asus e203na rev 2.0 main bios required
  • tutututu
    • Jan 2016
    • 10
    • india
    any body help me asus E203na rev 2.0 bios need .
  • alas3376
    • Nov 2011
    • 382
    • BENIN
    Re: asus e203na rev 2.0 main bios required
    send your old one if can fix it
    • ndher86
      • Aug 2016
      • 40
      • Indonesia
      try this...
      • red_apache
        • Mar 2014
        • 9
        • indonesia
        bios tested by me..
        thx..........
        • seosan
          Ronaldo 035
          • Apr 2018
          • 27
          • japan
          Originally posted by ndher86
          try this...
          Work perfectly, Thank you very much !
          • kodox
            • Jul 2017
            • 329
            • Indonesia
            [HELP] Asus E203NA Serial Number Gone
            please help put serial number in bios, the bios chip in the unit was blank before i flashed it using file from https://www.badcaps.net/forum/showthread.php?t=82789 and the flashed file worked fine, but without serial number.
            since the bios chip blank (empty) so i think it useless to upload the dump with all "FF" inside it, but here's the serial number on the sticker: HBN0CX09H07245E
              • 21461
              Re: [HELP] Asus E203NA Serial Number Gone
              You can use asus block transmit tool, the short name is asus bt.exe . bt2.exe is used with newer boards .Search the forum,both have been posted somewhere.Alternatively you can edit the serial with a hex editor.
              • kodox
                • Jul 2017
                • 329
                • Indonesia
                ok thank's, i'll search it
                on which address i can add the serial number?
                  • 21461
                  the DMI can be copied from a backup (you dont have one) or from a dump that has DMI info in it then hex edit the serial/win key etc. Just use bt(2).exe to add it .
                  • kodox
                    • Jul 2017
                    • 329
                    • Indonesia
                    just noticed, the bios doesn't have a legacy or csm mode. using dos box on win10 setup result error when running bt(2).exe.
                    i think just had to wait for someone to upload their bios dump
                      • 21461
                      Sorry,i gave you wrong info about this particular bios The serial/DMI is in one of the partitions in the TXE firmware, it would be difficiult to add it or change it.I found a dump with the DMI in it,the problem is the TXE FW is initialised ,and cleaning it removes the DMI.Do you still have the laptop
                      • kodox
                        • Jul 2017
                        • 329
                        • Indonesia
                        ummm..... i'm not really understand what you've said , but still had the laptop on my desk
                        • dezgod14
                          • Dec 2021
                          try this...
                          thank you very much!!!, everything worked
                          • vcore service
                            • May 2024
                            • 7
                            • sumenep
                            BIOS Code Board ASUS E203NA REV 2.0 tested
                            • razor_amd
                              by razor_amd
                              12-15-2020, 07:07 PM
                            • jbonavita
                              by jbonavita
                              Some issues
                              Things I tried
                              04-29-2025, 09:38 PM
                            • throwaway327
                              by throwaway327
                              Model No: RC72LA
                              Serial No: SBNVKD001014459
                              06-18-2025, 05:52 PM
                            • lrouw84
                              by lrouw84
                              Hi there,
                              01-28-2023, 01:31 PM
                              ASUS VivoBook E203NA-FD084R Notebook E12 Specification for Upgrade or Repair
                              This specification for the ASUS VivoBook E203NA-FD084R Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E203NA-FD084R boardview and E203NA-FD084R schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                              09-06-2024, 06:20 PM
