  • Stefan Steff
    • Mar 2024
    • 389
    #3981
    Originally posted by ofluffy
    Can you send a link to a decent one? I don't have a JTAG programmer. I have heard of it though, but I usually avoid it and use UART with my raspberry pis, since I've only ever used it for serial debugging/console.
    I think RT809H is the best price/value in this category...in fact every programmer has good and bad things but to use it once or twice a year then RT809H is a good choice.
    In US you find a lot of RT809H programmers on Amazon or eBay. (ex. https://a.co/d/eUE6vcB)
    Look for RT809H not for RT809F !
    • mouse1972
      • Jul 2023
      • 13
      • Ukraine
      #3982
      Try with this attached content.
      STEP 1: Flash and replace current BIOS with the P50_Bios_2_PATCHED.bin file
      STEP 2: Boot the machine
      STEP 3: Press ENTER/F1/etc. to enter BIOS settings
      STEP 4: Enter any character when asked for Supervisor Password
      STEP 5: Press enter when it shows Hardware ID
      STEP 6: Press space bar 2x when asked
      STEP 7: Turn off machine
      STEP 8: Restore original P50_Bios_1.bin BIOS content
      STEP 9: Reset BIOS settings to factory default
      Good luck!
      This file didn't help. My P50 is still dead.😂
      • Karol
        • May 2016
        • 90
        #3983
        Originally posted by mariusdumi
        Thanks for sharing.
        I tried the file you shared,
        I wrote it and verified it was written correctly.
        It has the same problem as above: it beeps 5 times twice, the fans spin for a few seconds, and then shuts down. No signal.
        rewriting my original, it goes back to how it was before with the password.
        Test this second version if you still need , let me know.
        Joe's KMX1 Pro S, RevelprogIS, TL866II, CH341A, Vertyanov JIG 3.1, Eakins Microscope, Gordak 952, 30V/5Ah PSU, 890C+, T2L Thermal Camera, SVOD 3, etc.
        • Sidqi Januar Riadi
          • Dec 2024
          • 31
          • INDONESIA
          #3984
          brother please helpme,please send patch t470p ,i have problem bios password
          s/n:R90VGF3G
          • mouse1972
            • Jul 2023
            • 13
            • Ukraine
            #3985
            Try this.
            • ofluffy
              • Aug 2025
              • 11
              • US
              #3986
              I ordered the one you sent, however I've noticed something. Underneath the black "tape" around the motherboard, I found a messed up chip. There is one wider chip near the Ethernet port that is cracked and has exposed copper coils! I looked into it some, if this is shorting out I think it may be causing my issue. I'd like to have the programmer anyway, but this might be the real issue with my laptop. I hadn't considered hardware damage because it was powering on fine before, but I believe I may have jolted it slightly which caused a short in the chip. I think removing it entirely should stop the short, it would just prevent the RJ45 from functioning. Thank you for your help! I'll come back here if it's not that chip and still doesn't boot.
              • Stefan Steff
                • Mar 2024
                • 389
                #3987
                OK.
                Rewriting the EC chip must be the last try if any else isn't working .
                A very good hardware check before it's also a good idea...
                Good Luck!
                • moadb
                  • Sep 2025
                  • france
                  #3988
                  Any idea if this will work on a P14s G5?
                  • mariusdumi
                    • Sep 2025
                    • 7
                    • Italia
                    #3989
                    Hi, this file boots the PC.
                    I follow this procedure, but I get stuck at step 5.
                    When the hardware ID appears, whatever I do is invalid password.
                    I can't proceed.
                    I tried restoring my original file, but the password isn't removed.
                    The HARDWARE ID changes with every boot.​
                      • Dec 2024
                      • 31
                      • INDONESIA
                      #3990
                      Originally posted by mouse1972
                      Try this.
                      thank you very much brother, it works for me.🤗🤗🤗
                      • Maxpower3
                        Bad Veteran
                        • Feb 2018
                        • 1356
                        • France
                        #3991
                        I can't proceed.
                        Click image for larger version  Name:	image.png Views:	0 Size:	40.6 KB ID:	3726086
                        try with nokey
                        Karol no solution selling here.
                        • spink90
                          • Sep 2025
                          • 8
                          • Poland
                          #3992
                          Hello!
                          I used autopatcher, rewrote the patched file in the bios, but as a result, when I press the power button, nothing happens.
                          I performed the first part (uploading patched bios and passing through empty fields, pressing the spacebar twice, etc.) using a clip.
                          While clearing memory before uploading the original batch, clip started failing (applications were freezing – neoprogrammer, asprogrammer, etc.).
                          So I desoldered the chip, cleaned it, uploaded the batch from the backup, and then verified it (I've attached a photo).
                          Unfortunately, the laptop wouldn't boot.
                          Only reaction is red LED (the one next to charging port) lighting up after connecting charger to any USB-C charging port.
                          Can someone help?
                          Laptop Lenovo X1 Yoga 3rd GEN
                          Type 20LE-SFO0X
                          Serial R9-0T1L2P
                          Original bios, backup bios, patched bios:
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 12426
                            #3993
                            Originally posted by spink90
                            Hello!
                            Can someone help?
                            Type 20LE-SFO0X
                            Serial R9-0T1L2P
                            Try again with Autopatcher.
                            • spink90
                              • Sep 2025
                              • 8
                              • Poland
                              #3994
                              I'm asking just to be sure.
                              Should I desolder the chip, clean it(erase), check if it's empty(blank check), and then upload(write) bios from you on this chip, then solder it again?
                              Thank you for taking the time to respond.
                              • Karol
                                • May 2016
                                • 90
                                #3995
                                I can't proceed.
                                Post the hardware ID and wait for the key.
                                Maxpower3 Don't make free accusations
                                • spink90
                                  • Sep 2025
                                  • 8
                                  • Poland
                                  #3996
                                  @hoaca388
                                  After uploading your file, the laptop reacts as follows:
                                  Keyboard LEDs (FNLock/ESC) light up - LEDs light up for a moment (after connecting the charger - the BIOS battery and the laptop battery are disconnected).
                                  White LED next to the charging port lights up.
                                  Fan doesn't spin.
                                  Screen is black (no backlight).
                                  • spink90
                                    • Sep 2025
                                    • 8
                                    • Poland
                                    #3997
                                    After flashing the patched BIOS (which worked yesterday it prompted me to enter the password (1234), then the hardware ID(enter), space 2 times, and then to turn off the machine, as instructed).
                                    Today I only get the power button to illuminate three times on white (a non-repeating sequence).
                                    I tested it with the BIOS/laptop battery disconnected - no change.
                                    • spink90
                                      • Sep 2025
                                      • 8
                                      • Poland
                                      #3998
                                      I compared this motherboard with same motherboard, and it turns out I'd probably ripped out one resistor (33 ohms) from the R2105 slot with clip.
                                      This might be why the computer isn't waking up?
                                      • spink90
                                        • Sep 2025
                                        • 8
                                        • Poland
                                        #3999
                                        I pulled out second computer, identical to the one I tried before.
                                        I repeated the entire procedure.
                                        Patched BIOS booted, and I went through the process.
                                        I desoldered the chip and soldered the same chip from where the previously readed BIOS(2nd lenovo X1 3rd gen).
                                        As a result, both computers are dead – they won't boot, the fan won't spin, and the monitor won't backlight.
                                        I used lenovo_autopatcher_0.2.
                                        Type: 20LES3FQ0X
                                        Serial: R90T1L30​
                                        • Markus1741
                                          • Sep 2020
                                          • 975
                                          • N/A
                                          #4000
                                          Type: 20LES3FQ0X
                                          Serial: R90T1L30
                                          Hello you can try this file good luck ....
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                          • cr4zychriss
                                            by cr4zychriss
                                            • Rebrand: PC Specialist
                                            11-14-2025, 04:04 PM
                                          • pirati
                                            by pirati
                                            10-27-2025, 04:20 PM
                                            by Vesko356
                                            08-11-2023, 03:27 AM
                                          • jbonavita
                                            by jbonavita
                                            Some issues
                                            Things I tried
                                            04-29-2025, 09:38 PM
