UX510UWK Bios
asus ux510uwk bios
by throwaway327ASUS ROG Ally X - (Handheld Gaming PC)
Model No: RC72LA
Serial No: SBNVKD001014459
I used a tool called 'Smokeless-UMAF' to access usually hidden settings in the bios. I tweaked one or two 'safe' things but made the mistake of tweaking a lot of settings under 'USB/Thunderbolt Configurations' when I didn't know what they did. For...-
Channel: BIOS Requests ONLY!
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
by intelgHello everyone, I am looking for help as I am struggling to remove lost BIOS Admin password on an HP EliteDesk G6 800 series desktop. I wanted to reset the vPro remote control IP kvm for homelab use.
Here is the hardware identification specs:
HP EliteDesk 800 G6 Desktop Mini PC
Intel(R) Core(TM) i5-10500 CPU @ 3.10GHZ 16384 MB RAM
BIOS ver S21 Ver. 02.05.01 01/05/2021
Born on date: 07/26/2021
SN MXL11841GN
SKU 3X8V9UCHABA
UUID 8116E79EF6FFE94DB0B98A3188270C5C
SYSTEM BOARD ID 8710
SYSTEM BOARD CT NUKBER PJLHQ0A8JF236L...-
by DynaxSCHi,
Usually on ASUS boards it worked...-
by oraganohey all, i did a silly thing and flashed bios to perfectly working board. None of the asus official download bios would work with ez flash. They all gave error saying not supported bios file. I tried using uefi tool to extract it to a bin file but then ez flash wouldnt even recognise it.
So, i used freedos and afudos with the aforementioned bin file i extracted and forced the issue. After bios reprogram, reboot and it was dead. Fans spinning but no post.
i have a bios writer and none of the .cap files from the official site work either. I just get one spin, then off, then all fans...-
10-17-2024, 02:53 AM -
- Loading...
