Hp elitebook 840 g5 bios password
  • deeptenk
    • Sep 2023
    • 10
    • Belarus
    #261
    Originally posted by SMDFlea
    RULES UPDATE for BIOS requests/offers AVOID BANNING, READ BEFORE POSTING
    RCUnlocker can delete computrace lock? Sorry, this is my first time encountering this. The laptop was blocked for organization; the laptop was scrapped. I was able to fix it, it did not turn on, but I see a blockage when installing windows.
    mb: computro 6050a2945601-mb-a01(1a)
    HP Elitebook 840 G5
    sku 2FA66AV
    UID 9B7337C7-0033-9973-5E10-38362DDAF283
    BIOS Q78 ver. 01.22.00 09/15/2022​
    sn 5CG83260G2
    • hoaca388
      Badcaps
      • Jan 2022
      • 12073
      #262
      HP Elitebook 840 G5
      sku 2FA66AV
      sn 5CG83260G2
      Install windown 10 home.
      • rex98
        • Feb 2023
        • 1287
        • Mandaue CEBU, Philippines
        #263
        HP Elitebook 840 G5
        sku 2FA66AV
        sn 5CG83260G2
        upload your main bios. and serial number here.
        • deeptenk
          • Sep 2023
          • 10
          • Belarus
          #264
          I already did it, look up please. sn 5CG83260G2
          • minhdigital
            • Nov 2022
            • 762
            • Vietnam
            #265
            I already did it​, looj up please. sn 5CG83260G2
            Send to you
            • deeptenk
              • Sep 2023
              • 10
              • Belarus
              #266
              Originally posted by minhdigital
              Send to you
              What changes have you made?
              As I understand it, "Windows Autopilot" is sitting in my dumps.​
              • deeptenk
                • Sep 2023
                • 10
                • Belarus
                #267
                Send to you
                Many thanks to you. With the help of your dumps and BIOS Configuration Utility (SP100599), I won the battle with Windows Autopilot Lock. Everything works fine!
                • deeptenk
                  • Sep 2023
                  • 10
                  • Belarus
                  #268
                  No results. Only programming spi chips made effect.
                  • habmuku
                    • 5
                    • Italy
                    #269
                    Request for unlocking my bios:
                    HP EliteBook 840 G5
                    ProdID 2FA64AV
                    SN# 5CG9245ZLH
                    I tried HPUnlocker withous success (password is still there).
                    • rex98
                      • Feb 2023
                      • 1287
                      #270
                      HP EliteBook 840 G5
                      ProdID 2FA64AV
                      SN# 5CG9245ZLH
                      First boot press F10 reset bios to factory defaults, 2nd boot reset security settings to defaults.
                      search here bios config utility in forum in case you don' know.
                      Use BCU to fill these DMI INFO
                      Serial Number: 5CG84925QJ
                      Product Number: 2FA62AV
                      CT Number: PGWHN00WBBL7HY
                      Description: HP EliteBook 840 G5
                      build_id: 17WWCSBT602#SABU#DABU
                      Feature Byte: 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqgdhKhkjh.gD
                      MAC Address: E4-E7-49-20-66-B0​
                      • habmuku
                        • 5
                        • Italy
                        #271
                        Does not work (black screen). Just noted your product number differs from mine (don't know if this matters).
                        • rex98
                          • Feb 2023
                          • 1287
                          #272
                          the product number is extracted from your bin. upload the EC 16mb or use RC unlocker D.I.Y .
                          did you verify this main bios bin after reading?
                          ec is found at the back of the board you need to disassemble.
                          • habmuku
                            • 5
                            • Italy
                            #273
                            Sorry, I did something wrong, I attached the correct file now. Thanks for patience.
                            • rex98
                              • Feb 2023
                              • 1287
                              #274
                              Serial Number: 5CG9245ZLH
                              Product Number: 2FA64AV
                              CT Number: PGWHQ00WBCE59A
                              build_id: 17WWCSCT601#SUUZ#DUUZ
                              Feature Byte: 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfAfXhKhkj4jh.fR
                              MAC Address: 80-E8-2C-A1-5E-C5​0
                              in case your wondering about this DMI info its from your dump.
                              • habmuku
                                • 5
                                • Italy
                                #275
                                This worked! Thank you so much.
                                • nasserancien
                                  • Mar 2024
                                  • Morocco
                                  #276
                                  Originally posted by ashr88
                                  Thank you, I accidentally knocked this off. I've replaced it and now it's booted! Thank you.
                                  Hi . Me to i Los this resistor and i don't know his value
                                  • szakacsa195
                                    • Apr 2022
                                    • 45
                                    • Magyarország
                                    #277
                                    Please help me to remove BIOS password from attached dump (32MB). Patching this dump - as rex98 did in 274 - would be the best.
                                    HP EliteBook 840 G5
                                    SKU 2FA66AV
                                    SN# 5CG9313CSW
                                    Thanks for your help!​
                                    • rex98
                                      • Feb 2023
                                      • 1287
                                      #278
                                      HP EliteBook 840 G5
                                      SKU 2FA66AV
                                      SN# 5CG9313CSW
                                      only flash this main do not touch the EC.
                                      follow these instructions.
                                      First boot press f10 reset bios to factory defaults and exit, 2nd boot reset security settings to defaults.
                                      use BCU permanently disable the absolute there.
                                      here's your DMI info:
                                      Serial Number: 5CG9313CSW
                                      Product Number: 2FA66AV
                                      CT Number: PGWHT00WBCL3EX
                                      build_id: 17WWCSCT601#SABD#DABD
                                      Feature Byte: 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfXhKhkjh.d7
                                      MAC Address: F8-B4-6A-E5-D5-D1​
                                      • szakacsa195
                                        • Apr 2022
                                        • 45
                                        • Magyarország
                                        #279
                                        Great, it's perfect. Thanks for your help.
                                        Btw which tool do you use to extract machine specific info and to patch BIOS file?
                                        • rex98
                                          • Feb 2023
                                          • 1287
                                          #280
                                          there is no tool.
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • traxformania
                                            TONGFANG "GM7TG7P" Bios Password Problem?
                                            by traxformania
                                            I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
                                            But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
                                            I'm trying to reset my bios without success.
                                            I tried :
                                            -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                            11-15-2023, 07:32 AM
                                          • tlindi
                                            Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
                                            by tlindi
                                            Sublect line continuation: ... Jaguar IDS PC aka Panasonic
                                            >Read BIOS guides, methods, resources and tools
                                            Ack
                                            >Try the method at BIOS guides, methods, resources and tools before requesting help
                                            Ack
                                            >Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
                                            python ./main.py "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.BIN" --output-dir "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.txt"
                                            01-30-2025, 04:26 AM
                                          • Nopslide
                                            HP Omen 15-dh0052nf power-on & bios password
                                            by Nopslide
                                            Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
                                            My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
                                            Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
                                            04-01-2024, 04:27 PM
                                          • Wutru
                                            HP Elitebook 820 G4 BIOS repair assistance required
                                            by Wutru
                                            Hi guys,
                                            If someone would be able to provide some expertise, I'd be very grateful.
                                            BIOS Corruption - Cause
                                            So I managed to corrupt my machine by installing linux and enrolling custom secure boot keys. I did choose to enroll the Microsoft keys as well, to prevent any potential bricking due to 3rd party drivers from HP being signed with those keys.
                                            After doing that, and rebooting(it did boot, powerLED, fanspin etc.), the laptop did not give any video output on the LCD or video connectors. I think I was able to get in BIOS and trigger the beeper by pressing ESC....
                                            09-06-2025, 10:32 AM
