I'm really into hardware hacking, both for profit and fun, well they're one in the same. While this particular post piqued my interest. Don't expect me to be a 1-time poster.Comment
i have bios patch with key, help me unlock no key for bios lenovo e490 , Maxpower3 can you help me unlock, thanks! serinumber: Type 20N8-001BUS S/N: PF-1D6BV1 19/08Last edited by giangtt; 12-05-2023, 03:51 AM.Comment
try for test nokey (not sure)
or
try this with my patch
at restart : enter Bios setup with F1
need clear security chip
type two password blank
and load by default and save
restore original Bios afterLast edited by Maxpower3; 12-05-2023, 03:40 AM.Comment
does the patched with key file work on your PC?
try another one for testing.
I only made one modification to it, I'm surprised that it doesn't start at all
please patch nm-a931 t470 password sn PF-0WEGPCAttached FilesLast edited by ravenmx; 12-07-2023, 05:05 PM.Comment
Havn`t you tried the Autopatcher ? ,it does work with the t470
RULES UPDATE for BIOS requests/offers AVOID BANNING, READ BEFORE POSTING
https://www.badcaps.net/forum/troubl...sting?t=103570
You MUST:- Read BIOS guides, methods, resources and tools
- Try the method at BIOS guides, methods, resources and tools before requesting help
- Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
yes i download python, and download autopatcher, but not run on my pc, only make bios output and nothing else, the file not exist..on the same file rout. i tried the updates autopatcher and nothing sr.
I see that autopatcher is told works till gen 8th.
I have p53 (9th generation from what i was told) with supervisor password lock.
I ran the patch with the bios dump and got this:
"Using UEFIReplace to inject 2 DXE drivers...
[1/2] BootOption (GUID e0746c42-d3f9-4f8b-b211-1410957b9ff5)
[2/2] LenovoTranslateService (GUID 826bcf56-bac4-43f4-8ea1-8cdf0a121abd)
Looking for volumes to patch...
[1/1] NVRAM_EfiSystemNvDataFvGuid (checksum 2609h):
Not found... Skipping.
Done.
PATCH FILE: W25Q256JV_Lenovo_p50_lock_supervisor_PATCHED.BIN
Good luck."
Do i risk bricking the motherboard, did anybody else tried on P53 9th generation?
Can somebody please advise?
THank you!Last edited by raven4is; 12-12-2023, 01:14 AM.Comment
Good afternoon everyone, I have really tried to get the job done but I haven't succeeded. That's why I respectfully request if you could make the patch for me. Thank you so much.
Attached FilesComment
You MUST:- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://badcaps.net/forum/showthread.php?t=88758 )
Hello. Please help me patch it E15 Gen 4 (type 21E6 21E7) Laptops (ThinkPad) - Type 21E6
Attached Files1 PhotoComment
look above
You MUST:
Serial PF3ZVSGQ
try clean 00 or FFAttached FilesComment
I have a Lenovo X270 with a supervisor password that I want to remove.
This is what it looks like before starting:
I bought a CH341A programmer, and I have a soldering iron so I thought I'd give this a try.
The programmer came with a clip that can't be used because of adjacent components, but also a tiny board that you can use to solder the chip directly.
So I unsoldered the Winbond 25Q128FVSQ chip from the motherboard, and soldered it to the tiny board, it looks like this:
Made 2 backups using flashrom, like this:
flashrom --programmer ch341a_spi -r backup1.bin
This took 2-3 minutes.
Then I used the autopatcher.
Then I wrote the patched bios, like this:
flashrom --programmer ch341a_spi -w backup1_PATCHED.bin
This took 5 minutes.
Then I soldered the chip to the motherboard, but the computer wouldn't turn on anymore.
I pressed the button and waited a couple of second, but nothing.
Does it turn on normally with the patched bios?
I thought I may have soldered it wrong (a short circuit or something), so I proceeded to desolder it, clean the paste and try again.
And unfortunately one of the tracks in the PCB broke (pin 2), as can be seen in this photo:
Pin 3 has a tiny bit of solder above, but it's ok, please ignore that.
Anyway, I should not have attempted this without a reflow station, soldering paste and heat protective tape.
If only I knew where this track goes, I could possibly rescue it with a cable.
This is a long shot, but does anyone have any idea on how would I fix this?Comment
I feel with you, Pepitoski, the same has happened to me, too - but fortunately not on such a pricey item as in your case. That's why I did not even try to desolder the flash chip, but soldered tiny wirewrap wires to the pins... Anyway, the challenge is now to try to salvage your motherboard. As pin 2 is the DO line, it probably goes directly to the CPU. So my best bet would be to remove the lacquer covering the via that is (or was) connected to pin 2, solder a tiny wire to the via and connect that to pin 2. Actually, before soldering the chip again to the motherboard, I would use wires to connect all pins from the motherboard the the small PCB you got with the programmer, and only solder the chip to the motherboard, once the entire auto-patch procedure has successfully finished (remember that you need to reflash the original BIOS once the patched version has done its job). Good luck!
by macabookHello everyone,
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by piratiHello everyone,
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
- Loading...
