Hp elitebook 840 g5 bios password
  • jiten1885
    • Apr 2021
    Thank you SMDFlea . Now I know the rules. and Thank you lapfix. I will try it and get back to you.
    • Bigherc07
      • Dec 2024
      • 13
      • France
      #342
      I've been preparing to unlock the BIOS password on my EliteBook 840 G5 for about a month. I got a T48 programmer along with a WSON8 8x6 adapter, but after removing the motherboard, I was surprised to find that the EC chip was actually in a WSON8 5x6 package.
      From what I've read on this forum, only the 16MB EC chip is compatible with RCUnlocker, and since I don't have an adapter for this chip, I'm stuck. Ordering a WSON8 5x6 adapter from AliExpress would mean waiting at least 20 days, so I was wondering—do I have any other options?
      Can I unlock the main BIOS instead, or is the EC chip the only way to remove the password? Any advice would be greatly appreciated!
      • hoaca388
        Badcaps
        • Jan 2022
        • 11794
        #343
        Post main bios file.
          • 20977
          Solder wires to the pads https://www.badcaps.net/forum/troubl...58#post3223258
          • Bigherc07
            • Dec 2024
            • 13
            • France
            #345
            Here is the main bios file. thank you in advance.
            • Bigherc07
              • Dec 2024
              • 13
              • France
              #346
              Should I post the motherboard’s serial number and model number? The serial number on the back of the laptop doesn’t match the one shown in HP System Information—I think the previous owner might have replaced the back cover. Should I reassemble the laptop and send you the serial number from HP System Information instead?
              • hoaca388
                Badcaps
                • Jan 2022
                • 11794
                #347
                Post the serial number on the back of the laptop.
                • Bigherc07
                  • Dec 2024
                  • 13
                  • France
                  #348
                  SN= 5CG8212H7V
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 11794
                    #349
                    SN= 5CG8212H7V
                    Unlocked
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 11794
                      #350
                      SN= 5CG8212H7V
                      Description : HP EliteBook 840 G5
                      Serial Number : 5CG8212H7V
                      SKU : 3TU06PA#ABG
                      Buil ID=17WWCSAT601#SABG#DABG
                      FEATUREBYTE_3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqgdhKhk.h4
                      • Bigherc07
                        • Dec 2024
                        • 13
                        • France
                        #351
                        SKU : 3TU06PA#ABG
                        thank you a lot. I really appreciate it. should I modify these before flashing your file?
                        • Bigherc07
                          • Dec 2024
                          • 13
                          • France
                          #352
                          Unlocked
                          On the first boot, it showed a mismatch error and mentioned that it copied information from the embedded controller. After restarting, the BIOS is still locked.
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 11794
                            #353
                            First boot press f10 apply factory defaults and restart, 2nd boot reset security settings to defaults and exit.
                            • Bigherc07
                              • Dec 2024
                              • 13
                              • France
                              #354
                              Before I could enter the BIOS to apply the default settings, an error appeared stating that there was a mismatch and that information had been copied from the embedded memory. After rebooting, the BIOS is still locked.
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 11794
                                #355
                                So there is still EC chip, look for chips with number 128 or 256, for example: 25Q256VDS..
                                • Bigherc07
                                  • Dec 2024
                                  • 13
                                  • France
                                  #356
                                  I can't read the EC chip because I don't have an adapter for it. It's the ISSI " ic25lp128 "
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 11794
                                    #357
                                    https://vi.aliexpress.com/item/10050...740007078757_1
Name:	2025-02-28 17_25_28-IS25LP128.pdf.png
                                    • Bigherc07
                                      • Dec 2024
                                      • 13
                                      • France
                                      #358
                                      Mine is wson8 6*5 and since I only have an adapter for wson8 6*8. I was asking if there is another way to unlock my bios.
                                      • hoaca388
                                        Badcaps
                                        • Jan 2022
                                        • 11794
                                        #359
                                        Only bios and EC, your computer can't be opened with bios then EC is the only way. Or you can solder wires to the extra pins to see.
                                        • Bigherc07
                                          • Dec 2024
                                          • 13
                                          • France
                                          #360
                                          Originally posted by SMDFlea
                                          I solder wires to these pads. right?
                                          • traxformania
                                            TONGFANG "GM7TG7P" Bios Password Problem?
                                            by traxformania
                                            I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
                                            But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
                                            I'm trying to reset my bios without success.
                                            I tried :
                                            -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                            11-15-2023, 07:32 AM
                                          • Nopslide
                                            HP Omen 15-dh0052nf power-on & bios password
                                            by Nopslide
                                            Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
                                            My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
                                            Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
                                            04-01-2024, 04:27 PM
                                          • BlackVisor
                                            How to Decode BIOS password for RedmiBook Pro15 2022 6800H
                                            by BlackVisor
                                            RedmiBook Pro 1542022 6800H
                                            SKU: TM2113-39463
                                            Model Number: RMA2204-AB
                                            CMIIT ID: 2022AP1835
                                            SN: 39463/22WD01355
                                            BIOS version: RMARB5B0P1010 20230628
                                            1. I bought this laptop from flea market, and the seller said that he had never set a password, however here is a password required when pressing F2 to enter BIOS.
                                            2. And after entering incorrrect password 3 times, there is no any useful information like "recovery code"
                                            3. I used universal bios backup tool, and dumped 8MB bin file, but hex code after "SystemSupervisorPw" is...
                                            01-14-2024, 06:35 AM
                                          • RMDUiFT
                                            Should I buy a Lenovo Thinkpad E495 with bios password?
                                            by RMDUiFT
                                            Good day. I apologize if I posted this in the wrong topic. I saw somebody selling a Thinkpad E495 with a Ryzen 3500U CPU near me. In the pictures the laptop is running windows 10. I contacted the seller and asked a few questions about upgradability and if it has a bios password on it. He confirmed it has a bios password. I searched through the forum, I found a guide regarding removing the bios password using the autopatcher, I also found a thread with the e495 where people requested help with unlocking the bios password.
                                            I have a few questions:
                                            • If I would buy this laptop and have
                                            08-25-2024, 09:00 AM
                                          • intelg
                                            HP Elitedesk 800 G6 lost BIOS admin password
                                            by intelg
                                            Hello everyone, I am looking for help as I am struggling to remove lost BIOS Admin password on an HP EliteDesk G6 800 series desktop. I wanted to reset the vPro remote control IP kvm for homelab use.
                                            Here is the hardware identification specs:
                                            HP EliteDesk 800 G6 Desktop Mini PC
                                            Intel(R) Core(TM) i5-10500 CPU @ 3.10GHZ 16384 MB RAM
                                            BIOS ver S21 Ver. 02.05.01 01/05/2021
                                            Born on date: 07/26/2021
                                            SN MXL11841GN
                                            SKU 3X8V9UCHABA
                                            UUID 8116E79EF6FFE94DB0B98A3188270C5C
                                            SYSTEM BOARD ID 8710
                                            SYSTEM BOARD CT NUKBER PJLHQ0A8JF236L...
                                            11-03-2023, 02:05 AM
