asus e203na rev 2.0 main bios required
  • tutututu
    • Jan 2016
    • 10
    • india
    any body help me asus E203na rev 2.0 bios need .
  • alas3376
    • Nov 2011
    • 382
    • BENIN
    Re: asus e203na rev 2.0 main bios required
    send your old one if can fix it
    • ndher86
      • Aug 2016
      • 40
      • Indonesia
      try this...
      • red_apache
        • Mar 2014
        • 9
        • indonesia
        bios tested by me..
        thx..........
        • seosan
          Ronaldo 035
          • Apr 2018
          • 27
          • japan
          Originally posted by ndher86
          try this...
          Work perfectly, Thank you very much !
          • kodox
            • Jul 2017
            • 329
            • Indonesia
            [HELP] Asus E203NA Serial Number Gone
            please help put serial number in bios, the bios chip in the unit was blank before i flashed it using file from https://www.badcaps.net/forum/showthread.php?t=82789 and the flashed file worked fine, but without serial number.
            since the bios chip blank (empty) so i think it useless to upload the dump with all "FF" inside it, but here's the serial number on the sticker: HBN0CX09H07245E
              • 22026
              Re: [HELP] Asus E203NA Serial Number Gone
              You can use asus block transmit tool, the short name is asus bt.exe . bt2.exe is used with newer boards .Search the forum,both have been posted somewhere.Alternatively you can edit the serial with a hex editor.
              • kodox
                • Jul 2017
                • 329
                • Indonesia
                ok thank's, i'll search it
                on which address i can add the serial number?
                  • 22026
                  the DMI can be copied from a backup (you dont have one) or from a dump that has DMI info in it then hex edit the serial/win key etc. Just use bt(2).exe to add it .
                  • kodox
                    • Jul 2017
                    • 329
                    • Indonesia
                    just noticed, the bios doesn't have a legacy or csm mode. using dos box on win10 setup result error when running bt(2).exe.
                    i think just had to wait for someone to upload their bios dump
                      • 22026
                      Sorry,i gave you wrong info about this particular bios The serial/DMI is in one of the partitions in the TXE firmware, it would be difficiult to add it or change it.I found a dump with the DMI in it,the problem is the TXE FW is initialised ,and cleaning it removes the DMI.Do you still have the laptop
                      • kodox
                        • Jul 2017
                        • 329
                        • Indonesia
                        ummm..... i'm not really understand what you've said , but still had the laptop on my desk
                        • dezgod14
                          • Dec 2021
                          • 1
                          try this...
                          thank you very much!!!, everything worked
                          • vcore service
                            • May 2024
                            • 7
                            • sumenep
                            BIOS Code Board ASUS E203NA REV 2.0 tested
                            • razor_amd
                              [TUTORIAL] fix asus bios with bios from asus web support (by razor_amd)
                              by razor_amd
                              With ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
                              For example, you can have 3 similar ASUS motherboards, all being the same model, all of which will have different BIOS versions.
                              I will give you an example and my version of preparing BIOS from ASUS website and in the process I am always cleaning Intel ME while doing it so you have fully cleaned BIOS, no DMI data, no password, nothing.
                              This is the picture of 3 similar ASUS motherboards, all of them being X555LD...
                              12-15-2020, 07:07 PM
                            • pirati
                              by pirati
                              10-27-2025, 04:20 PM
                            • jbonavita
                              by jbonavita
                              Some issues
                              Things I tried
                              04-29-2025, 09:38 PM
                            • throwaway327
                              Asus ROG Ally X -RC72LA - changed hidden bios settings with 'Smokeless-UMAF', won't get past boot logo
                              by throwaway327
                              ASUS ROG Ally X - (Handheld Gaming PC)
                              Model No: RC72LA
                              Serial No: SBNVKD001014459
                              Hi all, I've spent the past week digging through the forums and guides to try correct my foolish mistake of changing hidden settings while tinkering around, and to be honest my heads overloaded so I'm hoping you'll be able to help.
                              I used a tool called 'Smokeless-UMAF' to access usually hidden settings in the bios. I tweaked one or two 'safe' things but made the mistake of tweaking a lot of settings under 'USB/Thunderbolt Configurations' when I didn't know what they did. For...
                              06-18-2025, 05:52 PM
                            • lrouw84
                              Asus vivobook s510ua bios changed to x510un
                              by lrouw84
                              Hi there,
                              I know there is somebody who can tell me what is happening with my laptop. For start, it is an asus vivobook s510ua with an asustek x510ua motherboard with an intel i5 7200u cpu and 16gb ram.. i have a screenshot from speccy before strange things started.. as you can see the laptop type and bios version x510ua.302.I don’t manually update the bios because i don’t like to having a bricked bios, i know what troubles that gives..
                              I did a fresh win 11 install, and after the automatic updates, windows rebooted and automatically started asus ez flash.....
                              01-28-2023, 01:31 PM
