HP Probook 640 G2 bios dump
    • 20855
    Re: Slow Start HP 640 G2 Probook - Bios
    Originally posted by GValdameri
    Attached are the two files for comparison.
    Try this bios ,it has NO dmi so you`ll need to use nbdmifit/HP BCU .
    • Claudiomfa
      • Nov 2015
      • 455
      • Portugal
      try this and report
      • Japanac
        • Aug 2014
        • 94
        • Serbia
        HP ProBook 640 G2 MPM
        HP ProBook 640 G2 MPM.How to solve this problem
        • peste
          • Dec 2016
          • 12778
          • ROMANIA
          Re: HP ProBook 640 G2 MPM
          https://www.youtube.com/watch?v=9T57ktw8n3Y
          • Japanac
            • Aug 2014
            • 94
            • Serbia
            I've tried it but it won't
            • imranromi
              • Jan 2015
              • 1288
              • Pakistan
              #26
              Post here bios file.Use bios programmer.
              • Japanac
                • Aug 2014
                • 94
                • Serbia
                #27
                Here is the bios file
                • imranromi
                  • Jan 2015
                  • 1288
                  • Pakistan
                  #28
                  Before i told you for bios you use bios programmer.Need bios 16mb if you want solve this error.File is 16mb but not have data.
                  • Japanac
                    • Aug 2014
                    • 94
                    • Serbia
                    #29
                    Here I read it again
                    • peste
                      • Dec 2016
                      • 12778
                      • ROMANIA
                      #30
                      same thing ..remove the bios chip from the motherboard before reading or writing ..
                      • Japanac
                        • Aug 2014
                        • 94
                        • Serbia
                        #31
                        This was read with RT809H
                        • Japanac
                          • Aug 2014
                          • 94
                          • Serbia
                          #32
                          • peste
                            • Dec 2016
                            • 12778
                            • ROMANIA
                            #33
                            if the bios is ok, try entering the DMI information
                            • Japanac
                              • Aug 2014
                              • 94
                              • Serbia
                              #34
                              All I get when I boot from usb flash is this.
                              • peste
                                • Dec 2016
                                • 12778
                                • ROMANIA
                                #35
                                what motherboard code do you have ???
                                • imranromi
                                  • Jan 2015
                                  • 1288
                                  • Pakistan
                                  #36
                                  Try this.
                                  • huss584
                                    Hussein
                                    • Apr 2020
                                    • 226
                                    • Palestine
                                    #37
                                    try this
                                    HTML Code:
                                    [ATTACH]231495[/ATTACH]
                                    • ScorpioMan86
                                      • Dec 2016
                                      • 94
                                      • South Africa
                                      #38
                                      HP 640 G2 Bios Request
                                      Hi Guys,
                                      I have a machine a customer brought in, HP 640 G2 with a corrupt bios.
                                      Mobo model number is circus-6050a2723701-mb-a02
                                      The machine was working fine and they did a bios update, screen went black and nothing else after that.
                                      caps lock blinks 5 times and fan runs at high speed.
                                      They did make a backup of the bios before starting the upgrade, but no auto recovery method seems to work.
                                      In the folder of the recovery bios, there is 3 files.
                                      The 0151 zip file contains 2 bios files N76 and N87, with date modified 2020/10/23
                                      The N76_0147 zip file contains N76 bios file, modified date on this one is the date of the failed bios update.
                                      The files are 9 216kb, the bios should be 16mb.
                                      I have already tried a few bios files without any luck.
                                      Can anyone please rebuild the bios ?
                                      • ScorpioMan86
                                        • Dec 2016
                                        • 94
                                        • South Africa
                                        #39
                                        Re: HP 640 G2 Bios Request
                                        This bios worked https://www.badcaps.net/forum/showpo...7&postcount=12
                                        • klean
                                          • Feb 2020
                                          • 37
                                          • Albania
                                          #40
                                          hey hello boys i have a problem with 640 g2 , i lflash the image bios from forum its turn on my laptop but i dosent charge the battery nd it stay in commitet state behind i put serial etc.
                                          first is my original bios, 2 nd its the image i find in forum
                                          Last edited by klean; 12-15-2021, 04:47 AM. Reason: i forget to upload my atachment
                                          • Habble7
                                            by Habble7
                                            Suspected Cause:
                                            Troubleshooting Attempts:
                                            05-22-2025, 07:28 AM
                                          • DynaxSC
                                            by DynaxSC
                                            11-17-2023, 10:56 AM
                                          • solomost
                                            need bios dump for HP ProBook 640 G2
                                            by solomost
                                            HI I need bios dump for HP ProBook 640 G2 PLZ☺☺
                                            prblm: black screen caps lock blinking 5 times then fan spening
                                            CT: PFKCT00WB69310 REV : 1.20
                                            motherboard : HSB J Mv-6 94v-0 E89382
                                            03-21-2025, 06:22 AM
                                          • salim5566
                                            loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
                                            by salim5566
                                            Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
                                            06-26-2025, 03:25 PM
                                          • ktcar214
                                            Need help for HP ProBook 445R G6 Secure boot key removal from BIOS dump
                                            by ktcar214
                                            Hello.
                                            I tried to add a custom secure boot key (for secure booting Linux) to my bios, but after this, my laptop bricked. After adding secure boot key (via PowerShell) and enabling secure boot my laptop turns on, shows HP logo, and after 5 seconds it turns off and on, and it repeats forever.
                                            My goal is to either turn off secure boot or remove my custom key from BIOS dump.
                                            I'll attach my bios dump (version R79_011700) from my bios chip 25b127dsig, my keys (PK/KEK/db), and bios dump from another HP ProBook 445R G6(I found it on this forum. URL: https://www.ba...
                                            12-07-2021, 08:57 AM
