Latitude 7280 bios
Latitude 7280 bios
Hello friends, I need help please, I have arrived at latitude 7280, with a very slow start, it takes more than 1 minute for the dell logo to appear, check the bios chip (uc5) and I was intervened then remove the bin and clean the region, but it does not give an image with the region it cleans me, I tried 2 files from other computers that I have but none gives an image Does anyone have any ideas? Will I have to change the firmware of the other chip (ut6)? I leave my original file if someone can review for me.Tags: None -
Re: Latitude 7280 very slow boot
try..Attached Filesif you find these attachements useful please consider making a small donation to the site
Every donation made will go towards server fees and maintenance costs. -
Try this and give feedbackAttached Filesif you find these attachements useful please consider making a small donation to the site
The service tag is for a Latitude 7380 .Comment
I have read other bios with live software serial number editor and it also shows that same service tag the lbe application is bad ...Comment
Every donation made will go towards server fees and maintenance costs.Comment
Dell Latitude 7280/7380/7480 with AMTAttached Filesif you find these attachements useful please consider making a small donation to the site
Ok, friends I appreciate your help I will summarize a little I have removed and installed the bios chip about 25 times, finally the problem was in the bios chip gd25q128, I replaced it with a windbond windbond 25q128, and the problem was solved, with the smdflea file turned on and asked for the servicetag when turning on, but it did not start from the bootmanager I did everything in the boot configurations I could even install the so, but it does not start, then I tried the second Plague file, this perfect fire and took the start the bootmanager right away only with the service tag of another computer, the same with the lapfix file, then I removed the file and with the serial number editor I changed the service tag for the one that is on the computer cover and it worked wonderfully, I sincerely thank you I was going crazy to all of you ...Comment
I need a bios for the Dell Latitude 7380, I tried the sunshine version but it turns my latop into a 7280, meaning when I enter the bios it says 7280 ... I don't know what the difference is between them
Can you help me?Comment
Very hard to fix it. I have the same problem. You cannot mixed the bioses in 7280 models. You need same dump as your original board. Check your board dell part number and need exact the same part numbered dump to fix it. I have solved mine but was not as easy fix. If you have the correct dump you need to clean ME with the correct CSME 11 version.
You cannot mixed the xhip content also, I mean you need dump from an identical chip model also. There are extremely rare on the net dumps from latitude models. Lot of different revisions...Comment
Re: Latitude 7280 bios
Hello.
Can any help me remove the Admin Password J5N0GH2-E7A8
Many thanks in advance !Attached Filesif you find these attachements useful please consider making a small donation to the site
DELL Latitude 7280 bios request
Appreciate BIOS binary for DELL Latitude 7280.
The flash is a Winbond 25Q128JVSQComment
Re: DELL Latitude 7280 bios request
Post your original corrupt bios file here.↵
​https://www.badcaps.net/donateComment
Dell latitude 7280 clear
hi every one can you clean me this bin bios of dell latitude 7280. thanks for helpAttached Filesif you find these attachements useful please consider making a small donation to the site
Re: Dell latitude 7280 clear
Here's your clean file.Attached Filesif you find these attachements useful please consider making a small donation to the site
all donations are welcome,
>>>>> click on this link to donate via PayPal. <<<<<
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
la-f311p rev 3.0 need bios dump
latitude 7280
service tag : F0BZ4H2
orginal dump no screenAttached Filesif you find these attachements useful please consider making a small donation to the site
Re: la-f311p rev 3.0 need bios dump
there are already threads open for Latitude 7280, next time use Search engine of this forum and DO NOT OPEN another thread!
try clean MEAttached Filesif you find these attachements useful please consider making a small donation to the site
by SathsulSo, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...-
Channel: BIOS Requests ONLY!
by mkdjDear all,
I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
This specification for the DELL Latitude 7280 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7280 boardview and 7280 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 7280...09-06-2024, 10:50 PM
This specification for the DELL Latitude 7280 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7280 boardview and 7280 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 7280...09-06-2024, 10:20 PM
- Loading...
