Before I attempt to start this - I have a ch134a clip adapter set, and a M900 Tiny that I purchased on ebay to run as a small proxmox server. They sent it with an administrator password. I've contacted them and can return it for a refund, but I got a really great deal and am on a time table (I'm using this to run home assistant and some other things at my grandmother's house so we can keep an eye on her with cameras and other stuff in case she falls, and I'm supposed to leave here in a few days).
So, I'm trying to see if I can handle this myself, because if I have to send it back and wait for a replacement I'll have to extend my stay. I tried the typical things; changing jumpers for clear CMOS and maintenance mode, removing the battery, etc, but the password is clearly stored in non-volatile memory. I even contacted Lenovo, where I was told I had to change the board - but wait, I can't do that because they don't make them. Even if they did, it's not worth it.
So, yeah - should I spend some time trying to flash the BIOS (I see two BIOS chips on the board, oddly enough, and flashrom also reads two even when connected to just one) to resolve this, or is it a waste of my time?
Additionally, I can't see anything to download in the OP - are the files no longer available, or is it a user permission error because I have a new account?
Sorry to be asking for help immediately after signing up, I know that can get irritating.
Wow - after two days and fifty tries, suddenly it randomly just reset. I'd forgotten to take the clip off completely before a test boot and had jumped two of the BIOS chip pins, and it bypassed the password completely and let me set a new one. What are the odds?=Last edited by Extremity; 11-23-2023, 11:10 AM.Comment
Hello, I have a thinkpad T490 with intel i5 8365U, serial number: PF221WKE, i am trying to remove the supervisor password using a c341A programmer. I have a few question: i need to give power to the thinkpad while i am connected with the programmer?, if yes, i need to plug it to the charger; attach the battery or attach the cmos battery?. i already have installed the driver for the programmer and i have the sotware, but it dosnt recognise the thinkpad but it recognise the programmer. i am probably doing something wrong.pls helpComment
It's amazing that you set a password and you don't use a password, but there is a password in the eepromComment
hi....i want to unlock bios password for lenovo thinkpad t14 PF-2GWVH0 20S1...autopatcher doesn't work with me ...thanks
Attached FilesComment
Hi I own a Thinkpad X395 locked with a supervisor password. I can use it but it tries to boot from the network and all devices everytime and it takes sooo long to start, so I'd like to remove the previous owner's password and change the booting queue.
I'm having a problem downloading the tool. I can't see the attached file. All I can see is a screenshot of the attached files.
Having the tool would actually be a great start. :p
https://www.badcaps.net/filedata/fetch?id=2224617
this is it.
you can locate just directly below the image that Knucklegrumble attached to the post on the first page
Hello bosses. I have a bios passworded T440 that has been worked on by an engineer at somepoint but it ended up that the file has been tampered with. now the system doesnt come on again. Pleasea can i use another biosfile on the system. I wont mind if i can get a bios file that will work please. Thanks in advance.
Hello, i have a P50 20EQ SN:PC0GKBC7 and i tried the autopatcher but it doesn´t work. screen is black, the power lights on and the fans are spinning 5 sec then off. Is a power supply necessary to boot in to patched bios? I have only the battery and it works on the original bios.
ThanksAttached FilesComment
post here your dump, i try patch for test
https://www.badcaps.net/forum/troubl...-bios-passwordComment
PLS GUYS HELP ME WITH THE PATCH FILE OF THIS BIOS. TANK UAttached FilesComment
RULES UPDATE for BIOS requests/offers AVOID BANNING, READ BEFORE POSTING
You MUST:- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://badcaps.net/forum/showthread.php?t=88758 )
by macabookHello everyone,
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by piratiHello everyone,
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
- Loading...
