Try and reportAttached Filesif you find these attachements useful please consider making a small donation to the site
Please Help ! ive got 3 T470s from my old company and every have supervisor lock, and a T450s with same problem.... but the 450s i dont save the original file ! thats a big problem i think.. for the first T470s ive got the Dump Bios Bin file here , i tried to make a patched file but its not working so please help... if i try to patch the original file the window open and close i tried with pyhton 3.8 and the latest with same Result
Hello everyone. I will need your help please. I tried everything to unlock my L560 but the patched bios file will not work for me. The patching process was successfull but I only get a black screen and no fan noise after writing the patched file. After I write back the original bios file everything works fine - but with my bios password set.
Can anyone try to patch my original bios file correctly that you can find attached?
Thanks a lot for your help!Attached Filesif you find these attachements useful please consider making a small donation to the site
serial number?Hello everyone. I will need your help please. I tried everything to unlock my L560 but the patched bios file will not work for me. The patching process was successfull but I only get a black screen and no fan noise after writing the patched file. After I write back the original bios file everything works fine - but with my bios password set.
Thanks a lot for your help!----------------------------------------------------------------------------------------------------------------------------------------------------------------------
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
write this file and follow steps described in autopatcher:
[ HOW TO USE THE PATCH ]
STEP 1: Flash and replace current BIOS with the generated patch file
STEP 2: Boot the machine
STEP 3: Press ENTER/F1/etc. to enter BIOS settings
STEP 4: Enter any character when asked for Supervisor Password
STEP 5: Press enter when it shows Hardware ID
STEP 6: Press space bar 2x when asked
STEP 7: Turn off machine
STEP 8: Restore original BIOS
STEP 9: Reset BIOS settings to factory default
[ NOTES ]
When booting the patched BIOS you might have to:
- Hold the anti-tamper switch down the whole time (use tape)
- Remove the hard disk or replace it with a locked oneAttached Filesif you find these attachements useful please consider making a small donation to the site
Thanks a lot - but what is the anti-tamper switch? Is it something I need to do if I am not want to put on the backcover?
[ NOTES ]
- Remove the hard disk or replace it with a locked oneComment
Last edited by volinakis; 08-12-2024, 03:15 PM.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
let it run for 2 mins, it will restart few times with no image, just wait----------------------------------------------------------------------------------------------------------------------------------------------------------------------
Sorry for my late reply. I let it run for more than 10 minutes but the screen keeps black and no restart so far. I tried with power supply and also with battery.
It is so strange. It is not the first time that I managed to unlock a L560. Maybe my bios dump is corrupt? Or can it be something else?
you said that if you put back original backup it works. Only thing to do is to clean ME
It is so strange. It is not the first time that I managed to unlock a L560. Maybe my bios dump is corrupt? Or can it be something else?----------------------------------------------------------------------------------------------------------------------------------------------------------------------
Thats right. But after I write back the original dump, the bios password is still there.
i dont know how to clean ME. Do you have a tutorial?
i will give it another try tomorrow.
Thank you, Everything worked perfectly as described. No issues. What a life saver!!
Lenovo T480s Bios Ver. 1.57 02/27/2024 Model 20L8S5T700 CPU I5 8250UComment
Hi guys i have an issue with autopatcher (trying to remove bios password on T450).tried with python 3.9, but i get no patched file eventhough it says it shoudl be done.
I m joinig the orginal bios here, can someone help? thx a million
https://www.badcaps.net/donateComment
by macabookHello everyone,
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by cr4zychrissHello everyone,
I have successfully used a CH341A programmer and can read/write/verify both flash chips, but using my backups/extractions has failed to restore power. The root cause is likely a corrupted Intel Management Engine (ME) region or an incompatible EC/BIOS pairing. System & Hardware Details- Barebone / Chassis: TongFang GK7MRFR
- MB: MB: GK5MP5X V1.0 Prod :GK5MRFV10T04201310281
- Rebrand: PC Specialist
Yesterday, 04:04 PM -
by piratiHello everyone,
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
- Loading...
