  • octaavio
    • May 2022
    • brazil
    #1481
    I get to the step of pressing space twice
    but what would restore the original BIOS?
    back the backup file? for the bios c.i?
    • imed40
      • May 2022
      • algerie
      #1482
      Hi everyone
      please can somebody help me to patch and clean my bios from Lenovo T480
        • 20299
        Originally posted by imed40
        Hi everyone
        [ATTACH]263650[/ATTACH]
        The Autopatcher at post #1 works with the T480,havn`t you tried it ?
        • Elettrone62
          • Nov 2021
          • 7
          • Italia
          #1484
          Hello everyone, I'm looking for help for Lenovo T495 pc with AMD Ryzen the card is a fa495 nm-c131 rev 1.0. The PC has the password on the BIOS and I have already tried to perform the procedure described on the first page of the post. Saved the Bios, subjected to the cleaning tools, saved Bios on eprom. The Eprom is a W25Q128FW (1.8Volt), so I have regularly programmed the eprom with voltage matching, no problem here, now I put it back together and I only get black screen and and a series of sounds, the CPU fan after power on and termination sound stops and the CPU heats up somewhat. Reading in the forum I find that others are posting with similar symptoms SEE https://www.badcaps.net/forum/showth...=fa495+nm-c131
          Reading this post hoaca388 offers him a patch version of the Bios .FL1 format that can be downloaded from the Lenovo website. Following his instructions, I download the BIOS program for the T495 from the site, I extract the .FL1 I make the cuts with an exa editor of the initial and final part to obtain a .BIN files with the latest Lenovo BIOS, I program and trace the Eprom, the only flaw I kept disconnected the internal battery, but I did not disconnect the holding battery of the Bios and system time. Then with this I get that the screen works, after which it performs an automatic update on the screen. It restarts and writes me "Bad CRC of security setting in EFI variable" "F1 for Setup", unfortunately I always have the password to access the BIOS. Now before I go back to unsoldering the Eprom and redo other tests maybe trying to mount this BIOS with the autopatch, I would like to understand if someone with this model T495 has managed to remove the BIOS password, reading in the forum I seem to have understood that someone he did it with the T495S but I do not think it is the same machine, for the moment I am not attaching the files of my BIOS, as I have already done to use the autopatch, but if someone has other possible ways to show me I would appreciate it very much.
          Sorry my syntax, but I'm using google translate, i hope you understand my writing anyway.
          • oghiee
            • Apr 2022
            • Indonesia
            #1485
            Help me unlock Lenovo Thinkpad L460 NM-A651 Rev 1.0 thanks
              • 20299
              Read post #1476 and #1477 ,isn`t it the same one you`re asking for again... ? . Have you even tried using the Autopatcher at post #1 ?
              You MUST:
              • oghiee
                • Apr 2022
                • Indonesia
                #1487
                Hello I've used this file and it works very well. Now the password is unlocked. Thank you very much
                • OntarioTL
                  • Feb 2022
                  • 45
                  Has anyone had any issues with Python recently? I went to patch a file and for some reason python just kicks out immediately when attempting the patch. It worked perfectly fine before, but I'm wondering if Windows updates pooched something on me.
                  I'll continue to work on it, but just was wondering if it's just me (waiting for sarcastic remarks ;p )
                  • munir100
                    • Dec 2018
                    • 178
                    • uae
                    #1489
                    Lenovo l450 password auto pachd not work
                    • Markus1741
                      • Sep 2020
                      • 842
                      • N/A
                      #1490
                      It looks like your BIOS file is corrupt, try reading it again.
                      It's just a BIOS chip like in the picture.
                      8MB Chip?
                      https://www.allservice.ro/forum/images/L450_bios.jpg
                      • munir100
                        • Dec 2018
                        • 178
                        • uae
                        #1491
                        Yes 8mb bios lenovo l450
                        • temporary111
                          • Apr 2022
                          • Czech
                          #1492
                          May I ask you please for patch of my bios dump to remove bios password for Lenovo L470?
                          Thank you.
                          • Markus1741
                            • Sep 2020
                            • 842
                            • N/A
                            #1493
                            Thank you.
                            Try this ....
                            • xxzheka
                              • Nov 2019
                              • 9
                              • Ukraine
                              #1494
                              Hi friends
                              I can't patch the Bios from P52. Gives an error.
                              Dump read 3 times, the same mistake. Can someone help me?
                              I removed the password for T450 and X270, everything was OK
                              • siwykk
                                • May 2020
                                • 54
                                • N/A
                                #1495
                                Originally posted by xxzheka
                                Hi friends
                                [ATTACH]264029[/ATTACH]
                                [ATTACH]264032[/ATTACH]
                                Bin is damaged, read again and verify.
                                • frisko78
                                  • May 2022
                                  • 7
                                  Hi everyone ��,
                                  i have a question about this topic before i would buy an programmer.
                                  Will it also work with an T570? Is the patch functionaly?
                                  Till now i read over 50 sites here but i can‘t find, if it is successful with this model?
                                  Many Thanks in advance ��
                                    • 20299
                                    Originally posted by frisko78
                                    Hi everyone ��,
                                    Yes it works.Use the Autopatcher at post #1,follow the instructions carefully,and make sure you have some good backups.
                                    https://www.badcaps.net/forum/showth...70#post1042483
                                    https://www.badcaps.net/forum/showth...70#post1123602
                                    https://www.badcaps.net/forum/showth...70#post1049924
                                    • frisko78
                                      • May 2022
                                      • 7
                                      ….i will try it, but at first i need a programmer and the located bios chip. 😁 👌🏻🙂
                                      Many Thanks to you….Marko
                                      • xxzheka
                                        • Nov 2019
                                        • 9
                                        • Ukraine
                                        #1499
                                        I can't read the Bios MX25L25673g chip properly through my TL866A programmer (25L25673g is not listed). Can I somehow read this chip with the TL866A?
                                        • AAAC
                                          • Jan 2020
                                          • 457
                                          • Mexico
                                          #1500
                                          @xxzheka
                                          My suggestion is to use any other chip of the same capacity, for example a Winbond W25Q256. Other option is to download the chip datasheet and manually add its IDentifiers so the programmer software correctly IDentifies the chip.
                                          READ chip once and SAVE it, do it a total of 3 times and then compare all 3 files to make sure you have a good backup.
                                          Having a 256-Megabit chip (32MB) you must have this one:
                                          ThinkPad P52 (TYPES: 20M9, 20MA)
                                            by Vesko356
                                            08-11-2023, 03:27 AM
                                          • jbonavita
                                            by jbonavita
                                            Some issues
                                            Things I tried
                                            04-29-2025, 09:38 PM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • Wahaz
                                            by Wahaz
                                            10-30-2023, 08:42 PM
                                          • Bloodhoundje
                                            by Bloodhoundje
                                            03-16-2024, 03:12 PM
