Asus ux433fn
  • Lukosiukas
    • Jul 2018
    • 106
    • Lithuania
    Asus ux433fn
    Hello, need bios. Or maybe someone can remove from mine bios.
  • peste
    • Dec 2016
    • 12667
    • ROMANIA
    Re: Asus ux433fn
    post the original bios here.
    • Lukosiukas
      • Jul 2018
      • 106
      • Lithuania
      Re: Asus ux433fn
      Oh, sorry, my bad, here you go. i need password removed. Thanks in advance.
      • crowntoy99
        • Oct 2012
        • 264
        • india
        Re: Asus ux433fn
        try this
        • Lukosiukas
          • Jul 2018
          • 106
          • Lithuania
          Re: Asus ux433fn
          Originally posted by crowntoy99
          try this
          Dosent turn on.
          • crowntoy99
            • Oct 2012
            • 264
            • india
            Re: Asus ux433fn
            Dosent turn on.
            this file ok
            • Lukosiukas
              • Jul 2018
              • 106
              • Lithuania
              Re: Asus ux433fn
              After all the flashes, soldering, desoledering, computer dosent power on with orginal bios(original had a password), power led on, no cpu vcore, ram voltage, just 5v, 3v, 1.05v, 1.8v is available, suggestions?
                • 20729
                Re: Asus ux433fn
                Try this bios . You can rename it first to bios.bin ,that will stop the error message (post #5) , the CH341A software doesn`t seem to like anything with numbers, dots and dashes in the filename.Erase the bios first, then blank check,write, read and verify
                Edit: The bios at post #4 is corrupt.
                • Lukosiukas
                  • Jul 2018
                  • 106
                  • Lithuania
                  Re: Asus ux433fn
                  After flashing, still no reaction to power button.
                    • 20729
                    Re: Asus ux433fn
                    If you can`t boot even with the original pass locked bios you must have done something wrong.Dd you attach the LVDS cable after the battery. Have you tried with the battery,screen and all daughter boards connected .
                    • Lukosiukas
                      • Jul 2018
                      • 106
                      • Lithuania
                      Re: Asus ux433fn
                      yes, first step after opening laptop, disconnecting the battery and other power sources. tried only motherboard with keyboard, nothing.
                      Could the another ones bioses brick ite it8225vg ec controller ?
                      checked votages, i got :
                      19v on screen connector
                      1.05v
                      1.82v
                      3.30v
                      5.02v
                      EDIT :
                      Maybe someone got this motherboard by the hand? i need 1 value of resistor.
                        • 20729
                        Re: Asus ux433fn
                        What is the serial number on the base cover,and part numbers on the white/green stickers on the board .
                        • Lukosiukas
                          • Jul 2018
                          • 106
                          • Lithuania
                          Re: Asus ux433fn
                          there's no serial number on cover. sticker on motherboard says
                          PN:60NB0JR0-MB1421 (221) UX433FA 18407902
                          PT:K626NBCV00K6VPMB 69N15ZM14C11(01)
                          On mainbord printed :
                          UX433FN MAIN BOARD
                          REV. 2.2
                          • Lukosiukas
                            • Jul 2018
                            • 106
                            • Lithuania
                            Re: Asus ux433fn
                            1.05v
                            1.82v
                            3.30v
                            5.02v
                            EDIT :
                            I really need this resistor value, because he's missing from my board :/
                              • 20729
                              Re: Asus ux433fn
                              I answered your post in the schematic requests , No schematics,no boardview available .
                              • deepspace
                                • Mar 2015
                                • 11
                                • Slovakia
                                Re: Asus ux433fn
                                I have the really same problem, UX433FN, locked bios, reflashed / NTB power on without video. Put back originbal locked bios / NTB powered without video.
                                Its possible brick EC with bad Bios flash ?
                                PCB picture in attachment, (broken trace from SPICLK repaired ). I have missing component asked in previous question too..
                                Thanks Martin
                                • M4n0l0307
                                  • Nov 2020
                                  • 164
                                  • Colombia
                                  Re: Asus ux433fn
                                  Working ! Thanks Friend
                                  • ali.soltan
                                    • Nov 2023
                                    • ormia
                                    please working bios ux433fn uma
                                  • grimacelord
                                    by grimacelord
                                    07-10-2025, 02:52 PM
                                  • jbonavita
                                    by jbonavita
                                    Some issues
                                    Things I tried
                                    04-29-2025, 09:38 PM
                                  • tlindi
                                    Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
                                    by tlindi
                                    Sublect line continuation: ... Jaguar IDS PC aka Panasonic
                                    Ack
                                    Ack
                                    01-30-2025, 04:26 AM
                                  • lrouw84
                                    by lrouw84
                                    Hi there,
                                    01-28-2023, 01:31 PM
                                  • snpetit
                                    Asus FA706IH Bios Password remove
                                    by snpetit
                                    i need some help :-/
                                    i deleted in Bios the Admisnistrator password with old password, but after it didn't allow me to modify the User password. Now i can't boot, enter the bios or do anything. It asking at boot for password, old password don't work...
                                    Could you please remove all password related stuff from this bios. A hate Asus....
                                    Thanks in advance!...
                                    01-10-2025, 09:17 AM
