  • Polar Bear
    Polar Bear
    • Jun 2025
    • 8
    A friend of mine approached me with request for help to recover access to a few electronic devices left after tragic death of his son. One of the devices is a Lenovo T480s laptop with UEFI Supervisor laptop. I did my research on internet for possible methods and couple of them lead to BadCaps forum.
    Laptop: Lenovo T480s
    MB: ET481 NS-B471 Rev: 1.0 2017-10-30
    Type: 20L7-002CUS
    S/N: PC-0WWFM7 18/08
    BIOS IC: 25Q128JVSQ
    Method #1: Lenovo autopatcher
    Video: https://www.youtube.com/watch?v=s9XlN2Hl0ag
    lenovo_autopatcher_0.2
    The BIOS has been read and stored 3 times in a files, CRC is the same for each file. The BIOS was processed by lenovo_autopatcher_0.2 successfully. The result bin file was written into the BIOS chip. At next laptop's boot a procedure to disable TPM was completed successfully. Then original BIOS was written/restored into BIOS chip. Following boot of the laptop still asks for password input.
    The procedure was completed/repeated a few times (with connected/disconnected batteries) with exactly same result.
    Method #2: Supervisor password decryption
    Video: https://www.youtube.com/watch?v=IhRw7ePhLKs
    Followed the video in attempt to decript Supervisor's password. Using UEFItool was found padding value (00700000h) and BIOS file was scanned for an offset (0003FC20h). Looking at 0073FC20h in BIOS file the password has 168 bites and bytes values way beyond keyboard scan codes. It is considered that this attempt/method is not applicable to Lenovo T480s.
    Keyboard scancodes: https://aeb.win.tue.nl/linux/kbd/scancodes-1.html
    Method #3: JLPC ADC shorting to GND
    Video: https://www.youtube.com/watch?v=D-PFVJpBcTY
    URL: https://www.badcaps.net/forum/troubl...-ec-pwd-bypass
    Followed the video, in many attepts to GND any pin 4,6,8,10 (ADC0:3) on JLPC pads and only once I was offered to press F1 go get into BIOS settings, for some unexplicable reason keyboard refused to respond on key presses. All following attempts was unsuccessful so far (to catch a right timing to corrupt data exchange and get into BIOS settings).
    Please suggest how Supervisor password can be remove.
    Your help is greatly appreciated.
    • peste
      peste commented
      Editing a comment
      post merged...next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
  • abrnb
    • Apr 2023
    • 6
    • India
    #3862
    when i try to autopatch a file the fill generated and immediately deleted, pls assist me for this problem, Thanks
    • Polar Bear
      Polar Bear
      • Jun 2025
      • 8
      Hello Knucklegrumble,
      per your suggestion I would like to report unsuccessful case with Lenovo T480s. I followed your procedure and everything was going according plan except that after restoring original BIOS and reboot laptop asks for a password.
      I've made a post for my case with a details. I would appreciate if you take a look at it.
      Thank you for your work and help
      Polar Bear
      • Polar Bear
        Polar Bear
        • Jun 2025
        • 8
        Originally posted by Vincehu
        Just bought a CH341A programmer for Thinkpad T480s, IC chip is 25Q128JVSQ,
        I used the AsProgrammer 2.1.0 .13 Version, But I cannot find this chip model in CH341A chip list, there are only 25Q128BV and 25Q128FV.
        Can someone help how to handle this IC 25Q128JVSQ?
        Thanks very much.
        you can use any of 25Q128BV or 25Q128FV they share same chip ID as your IC 25Q128JVSQ (see page 21).
        Or you can add your chip into list of supported chips yourself. Just edit file chiplist.xml,
        find line
        Code:
        <W25Q128FV id="EF4018" page="256" size="16777216"/>
        add after it
        Code:
        <W25Q128JV id="EF4018" page="256" size="16777216"/>
        save the file.
        Now try identify chip in AsProgrammer and you will see your chip in the list.
        Note: you can download more recent AsProgrammer 3.7 or AsProgrammer 2.1.2
        Polar Bear
        • CesrDroid
          • Jun 2025
          • Lima
          #3865
          Originally posted by CesrDroid
          Can someone help me? When I use the autopatcher, the computer starts beeping and does not start the BIOS.
          I just saw that I uploaded the file, but it's 6MB. The original BIOS is 16MB, but when I run the autopatcher, it doesn't work and the siren is activated.
          • Maxpower3
            Bad Veteran
            • Feb 2018
            • 1358
            • France
            #3866
            serial number, type etc ... respect rules please
            • Maxpower3
              Bad Veteran
              • Feb 2018
              • 1358
              • France
              #3867
              method 1 should work
              Method 2 doesn't work. Password is in EC. Can't decrypt. It's not registered in the BIOS.
              Method 3: You must use a USB keyboard because the shunt disables the keyboard. Watch the other videos to understand, the timing of the shunt is important
              f1 is pressed before the shunt.
              • CesrDroid
                • Jun 2025
                • Lima
                #3868
                Model: ThinkPad T480
                Serial Number: PF-1NSAAJ
                Motherboard Model: ET480 NM-B501 - rEV. 1,0 - 2018-03.03
                Issue:
                I am unable to remove the BIOS supervisor password. I have tried all recommended procedures, including the Lenovo Auto‑Patcher, but I am still locked out.
                What I have tried:
                Used Flashrom and a CH341A SPI programmer to read and write the BIOS chip.
                Worked from both Ubuntu and Windows 11 operating systems during the process.
                Flashed both 8MB and 4MB dumps (attached below).
                Ran the latest Lenovo Auto-Patcher script on my BIOS dumps.
                Flashed the patched BIOS back to the chip.
                I also tried the original BIOS dump for recovery.
                Current symptoms:
                With patched BIOS: The laptop does not boot and emits a continuous siren/alarm sound.
                With original BIOS: The laptop boots but asks for the supervisor password (which I do not have).
                Additional info:
                The board label says MN-B501.
                Thank you in advance for your help! Any guidance or clean/unlocked BIOS would be greatly appreciated.
                • Polar Bear
                  Polar Bear
                  • Jun 2025
                  • 8
                  Tried method 1 again and again -- still after flashing original BIOS on boot a password is asked.
                  Tried method 3 again and again -- so far no success in right timing.
                  Note on method 3:
                  Tried to shunt after backlight on (no Lenovo logo, probably in BIOS set fastboot) with tapping F1 key - the boot process either "paused" or might give an error and reboot, or might play melody (couple of times), or password input requested. Watched YouTube videos with the procedure, I see that success shunt often happens on second-third-fourth try but in my case no luck so far.
                  Is there any setting in BIOS which could cause of such behavour?
                  Polar Bear
                  • abrnb
                    • Apr 2023
                    • 6
                    • India
                    #3870
                    Originally posted by Stefan Steff
                    If your CPU is i7-8650U then the patcher doesn't work...
                    Hi
                    if cpu is i5 13th, will this patcher work brother?
                    • Stefan Steff
                      • Mar 2024
                      • 399
                      #3871
                      Originally posted by abrnb
                      Hi
                      No, it will not work.
                      The autopatcher works on MBs with CPU version until 8-th gen.
                      • abrnb
                        • Apr 2023
                        • 6
                        • India
                        #3872
                        Hi
                        Thanks for you reply, is there anyway to remove supervisor password for latest gen for lenovo, if yes mean please suggest me Thanks in advance brother
                        • Stefan Steff
                          • Mar 2024
                          • 399
                          #3873
                          Yes there is a hope...read here:
                          https://www.badcaps.net/forum/troubl...ss#post3237235
                          • Stachujones
                            • Jul 2023
                            • 21
                            • Poland
                            #3874
                            Hello i have a problem using autopatcher in ThinkPad X280, after writing patched file laptop is beeping code 010288 and no display, tried on original bios from 2020 and after update on newest bios from 2025
                            after writing original bios laptop is starting fine again
                            Laptop: ThinkPad X280
                            MB: NM-B521
                            SN: PC0YZ1FW 18/11
                            BIOS IC 25Q128JVSQ
                            Could anyone help me with removing supervisor password, thanks in advance
                            • danito
                              • Jun 2016
                              • 1233
                              #3875
                              MB: NM-B521
                              SN: PC0YZ1FW 18/11
                              BIOS IC 25Q128JVSQ
                              try
                              • Stachujones
                                • Jul 2023
                                • 21
                                • Poland
                                #3876
                                Originally posted by danito
                                try
                                Still the same behavior, no display and the same sound error
                                • Stachujones
                                  • Jul 2023
                                  • 21
                                  • Poland
                                  #3877
                                  Done, fix ot by flashing first clean me bios, than reading it back, doing autopatch, laptop booted just fine, and lastly writing original file from laptop
                                  Maybe this will help someone
                                  • mohammedsf
                                    • Jun 2014
                                    • 16
                                    • Lebanon
                                    #3878
                                    Hi, please help me patching this bios to remove the password..
                                    MB: NM-B521 Rev 1.0
                                    Machine type: 20KE
                                    SN: PC-0YC2T3
                                    • peste
                                      peste commented
                                      Editing a comment
                                      post merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
                                  • EB999999
                                    • Jun 2025
                                    #3879
                                    I'm having trouble deleting the SVP on my laptop.
                                    EDIT:
                                    [It's an x280 20KES2SN00; i5-8350U 8GB 01LX681
                                    SN: PC16FNZB 19/07
                                    IC: W25Q128JVSQ]
                                    After flashing the patched file, I get a black screen and a musical note.
                                    The original bin dump is uncorrupted and works after flashing it.
                                    How can I fix the patched file so it works to remove the SVP?
                                    Thanks for your help
                                    • peste
                                      • 13880
                                      • ROMANIA
                                      #3880
                                      Originally posted by EB999999
                                      I'm having trouble deleting the SVP on an x280
                                      post S/N, full name and model, motherboard model, TYPE,etc.
                                      • macabook
                                        by macabook
                                        🧩 Initial Issue
                                        07-24-2025, 02:17 PM
                                      • cr4zychriss
                                        by cr4zychriss
                                        • Rebrand: PC Specialist
                                        11-14-2025, 04:04 PM
                                      • pirati
                                        by pirati
                                        10-27-2025, 04:20 PM
                                        by Vesko356
                                        08-11-2023, 03:27 AM
                                      • istvanszasz99
                                        Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
                                        by istvanszasz99
                                        Product ID: RZ09-0421
                                        Motherboard: CH580
                                        Bios File Size: 32,768 KB
                                        Dear Forum Readers!
                                        !!! MY RAZER BLADE...
                                        11-24-2025, 05:52 PM
