aprreciated..
                                  thanks
                                  • srpr
                                    • Oct 2019
                                    • 12
                                    • turkey
                                    #837
                                    can someone help me? I failed.
                                    • kiknusko
                                      kiknusko
                                      • Jan 2019
                                      • 26
                                      • Slovensko
                                      #838
                                      Here
                                      • Soo
                                        • May 2016
                                        • 7
                                        • On the Hill
                                        #839
                                        Helo
                                        I have a lenovo Yoga 11e can some one help with bios patch?
                                        bios
                                          • 24127
                                          Originally posted by Soo
                                          Helo
                                          bios
                                          Read some other Yoga 11e threads, the patcher doesn`t work.
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                          • cr4zychriss
                                            by cr4zychriss
                                            • Rebrand: PC Specialist
                                            11-14-2025, 04:04 PM
                                          • TopPop
                                            Dell Latitude 5530 BIOS Password Removal Attempted but I Broke the Laptop
                                            by TopPop
                                            Sorry for the long story. I have a Dell Latitude 5530 (i7) laptop (South Peak 15 MLK MB DDR4 203102-1 FK8VG$JA) with an admin BIOS password that I want to remove. Service Tag: HYKFPT3. Other than that the laptop worked OK.
                                            I found a CH341A Black and went looking for the BIOS chip on the motherboard. After trying to read one chip that was a firmware chip but not the BIOS I think I found the BIOS chip labeled Winbond 25Q256JVEN. Altogether I think I found 4 different firmware chips in the laptop. The BIOS chip is a WSON8 6x8. I used the CH341A, NeoProgrammer, and a cheap pogo pin clip...
                                            12-14-2025, 09:40 PM
                                          • pirati
                                            by pirati
                                            10-27-2025, 04:20 PM
                                          • Deniz
                                            IdeaPad Gaming 3 16IAH7 BIOS Issue / GPU Not Detected
                                            by Deniz
                                            Bu: https://pcsupport.lenovo.com/tr/tr/p...065tx/mp2br7d9
                                            I have a Lenovo IdeaPad Gaming 3 16IAH7. When the device first arrived, there was no display at all.
                                            I had the BIOS cleaned, but the issue was not resolved and there was still no image.
                                            Later, I flashed a different BIOS dump from the same model. With this BIOS, the device boots and display works, but the GPU is not detected in the BIOS (RTX 3060 is missing).
                                            After that, I tried to update the...
                                            01-27-2026, 06:56 AM
