The laptop serial number, as required by the rules https://www.badcaps.net/forum/troubl...before-posting
I'm added 25Q80BL and MX25L25673G files to zip
Do I need to add more info?
For now I only have 3 flashes on power button when I connect power to laptop...Attached Filesif you find these attachements useful please consider making a small donation to the site
Patch not work
see https://www.badcaps.net/forum/troubl...04#post3337104
or read EC
Bad reading maybe
it worked before
Hello
Is it possible to clear the password to the bios using the auto patcher on the Lenovo ThinkPad E595 AMD Prosessor?
Type 20nf-s0th0q
s/n 2bf5q1
Hi ....its 2024 ...i have a lenovo x1 carbon gen 8 locked with Supervisor Password lock i am new to all this ....so how can i unlock it ....(dump my Bios , patch it and install the new patched bios) ? thanks in advance
TryAttached Filesif you find these attachements useful please consider making a small donation to the site
Thank You danito, but laptop is still dead. Nothing on the screen plus caps lock is on and fan is spinning too.Comment
Hey this patch is working perfectly for removing the bios so, I was wondering if I could use this to remove the computrace?
I did try but when I try to patch the file CMD opens and closes right away and shows no sign of completing the process.
Can you help me in this matter please. ThanksComment
Hi guys i need patched bios for P50sAttached Filesif you find these attachements useful please consider making a small donation to the site
RULES UPDATE for BIOS requests/offers AVOID BANNING, READ BEFORE POSTING
You MUST:- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
Try
Can anyone help how to generate the sha256 code and how to find the range in the HxD program please. Thank YouLenovo T495s 20QK
The first try didn't worked out and the bios beeped 5x times (wrong checksum). UEFITool revealed the wrong hash:
With the help of HxD i calculated the SHA256 of above range and replaced the old hash with the new one (search the old hash and replace it with the calculated one with help of HxD). A boot with manipulated checksum and patched BIOS binary worked. Supervisor password was removed. Thank you very much!Code:FfsParser::checkProtectedRanges: Phoenix protected range [BB0000h:F30000h] hash mismatch, opened image may refuse to boot RelativeOffset: 00BB0000h Size: 380000h Hash: 894F0EC4AAE777028ADC60150B10ECE724FC165E6530129DD6B56E45623192E6
Donation incomming (:
EDIT:
Output of patcher:
Code:Using UEFIReplace to inject 2 DXE drivers... [1/2] BootOption (GUID e0746c42-d3f9-4f8b-b211-1410957b9ff5) [2/2] LenovoTranslateService (GUID 826bcf56-bac4-43f4-8ea1-8cdf0a121abd) Looking for volumes to patch... [1/1] NVRAM_EfiSystemNvDataFvGuid (checksum 2609h): Found volume at offset 710000h (checksum 91f8h) Volume checksum does not match... Skipping.
My laptop is also blocked because I forgot my supervisor password.
It's an AMD P14s gen4 (serial PF54NMJB), I have another copy of exactly the same laptop.
My questions:
- I'm not sure how to dump/flash the bios, is it really a CH341A programmer that should be used?
- is it possible to read the bios of the laptop I know the password for and flash it on my other laptop? (they're exactly the same model).
- if not, what should I do?
Thanks for your helpComment
To flash the bios you need a programmer, not necessarily CH341A.Hello,
My questions:
We do not recommend this because each device has its own DMI and Windown key.↵
https://www.badcaps.net/donateComment
Thanks for your feedback, I ordered a CH341A programmer.
Concerning copying the bios from another laptop, I don't have an OEM windows key but serial numbers could be copied....
Would the following procedure work?
- dump the bios on my working laptop
- change the bios password
- dump the bios again
- do a diff to identify the area where the password is stored
- => modify this zone on the blocked laptop
I'm wondering whether there might be checksum or other issues, and if so, whether the autopatcher method might not be simpler.Comment
password is stored in ECThanks for your feedback, I ordered a CH341A programmer.
not possible unlock via bios dump for this generationComment
(edited, sorry I misread the thread)
if my understanding is correct, this means that for this model I need to work on dumping/flashing the EC and not the bios, i.e. with a program other than CH341A.
Can you confirm this?
If so, how do I dump the EC on this model?Comment
by macabookHello everyone,
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by cr4zychrissHello everyone,
I have successfully used a CH341A programmer and can read/write/verify both flash chips, but using my backups/extractions has failed to restore power. The root cause is likely a corrupted Intel Management Engine (ME) region or an incompatible EC/BIOS pairing. System & Hardware Details- Barebone / Chassis: TongFang GK7MRFR
- MB: MB: GK5MP5X V1.0 Prod :GK5MRFV10T04201310281
- Rebrand: PC Specialist
Today, 04:04 PM -
by piratiHello everyone,
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
- Loading...
