Lenovo P52 20M9 BIOS needed
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    Hello
    I am in need of a BIOS dump for a Lenovo P52 with Xeon CPU and NVIDIA graphics
    The model Number is 20M9-CTO1WW
    The computer was force shutdown while an X86_64 port of Android was booting, and the machine did not restart after. I suspect firmware corruption as the CPU power rails look okay
    Thanks!
    Follow the white rabbit.
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: Lenovo P52 BIOS needed
    That should still be under warranty.
    Get Lenovo to fix it. BIOS is not supposed to get corrupt merely by shutting down while it's booting an OS. (if it was performing a BIOS update that's something else though)
    • goontron
      5000!
      • Dec 2011
      • 4108
      • US
      It is out of warranty as of 10/19, sadly
      • piernov
        • Jan 2016
        • 4435
        • France
        Ah… Sorry I assumed it came with 3 years base warranty as all Thinkpads in Europe but I guess that's not the case in the USA. Really worth it to have more than 1 year warranty on such a high value product.
          • 20818
          Can you post your bios backup .
          • goontron
            5000!
            • Dec 2011
            • 4108
            • US
            Waiting on an spi programmer to arrive right now, but I will post after I have it dumped
            • goontron
              5000!
              • Dec 2011
              • 4108
              • US
              https://mega.nz/#!I8snwYaZ!e-kttFLMs...gIL3Br9iyyFLqA
              P52-MMX25L25.bin is the main BIOS chip
              P52_W25Q80.bin is the other small flash chip. Was connected upside down at first, so may have been damaged and the dump may be bad.
              Thanks!
                • 20818
                Try this bios, i`m unsure it will work though,can`t find a working bios dump to compare with.
                • goontron
                  5000!
                  • Dec 2011
                  • 4108
                  • US
                  Unfortunately no change.
                  I'm starting to suspect the CPU itself has failed as well.
                    • 20818
                    get in touch with lenovo and ask them if they`ll fix it for you,for free,there`s a major problem with the ME firmware updates on these
                    https://forums.lenovo.com/t5/ThinkPa...4347463/page/7
                    https://forums.lenovo.com/t5/ThinkPa...E/ta-p/4422995
                      • 20818
                      Another bios for you to try. I copied the ME firmware from the RecoverDisabledPlatform_12.0.35.1427_v2 folder, (downloaded from the second link above) into your bios, there`s no more error messages now from MEAnalyzer .
                      • goontron
                        5000!
                        • Dec 2011
                        • 4108
                        • US
                        Not even a fan spin with this one...
                          • 20818
                          last try .
                            • 20818
                            Another bios to try .
                            • goontron
                              5000!
                              • Dec 2011
                              • 4108
                              • US
                              No dice on either one
                              • Wahaz
                                by Wahaz
                                10-30-2023, 08:42 PM
                              • grimacelord
                                Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
                                by grimacelord
                                Hello there.
                                I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
                                History:
                                1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
                                I searched for this error online and discovered...
                                03-15-2023, 03:29 PM
                              • cyber16
                                Lenovo P1 g1 Type 20MD-002PUS "BIOS Help Needed"
                                by cyber16
                                Please I need help.
                                Quick rundown long story shorter, but still long winded.
                                I received this Lenovo P1 GEN 1 about a year ago from a business.
                                It was pretty much dead hit the power button and the LED on the power light would come on as would the keyboard back light a couple times and just shut off or go into high speed fan mode without life other than the power button led.
                                At that time it was still under warranty, I spoke to Lenovo and I was going to send it in to have them repair it.
                                Then late last fall my father-in-law suffered...
                                09-08-2022, 07:32 AM
                              • Joluvillas
                                Lenovo ThinkPad L15 Gen 1 i7 (20U4) Bios and EC dump needed
                                by Joluvillas
                                Hi all! I was reading on tutorials how to flash a bios to remove password from a bios, and I ended up reading the EC chip instead of the main bios chip, it only gave me a .bin file of 1,024kb, I learned later that that is the EC chip not the main bios chip (I should have read the tutorials here instead before attempting anything, my bad), I went to flash the original backup, the 1,024kb size file into the same chip and laptop is not powering up anymore. I may have screwed the chip or even the motherboard (Hopefully not), I am trying to see if there is a fix before I discard it. I had a couple...
                                06-18-2024, 10:35 PM
                              • baaligoga
                                Help needed in unlocking BIOS Supervisor password - Lenovo X1 Yoga 5th Gen
                                by baaligoga
                                Good day, everyone!
                                I'm encountering an issue with my Lenovo X1 Yoga 5th Gen laptop related to the BIOS supervisor password. I'm seeking assistance and guidance from the knowledgeable members of this community in resolving this problem.
                                I am no expert and cannot perform soldering or unsoldering of the chip from the board. Therefore, I attempted to use an EZP 2023 programmer with a clip to extract the BIOS bin file without removing the BIOS chip from the motherboard. The BIOS chip has the following letters imprinted on it: "Winbond 25Q80DVNIG 2026". I used the...
                                05-20-2023, 09:48 AM
