HP Probook 640 G2 bios dump
  • user_green
    • Jun 2018
    • 9
    here is a dump, I received it for my 640 g2 but I have another motherboard version, it was not good for me.
  • nasnus123
    • Jan 2016
    • 28
    • india
    Re: HP Probook 640 G2 bios dump
    i have dump check it ...... before copy this take backup
    • nasnus123
      • Jan 2016
      • 28
      • india
      Hi
      • nugi
        • Nov 2015
        • ireland
        Hello
        can you please provide what exacly is that part
        i cant find it
        • GValdameri
          • Apr 2020
          • 24
          • Brasil
          Slow Start HP 640 G2 Probook - Bios
          I understood.
          This is the original Bios file that was unlocked with the tool posted here on the forum.
          Could someone clean it for me?
          Thank you.
          • GValdameri
            • Apr 2020
            • 24
            • Brasil
            Re: Slow Start HP 640 G2 Probook - Bios
            I tried to use the "Intel Easy Clean Me" program, but it doesn't recognize my notebook's bios.
            • bachir2004
              • Feb 2015
              • 437
              • maroc
              [QUOTE=GValdameri;967761]I tried to use the "Intel Easy Clean Me" program, but it doesn't recognize my notebook's bios.
              It does not work,there are videos on youtube that show how to clean me.you must use flash image tool.
              • peste
                • 12872
                • ROMANIA
                try..
                • GValdameri
                  • Apr 2020
                  • 24
                  • Brasil
                  Originally posted by peste
                  try..
                  I'll try.
                  Thank you.
                  • GValdameri
                    • Apr 2020
                    • 24
                    • Brasil
                    try..
                    I did the test, but it doesn't start.
                    The LED on the numlock and capslock keys flashes 5 times
                    Attached is the updated bios that was working.
                    • peste
                      • 12872
                      • ROMANIA
                      remove the bios chip from the motherboard before reading or writing..if you use the clip you may have errors..use the chip adapter..search the internet for video tutorials, depending on the programmer you have.
                      try..
                      • GValdameri
                        • Apr 2020
                        • 24
                        • Brasil
                        try..
                        I identified that the bios chip I was using for testing was defective.
                        So I saved the new BIOS settings on the original chip.
                        I tested it with the two versions that you modified and with an older one that I had saved.
                        The notebook turned on, but the charging time is the same.
                        • GValdameri
                          • Apr 2020
                          • 24
                          • Brasil
                          I downloaded this bios from the HP website, but it is smaller than normal.
                          I believe it is only for updating.
                          How do I add information about my notebook to make it work?
                          • peste
                            • 12872
                            • ROMANIA
                            Made from the bios in the first post, and the update on the HP site.
                            • GValdameri
                              • Apr 2020
                              • 24
                              • Brasil
                              The loading time is the same.
                              It is stuck in the BIOS loading for 30 seconds and after you start to load the system.
                              Only a few times did it start quickly with the previous bios, but these were rare cases.
                              • peste
                                • 12872
                                • ROMANIA
                                try this too
                                • GValdameri
                                  • Apr 2020
                                  • 24
                                  • Brasil
                                  try this too
                                  Hello friends.
                                  I did the tests with these BIOS images, but it didn't work, the startup time is the same and ended up disabling some motherboard peripherals.
                                  So I decided to leave the original configuration.
                                  Thank you for your help.
                                    • 21022
                                    Originally posted by GValdameri
                                    Hello friends.
                                    Do you have an original bios backup, the one before you removed the password.
                                    • GValdameri
                                      • Apr 2020
                                      • 24
                                      • Brasil
                                      The first file is original.
                                      I just erased the password line manually.
                                      The rest is the same.
                                      • GValdameri
                                        • Apr 2020
                                        • 24
                                        • Brasil
                                        Attached are the two files for comparison.
                                        • Ahari
                                          by Ahari
                                          I...
                                          08-13-2025, 06:12 AM
                                        • Habble7
                                          by Habble7
                                          Suspected Cause:
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • haitham sharabati
                                          by haitham sharabati
                                          Hello engineers 😀,
                                          🔧 Device Info:
                                          - Model: HP 15-da2007ne
                                          - Product Number: 8XF55EA#ABV
                                          - Serial Number: CND0338P0D
                                          - CPU: Intel Celeron N4000
                                          💀 Problem:😅
                                          08-07-2025, 04:54 AM
                                        • Citymin
                                          by Citymin
                                          S/N : 5RNK9FFT70...
                                          08-05-2025, 05:12 AM
                                        • DynaxSC
                                          by DynaxSC
                                          11-17-2023, 10:56 AM
