Try this file ...
And read this post ...
https://www.badcaps.net/forum/showpo...52&postcount=1Attached FilesPremium supporters get full download access and other benefits.
give a try and post reply
Kill the state in yourself and you will be free like a wind...Comment
Hello. I have a password on l460 too. I decided to reset it. soldered, subtracted(read attached) and wrote the lenovo L460_PATCHED file from here - https://www.badcaps.net/forum/showthread.php?t=104327 the motherboard no longer starts. I filled the proofread file back in and the computer will also no longer run. what could be the problem?Last edited by SMDFlea; 03-26-2023, 12:32 PM.Comment
I filled in a file - which should fit my motherboard according to the description. the same thing - When turned on, the power LED lit up and the cooler turned on for a short time. And nothing else, a black screen.Hello. I have a password on l460 too. I decided to reset it. soldered, subtracted(read attached) and wrote the lenovo L460_PATCHED file from here - https://www.badcaps.net/forum/showthread.php?t=104327 the motherboard no longer starts. I filled the proofread file back in and the computer will also no longer run. what could be the problem?Last edited by SMDFlea; 03-26-2023, 12:32 PM.Comment
Try this file ...Attached FilesPremium supporters get full download access and other benefits.
doneAttached FilesPremium supporters get full download access and other benefits.
What could be the reason that autopatch does not work. I follow the instructions on the first page.
I have Python installed.
When I move the bin to the autopatcher, the program window appears for 1 second and turns off.
I tried on Win 7 and 10.Comment
How would I save the existing UEFI BIOS image into a .bin file?
If I download it from Lenovo, the BIOS image has .fl1 and .fl2 files, and those don't seem compatible.
It is for an X1 Yoga Gen5Comment
by macabookHello everyone,
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by cr4zychrissHello everyone,
I have successfully used a CH341A programmer and can read/write/verify both flash chips, but using my backups/extractions has failed to restore power. The root cause is likely a corrupted Intel Management Engine (ME) region or an incompatible EC/BIOS pairing. System & Hardware Details- Barebone / Chassis: TongFang GK7MRFR
- MB: MB: GK5MP5X V1.0 Prod :GK5MRFV10T04201310281
- Rebrand: PC Specialist
by TopPopSorry for the long story. I have a Dell Latitude 5530 (i7) laptop (South Peak 15 MLK MB DDR4 203102-1 FK8VG$JA) with an admin BIOS password that I want to remove. Service Tag: HYKFPT3. Other than that the laptop worked OK.
I found a CH341A Black and went looking for the BIOS chip on the motherboard. After trying to read one chip that was a firmware chip but not the BIOS I think I found the BIOS chip labeled Winbond 25Q256JVEN. Altogether I think I found 4 different firmware chips in the laptop. The BIOS chip is a WSON8 6x8. I used the CH341A, NeoProgrammer, and a cheap pogo pin clip... -
by piratiHello everyone,
by DenizBu: https://pcsupport.lenovo.com/tr/tr/p...065tx/mp2br7d9
I have a Lenovo IdeaPad Gaming 3 16IAH7. When the device first arrived, there was no display at all.
I had the BIOS cleaned, but the issue was not resolved and there was still no image.
Later, I flashed a different BIOS dump from the same model. With this BIOS, the device boots and display works, but the GPU is not detected in the BIOS (RTX 3060 is missing).
After that, I tried to update the...-
- Loading...
