  • xaxex
    • Sep 2020
    • 24
    I have just flashed the chip with patched bios and I get 5 beeps and no display
    • xaxex
      • Sep 2020
      • 24
      Can someone please patch this?
      • lapfix
        • Mar 2020
        • 2765
        • my workshop
        #143
        Clean me region the patched dumb
        • lapfix
          • Mar 2020
          • 2765
          • my workshop
          #144
          Try
          • xaxex
            • Sep 2020
            • 24
            Originally posted by lapfix
            Try
            I have flashed it. And now there is no sound and display.
            What have I tried so far:
            Read dump twice and matched Sha1 hashes
            Patched it and then flashed it with ch341a software. this resulted in 5 beeps and no display.
            Downloaded patch of someone else from this thread and write it. The sound is gone and the display is still blank/black.
            Downloaded original dump of someone else from this thread and write it. Still no change.
            And now, I flashed the patch you provided. Still no change.
            Can i recover it? When I was patching it, the software said:
            [1/1] NVRAM_EfiSystemNvDataFvGuid (checksum 2609h):
            Not found... Skipping.
            What do you mean clean ME?
            • lapfix
              • Mar 2020
              • 2765
              • my workshop
              #146
              What do you mean clean ME?[/QUOTE]
              Read this thread : https://www.badcaps.net/forum/showthread.php?t=88533
              • lapfix
                • Mar 2020
                • 2765
                • my workshop
                #147
                Try this patch from maxpower : https://www.badcaps.net/forum/showth...+T440s+patched
                • xaxex
                  • Sep 2020
                  • 24
                  I have cleaned ME. But only after merging both 4MB & 8MB dumps as it was not opening correctly in flash tool. Now, how do I unmerge it and flash separately to 4MB & 8MB flash chips?
                  • xaxex
                    • Sep 2020
                    • 24
                    Already tried not working
                    • xaxex
                      • Sep 2020
                      • 24
                      Can someone provide a flashable files from these? These are original dumps and have yet to patch my laptop.
                      Contains both 4MB & 8MB dumps
                      • Knucklegrumble
                        • Jun 2020
                        • 78
                        • US
                        #151
                        There is no need to merge files, and no need to clean ME.
                        The autopatcher is reported to be working on T440 just fine. Use it on the 4MB dump. It will skip the NVRAM cleanup. That's fine. Then go ahead and flash it. FOLLOW THE INSTRUCTIONS!!! remove the hard disk, tape down the anti-tamper switch (if you have one).
                        ALSO MAKE SURE YOU ACTUALLY HAVE A SUPERVISOR PASSWORD.
                        The patch does not work for boot password and hard disk passwords.
                        • xaxex
                          • Sep 2020
                          • 24
                          It was PIA to disassemble whole laptop. The laptop hasn't been able to display anything since I flashed the patched file. Only the power key blinks. When I first flashed the patched, there were some beeps. This didn't went away despite waiting for minutes and restarting multiple times. All batteries were still removed at this point. Only gave power via adapter. It continued being blank. But then I panicked and flashed other t440p dumps on 4MB chip. This took the beep away but the display remained same i.e. blank, not even a light. Then I flashed original dump thinking it may restore my laptop, but it didn't. Now, I am cleaning ME.
                          I have followed instructions very carefully so far. Haven't tried hard disk thing but will it help with display? Should I just patch the 4MB and boot up without HDD when the laptop doesn't even has any display or beeps now. And only power lights up
                          I have supervisor password in BIOS which doesn't let me change any intel processor virtual settings. All the options are locked. It's a supervisor password and it's enabled. When ever i enter bios, it asks me for supervisor first and if i press enter, it loads basic bios with no change able option
                          • xaxex
                            • Sep 2020
                            • 24
                            One strange thing I have noticed. When I write a ROM and then read it again, shouldn't it be same? Except it's not.
                            The file hashes doesn't match means the read file is changed from the file I am writing to chip.
                            • AAAC
                              • Jan 2020
                              • 459
                              • Mexico
                              #154
                              @xaxex
                              CH341A programmer is known to corrupt the dump under certain circumstances, I'll say this is due to the speed of the computer being used to read/write chip (an old computer may work best, seems like programmer can not keep up and it corrupts dump when reading or corrupts chip contents when writing), but to solve this problem I suggest to use FlashROM with CH341A driver.
                              Get a clean ME dump for your ThinkPad T440p, once it works you can get it patched.
                              For FlashROM check post #19:
                              www.badcaps.net/forum/showthread.php?t=69145
                              • Trickiedickie
                                • Aug 2020
                                • 6
                                @xaxex My advice is if you use the ch341a programmer you should also use the Colibri 10.0.1.61 software for reading and writing back. The other software does not read/dump the eeprom correctly.
                                • Knucklegrumble
                                  • Jun 2020
                                  • 78
                                  • US
                                  #156
                                  The instructions are:
                                  1. Read your bios chip and create a dump file
                                  2. Do it again 2-3 times and compare the files to verify integrity
                                  3. Patch the dump
                                  4. Write the patch to your laptop
                                  5. DISCONNECT HARD DRIVE
                                  6. TAPE DOWN ANTI-TAMPER SWITCH (IF PRESENT)
                                  7. Boot laptop and follow the steps in the first post (or see directions by executing autopatch --howto)
                                  8. WRITE ORIGINAL BIOS BACK TO THE MACHINE!
                                  So the answer to your question "Haven't tried hard disk thing but will it help with display?" is: it's possible, but if you don't try it how can we troubleshoot?
                                  • Mazorca
                                    • Jan 2017
                                    • 463
                                    I confirm that it did work on a lenovo x240 corei5. I had to rename file to 1.bin. Follow instructions closely. Thank you all.
                                    • OmegaPrime
                                      • Jun 2020
                                      • 22
                                      #158
                                      Can anybody make patch for T570 , sizes of pach files not match as size in dump...
                                      autopatcher alway says : Using UEFIReplace to inject 0 DXE drivers...
                                      • lapfix
                                        • Mar 2020
                                        • 2765
                                        • my workshop
                                        #159
                                        post your old dump
                                        • OmegaPrime
                                          • Jun 2020
                                          • 22
                                          #160
                                          here is
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                          • pirati
                                            by pirati
                                            10-27-2025, 04:20 PM
                                            by Vesko356
                                            08-11-2023, 03:27 AM
                                          • jbonavita
                                            by jbonavita
                                            Some issues
                                            Things I tried
                                            04-29-2025, 09:38 PM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
