HP Probook 640 G2 bios dump
    • 21936
    Re: Slow Start HP 640 G2 Probook - Bios
    Originally posted by GValdameri
    Attached are the two files for comparison.
    Try this bios ,it has NO dmi so you`ll need to use nbdmifit/HP BCU .
    • Claudiomfa
      • Nov 2015
      • 455
      • Portugal
      try this and report
      • Japanac
        • Aug 2014
        • 95
        • Serbia
        HP ProBook 640 G2 MPM
        HP ProBook 640 G2 MPM.How to solve this problem
        • peste
          • 13630
          • ROMANIA
          Re: HP ProBook 640 G2 MPM
          https://www.youtube.com/watch?v=9T57ktw8n3Y
          • Japanac
            • Aug 2014
            • 95
            • Serbia
            I've tried it but it won't
            • imranromi
              • Jan 2015
              • 1290
              • Pakistan
              #26
              Post here bios file.Use bios programmer.
              • Japanac
                • Aug 2014
                • 95
                • Serbia
                #27
                Here is the bios file
                • imranromi
                  • Jan 2015
                  • 1290
                  • Pakistan
                  #28
                  Before i told you for bios you use bios programmer.Need bios 16mb if you want solve this error.File is 16mb but not have data.
                  • Japanac
                    • Aug 2014
                    • 95
                    • Serbia
                    #29
                    Here I read it again
                    • peste
                      • 13630
                      • ROMANIA
                      #30
                      same thing ..remove the bios chip from the motherboard before reading or writing ..
                      • Japanac
                        • Aug 2014
                        • 95
                        • Serbia
                        #31
                        This was read with RT809H
                        • Japanac
                          • Aug 2014
                          • 95
                          • Serbia
                          #32
                          • peste
                            • 13630
                            • ROMANIA
                            #33
                            if the bios is ok, try entering the DMI information
                            • Japanac
                              • Aug 2014
                              • 95
                              • Serbia
                              #34
                              All I get when I boot from usb flash is this.
                              • peste
                                • 13630
                                • ROMANIA
                                #35
                                what motherboard code do you have ???
                                • imranromi
                                  • Jan 2015
                                  • 1290
                                  • Pakistan
                                  #36
                                  Try this.
                                  • huss584
                                    Hussein
                                    • Apr 2020
                                    • 230
                                    • Palestine
                                    #37
                                    try this
                                    HTML Code:
                                    [ATTACH]231495[/ATTACH]
                                    • ScorpioMan86
                                      • 94
                                      • South Africa
                                      #38
                                      HP 640 G2 Bios Request
                                      Hi Guys,
                                      I have a machine a customer brought in, HP 640 G2 with a corrupt bios.
                                      Mobo model number is circus-6050a2723701-mb-a02
                                      The machine was working fine and they did a bios update, screen went black and nothing else after that.
                                      caps lock blinks 5 times and fan runs at high speed.
                                      They did make a backup of the bios before starting the upgrade, but no auto recovery method seems to work.
                                      In the folder of the recovery bios, there is 3 files.
                                      The 0151 zip file contains 2 bios files N76 and N87, with date modified 2020/10/23
                                      The N76_0147 zip file contains N76 bios file, modified date on this one is the date of the failed bios update.
                                      The files are 9 216kb, the bios should be 16mb.
                                      I have already tried a few bios files without any luck.
                                      Can anyone please rebuild the bios ?
                                      • ScorpioMan86
                                        • 94
                                        • South Africa
                                        #39
                                        Re: HP 640 G2 Bios Request
                                        This bios worked https://www.badcaps.net/forum/showpo...7&postcount=12
                                        • klean
                                          • Feb 2020
                                          • 37
                                          • Albania
                                          #40
                                          hey hello boys i have a problem with 640 g2 , i lflash the image bios from forum its turn on my laptop but i dosent charge the battery nd it stay in commitet state behind i put serial etc.
                                          first is my original bios, 2 nd its the image i find in forum
                                          Last edited by klean; 12-15-2021, 04:47 AM. Reason: i forget to upload my atachment
                                          • Ahari
                                            by Ahari
                                            I...
                                            08-13-2025, 06:12 AM
                                          • mkdj
                                            by mkdj
                                            Dear all,
                                            10-19-2025, 04:41 AM
                                          • Habble7
                                            by Habble7
                                            Suspected Cause:
                                            Troubleshooting Attempts:
                                            05-22-2025, 07:28 AM
                                          • haitham sharabati
                                            by haitham sharabati
                                            Hello engineers 😀,
                                            🔧 Device Info:
                                            - Model: HP 15-da2007ne
                                            - Product Number: 8XF55EA#ABV
                                            - Serial Number: CND0338P0D
                                            - CPU: Intel Celeron N4000
                                            💀 Problem:😅
                                            08-07-2025, 04:54 AM
                                          • Citymin
                                            by Citymin
                                            S/N : 5RNK9FFT70...
                                            08-05-2025, 05:12 AM
