hp 250 g7 corrupt bios
Re: need help po to clean my bios backup thank admin
I can't find ME region on your bios file, I tried extracting the .exe file downloaded from HP homepage and got 6 .bin files (three 8MB files and three 16MB files). In these 8 MB files there is a 084AA.bin file without ME region ( same your bios file ) . I am confused. Maybe you should try the 8MB files one by one and see the results.
Attached Filesif you find these attachements useful please consider making a small donation to the site
https://www.badcaps.net/donateComment
Re: need help po to clean my LA-G073P bios backup
bios extracted from the HP site update, the laptop has six variants of your bios is 084AA
DMI 3C7000 - 3C8FFF
KEYWIN 3C5000 - 3C503FAttached Filesif you find these attachements useful please consider making a small donation to the site
Every donation made will go towards server fees and maintenance costs.Comment
Hp 250 g7 - la-g073p
Hi.
Need bios dump for this model HP 250 G7, board: LA-G073P BID: BID084AA
I Tried many bios and same problem, blinking 2.2 code caps lock
With my original file, show image for HP BIOS RECOVERY says inicializating and restart again.
Can help me? Thanks a lot.Attached Filesif you find these attachements useful please consider making a small donation to the site
Re: Hp 250 g7 - la-g073p
Try this file.Attached Filesif you find these attachements useful please consider making a small donation to the site
EC extracted from all bios at post #5Attached Filesif you find these attachements useful please consider making a small donation to the site
Re: HP 250 G7 BIOS No display
HP 250 G7 Notebook PCAttached Filesif you find these attachements useful please consider making a small donation to the site
There are 6 bios versions for this model. If the file you uploaded is exactly the original then it has code 084AA and it should work if the problem is just a corrupt bios. I've also attached the rest of the files for you to try, which don't have DMI info yet.Attached Filesif you find these attachements useful please consider making a small donation to the site
Hp 250 g7 bios need
Hello brothers,
i need bios bin file for hp 250 g7 mobo part no: Gpi52 la-j951p rev:1.0Attached Filesif you find these attachements useful please consider making a small donation to the site
Re: Hp 250 g7 bios need
tryAttached Filesif you find these attachements useful please consider making a small donation to the site
Re: hp 250 g7 corrupt bios
Good day boys, please help HP 250 G7 no display, Board number EPK50 LA-G073P
Attached is the Original BIOS BINAttached Filesif you find these attachements useful please consider making a small donation to the site
I solved it with this bin 084AAAttached Filesif you find these attachements useful please consider making a small donation to the site
by BloodhoundjeHi everyone,
I have been doing hardware repair as a hobby for some years now and recently decided to learn about repairing laptops as a fun challenge.
I managed to get my hands on a "HP Pavilion Gaming 15-ec2523nd" notebook that only shows a white power LED and doesnt respond to anything.
After initial testing I concluded the bios seems to be corrupted since all voltages are normal and there are no shorts. HP has a feature for a bios restore from USB with winkey+B for this model. This did not work.
I have desoldered the bios chip (GigaDevice...-
Channel: BIOS Requests ONLY!
by TripTopHi
i have dell latitude E7270 with following symptoms:
- takes long time to restart.
- sometimes powers on and then off
- sometimes while working it just dies,
From googling online bios clean could possible resolve this?
i was able to save bios and was going to try bios clean myself but get an below error when i drop it in ME analyzer.(unsure whether this sometimes occurs or could be due to bad/corrupt bios)
As ME analyzer gave me an error i just decided to write bios with a cleaned bios from E7270 bios post.
I reinstall...-
by macabookHello everyone,
🧩 Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
- External display (HDMI) shows
07-24-2025, 02:17 PM -
by cr4zychrissHello everyone,
I have successfully used a CH341A programmer and can read/write/verify both flash chips, but using my backups/extractions has failed to restore power. The root cause is likely a corrupted Intel Management Engine (ME) region or an incompatible EC/BIOS pairing. System & Hardware Details- Barebone / Chassis: TongFang GK7MRFR
- MB: MB: GK5MP5X V1.0 Prod :GK5MRFV10T04201310281
- Rebrand: PC Specialist
by grimacelordHello there.
I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
History:
1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
I searched for this error online and discovered...-
- Loading...
