Supervisor password on Lenovo T490 and T490s
I have a lenovo laptop with bios password stuck. Can anyone who has done it tell me how to wire the jtag and am using a rt809h reader? -
Re: Supervisor password on Lenovo T490 and T490s
LENOVO THINKPAD
T490 T590 FT490 FT492 FT590 FP531 NM-B901 REV 1
this main supports all the models above and the MEC is also unlocked.Leave a comment:
hello
how i can use my r809h for t490 to read the ec? how i can connect it with this board?Leave a comment:
@mgjini
You don't have to edit anything, the programmer is properly connected as you could read the EC, the next step would be to reprogram the EC with the same file on post #48 (the reprogramming should take care of the EEPROM contents when the chip is erased prior to programming). After a successful programming then remove all source of energy, reconnect and that should have take care of the Supervisor Password, then you just need to use the Lenovo Maintenance Utility to type the DMI information.
Guy edited for me and I dint have to use dmi, mine is resolved thank you guysLeave a comment:
@mgjini
You don't have to edit anything, the programmer is properly connected as you could read the EC, the next step would be to reprogram the EC with the same file on post #48 (the reprogramming should take care of the EEPROM contents when the chip is erased prior to programming). After a successful programming then remove all source of energy, reconnect and that should have take care of the Supervisor Password, then you just need to use the Lenovo Maintenance Utility to type the DMI information.Last edited by AAAC; 10-05-2023, 10:29 AM.Leave a comment:
@mgjini
In my experience, when you erase the EC chip to reprogram it, is when the internal EEPROM contents are erased too, that EEPROM memory hold the Supervisor Password among other data like Model Number, Serial Number, TYPE, etc.
So depending on the programmer you are using the next step is to reprogram the EC chip with the exact file you saved from EC, then use the software utility (ThinkPad Maintenance Utility) that is in another post to program the ThinkPad DMI information.
I've verified the EC file you uploaded, version N2IHT39W, with the corresponding BIOS/EC update downloaded from Lenovo and it is an exact copy; I just had to delete the header from the EC update (first 32-bytes) and the tail starting from 40000h all the way to the end, then I could do the comparison of both files.Leave a comment:
So the story of programmer is I bought from eBay 2 years ago from eBay from some guy io programmer and when arrived I see the software doesn't work so after researching I had to get in touch with verytanov and paid for his software 50$ so I used verytanov and then jtag one user here has done great job providing the pictureLeave a comment:
@mgjini
can anyone remove the password from this mec1663 lenovo t490 please nm-b901Attached FilesLeave a comment:
Re: LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal
Nm-b901, t490 need patch file I7-8TH GEN CPU
[ATTACH]299532[/ATTACH]Leave a comment:
i have read the 290kb save it and rewrite it to the ec , i have done x1 gen4, x13, t14 t490 in same way , after that i used the lenovo tool to rewrite the motherboard infos
easy when you knowLeave a comment:
what you did with dump, to unlock password?Leave a comment:
Hi i have been trying to unlock with svod4 for weeks unfortunatly i have failed because svod can only read 288kb so decide to buy a rt809h this one read the full ec 290kb or more and it work at the first attemptLast edited by piernov; 01-05-2023, 05:22 PM.Leave a comment:
ineed this help aswell.please any oneLeave a comment:
Re: Can unlock t490 32mb please ,?
try this.Attached FilesLeave a comment:
Hey guys,
have a laptop here that has a supervisor Password (dump in Attachements).
Before i write the Serial NR.etc i wanted to say that strangely after flashing with 3 different Bios dumps and one from lenovos site
the laptop works but everytime it wants me to type a supervisor password i never set.
I thought the supervisor password is stuck in the ec bios but no it isn't either because after replacing the ec chip from one of another board it still has the supervisor password.
Anyway i wanted to ask what of the two chips is the ec bios because on the left...-
Channel: BIOS Requests ONLY!
by baaligogaGood day, everyone!
I'm encountering an issue with my Lenovo X1 Yoga 5th Gen laptop related to the BIOS supervisor password. I'm seeking assistance and guidance from the knowledgeable members of this community in resolving this problem.
I am no expert and cannot perform soldering or unsoldering of the chip from the board. Therefore, I attempted to use an EZP 2023 programmer with a clip to extract the BIOS bin file without removing the BIOS chip from the motherboard. The BIOS chip has the following letters imprinted on it: "Winbond 25Q80DVNIG 2026". I used the...-
by PusherHi, I bought a Lenovo P16 Gen1 from a private seller. The box was still originally sealed but when I want to enter the BIOS a supervisor password is required. Is it possible that the notebook was delivered by Lenovo with a password? What can I do to reset the password? Unfortunately, I no longer have contact with the seller.
by lrserviciosHi !
I have a Lenovo Thinkpad X12 Detachable 1st GEN with Supervisor Password - Type 20UV-S2Q100 Serial Number: PW-01NB9P - PW01NB9P
I attach Bios 2 Chip reading Bin, please can you try to clear it for me ?...-
by PascosHi all,
I bought a few Lenovo laptops from a batch, most of them having a 10th/11th gen Intel CPU, and I found out they all have a supervisor password enabled. I understand you would need soldering or a programmer to disable the supervisor password on these newer units, which I would like to prevent if at all possible. I have the suspicion that all the laptops are using the same password, though.
In the batch there is also an earlier T550. Is there a method available to retrieve the supervisor password from this model so it can be tested with the others?-
- Loading...
