Hello everyone, I need help password t470S NM-B081
Guest
hopefully its not too late to ask for help lol,
thinkpad t480 specs:
Type 20L6-S5NY00
CPU Intel i7-8650U
bios version: 1.52
supervisor password-locked
i used both autopatchers posted by op, even tried pushing the tamper button and still got seven beeps (Virtual Mode Exception Error) and the device stayed on both times.
Flashing back to og bios fixes that. i've done hours of digging on this thread and have yet to find a solution, is it true that with my model a ch341a programmer won't work no matter what?Attached Filesif you find these attachements useful please consider making a small donation to the site
Good morning, very much a similar story to the previous poster, I've followed the steps meticulously, but I cannot get my T480 to POST after writing the patched BIOS. (Both phases of the python script appear to complete successfully.) I would get a beep code, however, though my phone app already lost it under recents. Google revealed this to be corrupt BIOS related. Fortunately, the machine works after restoring the initial backup. (There is an admin password) I hate to ask, but have gotten as deep into the troubleshooting rabbit hole as I think I can manage, but if this could be checked and fixed, I would be most thankful.
This is a T480 type 20L6S68t23
system unit serial: PF1F2FR3
system board serial: L1HF8AF0875Attached Filesif you find these attachements useful please consider making a small donation to the site
Guest
also, what the qr code says on the motherboard:hopefully its not too late to ask for help lol,
Type 20L6-S5NY00
CPU Intel i7-8650U
bios version: 1.52
1227716604265
43116M012OS
ET40 10G2
2H_2018-08-25
what it says under the fan on the motherboard:
ET480 NM-B501
Rev:1.0
2018-03-05
Made In China
Q198
how would i replicate
kordex35's success on my Type 20L6-S5NY00 W25Q128JV bios chip?
need Programming ec MECGood morning, very much a similar story to the previous poster, I've followed the steps meticulously, but I cannot get my T480 to POST after writing the patched BIOS. (Both phases of the python script appear to complete successfully.) I would get a beep code, however, though my phone app already lost it under recents. Google revealed this to be corrupt BIOS related. Fortunately, the machine works after restoring the initial backup. (There is an admin password) I hate to ask, but have gotten as deep into the troubleshooting rabbit hole as I think I can manage, but if this could be checked and fixed, I would be most thankful.
system board serial: L1HF8AF0875Comment
Hi guys, i canot patch my bin file. can somedody do it ? thanks
okAttached Filesif you find these attachements useful please consider making a small donation to the site
Thank you! I unlocked my laptop using your patch.HELLO,
I have a problem.
I managed to patched the bios, but I accidentally deleted the original bin file.
Is there a way to recover or do a vice versa to undo the patched, to be able to have the original bios.
btw, shift delete was used, the orig bin file is not in the recycle bin.
thank you.
attached the patched bin file.
laptop: thinkpad T440
type: 20B7
SN: PF-01MC28Comment
good evening team, I managed to use the patch on a lenovo L480 successfully
but I have problems with a lenovo E485 that does not work with this patch because it is an AMD platform
my question is what options do I have for the supervisor password romoval ?
Hello team has anyone managed to patch bios password for this laptop, if it is not possible is someone able to disable Absolute Persistence?
Lenovo Thinkpad T14s Gen 2i
HT4B1/HX3B0
NM-D362 Rev 4.0
SN:PC2EXE71
Type: 20WNAttached Filesif you find these attachements useful please consider making a small donation to the site
First off, I would like to say THANK YOU for this software.
I was able to successfully unlock my bios locked Thinkpad X1 Carbon Gen 6 (20KH) laptop.
For those of you with the same model, here are a couple of notes.
I started off using AsProgrammer 2.1.0 and was able to successfully read and backup the bios on the chip.
However, using this software I was unable to write the patched bios back on the chip.
After searching through this forum I came across a post recommending NeoProgrammer V2.2.0.8 and using that software I was able to write the patched bios to the chip.
I then used NeoPrgrammer to rewrite my original bios back on the chip after following the Autopatcher instructions.
So if you were having the same issue as I was, switching to NeoProgrammer software solved the problem.Comment
First of all thanks for this Script. I managed to pass my Bios password succesfully on a Lenovo T480s. The Problem i have now is that i have an extreme Bios time for about 60 seconds and more before i see the Lenovo splash screen.
After i enter the Bios i saw that there ist no version written in the line Intel ME Version. Does anyone has the same Problem and how to fix it ? Or is it neccesary to have the version written here ? Maybe it has something to do with the extended Bios Time.
thanks in advanceComment
Thanks for the work. The problem is this - I reset the password with the auto patcher - x380 yoga. It turns on in the BIOS, but nvme is not displayed. Live USB loads. After turning it off, it does not turn on for the second time. You need to disconnect all power supplies and CMOS/ Thanks in advance. Peace to all.Comment
Hey Y'all
Unfortunately I have not been able to get my patched BIOS to work on my X280.
The autopatch script seems to be working from the output with no errors (see attached image).
During boot there is no display, and I get beep code 0285 (TCG-compliant functionality related error / Might be TPM initialization failure).
I can re-flash my BIOS chip with the original unpatched BIOS and boot normally.
Would anyone be able to help or explain why it might not be working in my case?
Thanks.
Hardware Specifications |
Machine Type Model : Lenovo X280 20KF-CTO1WW
System Unit S/N : PC15ZW0H
System Board S/N : L1HF936010A
1 PhotoLast edited by Garry Larry; 12-08-2024, 12:18 AM.Comment
perform clean ,meHey Y'all
Thanks.
System Board S/N : L1HF936010AComment
can please patched? bios locked
DL470 nm-b021 rev 1.0Attached Filesif you find these attachements useful please consider making a small donation to the site
by macabookHello everyone,
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by cr4zychrissHello everyone,
I have successfully used a CH341A programmer and can read/write/verify both flash chips, but using my backups/extractions has failed to restore power. The root cause is likely a corrupted Intel Management Engine (ME) region or an incompatible EC/BIOS pairing. System & Hardware Details- Barebone / Chassis: TongFang GK7MRFR
- MB: MB: GK5MP5X V1.0 Prod :GK5MRFV10T04201310281
- Rebrand: PC Specialist
Today, 04:04 PM -
by piratiHello everyone,
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
- Loading...
