Need bios for asus GL702VM
  • ZOrd_Z
    • Jul 2013
    • 80
    • Portugal
    Hi.
    Need bios dump for asus GL702VM.
    Thank's....
  • lapfix
    • Mar 2020
    • 2649
    • my workshop
    Re: Need bios for asus GL702VM
    Better you post your old dump
    • sourcebf
      • Jul 2016
      • 431
      • N/A
      Originally posted by zord_z
      hi.
      Need bios dump for asus gl702vm.
      Thank's....
      try this
      • ZOrd_Z
        • Jul 2013
        • 80
        • Portugal
        Thank's. But none worked. Now i've got de power light blinking green twice.
        Any ideias?
        • peste
          • Dec 2016
          • 12397
          • ROMANIA
          Any ideias?
          post the original bios.
          • ZOrd_Z
            • Jul 2013
            • 80
            • Portugal
            That is the original BIOS.
            • servis_null
              • Oct 2014
              • 82
              • Croatia
              try this one
              • ZOrd_Z
                • Jul 2013
                • 80
                • Portugal
                Originally posted by servis_null
                try this one
                Thank's, but still the same.....
                  • 20481
                  try this bios.
                  • lapfix
                    • Mar 2020
                    • 2649
                    • my workshop
                    Try this and give feedback
                    • ZOrd_Z
                      • Jul 2013
                      • 80
                      • Portugal
                      It's working with a diferent EC. But now i've got a system boot password... Trying to solve it...
                      Thank's...
                      • razor_amd
                        by razor_amd
                        12-15-2020, 07:07 PM
                      • DynaxSC
                        by DynaxSC
                        06-14-2024, 03:49 PM
                      • jbonavita
                        by jbonavita
                        Some issues
                        Things I tried
                        04-29-2025, 09:38 PM
                      • Habble7
                        by Habble7
                        Suspected Cause:
                        Troubleshooting Attempts:
                        05-22-2025, 07:28 AM
                      • Anchar777
                        ASUS P1412CE need BIOS DUMP
                        by Anchar777
                        Sorry for creating a second post, I didn't understand how to fix the error in the message. I need help, laptop ASUS P1412CE (P1411CEA-EK0395X) SN: N4NXCV033901146. There was a failure during BIOS flashing, and the laptop stopped turning on. The original, non-working BIOS is attached. Unfortunately, I was unable to correctly generate the BIOS from what is presented on the Asus website. Help me make a dump. Thank you....
                        06-26-2025, 03:39 AM
