  • Maxpower3
    Bad Veteran
    • Feb 2018
    • 1210
    • France
    #3381
    Originally posted by giokxan
    You mean writing default/original bios of this model,right? Not the initial one I read & save at beginning before patch?
    Any X1 Carbon bios bin would be ok or 20HQ model level compatibility needed?
    initial bios restore
    • giokxan
      • Sep 2024
      • 8
      • Turkey
      #3382
      i cant reach bios menu, because its getting stuck "Entering Setup..." after pressing F1
      • Maxpower3
        Bad Veteran
        • Feb 2018
        • 1210
        • France
        #3383
        post your initial bios
        someone will provide you with a cleaned or new one
        don't forget to indicate the serial number​
        • giokxan
          • Sep 2024
          • 8
          • Turkey
          #3384
          https://filetransfer.io/data-package/XXWffcco#link
          Cant upload as attachment, it doesnt allow .bin extension
          I put in link initial and patched one I did as instructed
          Its 20HQ - DX120 NM-B141
          • Maxpower3
            Bad Veteran
            • Feb 2018
            • 1210
            • France
            #3385
            with winrar (.rar) or .zip
            • giokxan
              • Sep 2024
              • 8
              • Turkey
              #3386
              attached now
              • Maxpower3
                Bad Veteran
                • Feb 2018
                • 1210
                • France
                #3387
                attached now
                try initial patched, see open setup
                • giokxan
                  • Sep 2024
                  • 8
                  • Turkey
                  #3388
                  your attachments are same with what I uploaded, do you mean I should try with initial (original bin with svp)?
                  What is open setup​
                  • Maxpower3
                    Bad Veteran
                    • Feb 2018
                    • 1210
                    • France
                    #3389
                    not same try
                    Cliquez sur l'image pour la voir en taille r?elleà  Nom : 		Nouveau Image bitmap.pngà Affichages :	3à Taille :		4,3 Koà ID : 			3464473
                    What is open setup
                    Bios menu
                    • giokxan
                      • Sep 2024
                      • 8
                      • Turkey
                      #3390
                      not same try
                      Bios menu
                      ok sorry ,saw it wrong. I will try now with that new patch
                      Does it matter if I keep SSD removed and attached during this trying?
                      • Maxpower3
                        Bad Veteran
                        • Feb 2018
                        • 1210
                        • France
                        #3391
                        try normal ,keep all
                        • giokxan
                          • Sep 2024
                          • 8
                          • Turkey
                          #3392
                          it worked, thanks man you are the king,
                          im in bios settings and spv disabled, i did "load setup defaults" as well. I closed computrace from enabled to as "permanently disabled" , do you know if extra steps needed further?
                          can I use laptop with this bios bin or I need to find clean default bin?
                          Thanks!
                          • Maxpower3
                            Bad Veteran
                            • Feb 2018
                            • 1210
                            • France
                            #3393
                            Thanks!
                            use this one, see if everything works ssd /lan etc ..
                            you lost the windows key, if necessary ask for it​
                            • Tokeri
                              • Sep 2024
                              • 6
                              • Sweden
                              #3394
                              Hi, I have used the search function copiously, and tried to follow a few leads in regards to getting a beep code of 0285, TCG-compliant functionality-related error (might be the TPM initialization failure). I've tried disabling TPM through powershell, tried autopatch script several times, and each time I try and boot with the modified BIOS I get a 0285 beep code. Using the dumped bios works fine. Any tips or knowhow on how to fix this? In UEFITool I found that the patched bios has a "FfsParser::checkProtectedRanges: Phoenix protected range [970000hA0000h] hash mismatch, opened image may refuse to boot" message on it, which the dumped bios does not have. I don't have the technical knowhow to calculate and patch in a new hash
                              • Maxpower3
                                Bad Veteran
                                • Feb 2018
                                • 1210
                                • France
                                #3395
                                https://www.badcaps.net/forum/troubl...40#post3345540
                                • Tokeri
                                  • Sep 2024
                                  • 6
                                  • Sweden
                                  #3396
                                  Many thanks
                                  • Tokeri
                                    • Sep 2024
                                    • 6
                                    • Sweden
                                    #3397
                                    So I tried following the guide, but hit an immediate roadblock. The hash range 970000h: DA0000h doesn't match with the hash ranges in the security tab in UEFITool:
                                    Code:
                                    FfsParser::checkProtectedRanges: Phoenix protected range [970000h: DA0000h] hash mismatch, opened image may refuse to boot
                                    Code:
                                    Phoenix hash file found at base 00F88018h
                                    Protected ranges:
                                    RelativeOffset: 000A0000h Size: D0000h
                                    Hash: 873294B3EBBB3329BBA6ABED75392C98891C38BAF1A934FD01B45132EE4162AD
                                    RelativeOffset: 00170000h Size: 430000h
                                    Hash: F346D4820EAC0C54FF7B7D342BBEDC1773C839936B53F366B50CE7CC92DEF45B
                                    RelativeOffset: 005A0000h Size: 40000h
                                    Hash: B8B7D897008E232E13A2982BA212ED9F7DE467424B2D4BCB266A032E0A64F13A
                                    RelativeOffset: 005E0000h Size: 10000h
                                    Hash: 34669869FF876E3118FE418D5359ECB71CC02B2132BD6F68CE12C406AA4AF6F0
                                    Unless I'm missing something from the tutorial?
                                    • Maxpower3
                                      Bad Veteran
                                      • Feb 2018
                                      • 1210
                                      • France
                                      #3398
                                      [QUOTE=Tokeri;n3465637]
                                      [QUOTE]
                                      Post your bios
                                      model and serial number to respect the rules
                                      • Tokeri
                                        • Sep 2024
                                        • 6
                                        • Sweden
                                        #3399
                                        [QUOTE=Maxpower3;n3465640][QUOTE=Tokeri;n3465637]
                                        Post your bios
                                        BIOS in attachment (unmodified)
                                        serial number PF-1QP25J
                                        Type 20L6
                                        • Maxpower3
                                          Bad Veteran
                                          • Feb 2018
                                          • 1210
                                          • France
                                          #3400
                                          [QUOTE=Tokeri;n3465647][QUOTE=Maxpower3;n3465640]
                                          Type 20L6
                                          try
                                            by Vesko356
                                            08-11-2023, 03:27 AM
                                          • jbonavita
                                            by jbonavita
                                            Some issues
                                            Things I tried
                                            04-29-2025, 09:38 PM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • Wahaz
                                            by Wahaz
                                            10-30-2023, 08:42 PM
                                          • Bloodhoundje
                                            by Bloodhoundje
                                            03-16-2024, 03:12 PM
