HP zbook 15 G2 bios locked (password)
  • bugmenot90
    • Jan 2020
    • 9
    • Parma
    Hi, I am new here and I need some help. Be patience
    I have 5/6 zbook 15 g2 that I bought by a stock but I didn't know that those nb had password on bios.
    I read that in this forum there are people (Magicians on my eyes) that know how to unlock it easly.
    Is here any of you who could explain to me what I have to do specifically?
    I know that you need my "bios dump", right?
    I read a guide from the HP website,where I should press Win+B(or V) and hold power for 3 seconds and some screen should appear. Tomorrow I will try to do some key combination as a test.
    If it's not too much trouble I need a step by step guide that explain how to do the "bios backup" that I will upload here
    Sorry for the inconvenience
  • RethoricalCheese
    • Mar 2013
    • 1519
    • Estonia
    Re: HP zbook 15 G2 bios locked (password)
    You need an SPI programmer like Ch341A or minipro. Then physically remove bios chip, attach to programmer and make a bios dump.
    If you don't feel like you are able to do that, try to find somebody who can.
    No use in trying any key combinations.
    • bugmenot90
      • Jan 2020
      • 9
      • Parma
      Oh! I understand. Thank you for the reply, I'll try to find this Ch341A or minipro or someone that know how to use it. May I update this post later for the news or I need to do a new one?
      Really, thank you for your patience
      • RethoricalCheese
        • Mar 2013
        • 1519
        • Estonia
        Just checked that model. You need a soic 8 clip aswell. Then maybe you don't even need to desolder the chip.
        Bios chip is right under bottom cover.
        Just reply in this topic if you have any more questions about the process.
        • bugmenot90
          • Jan 2020
          • 9
          • Parma
          Ok, It should be the one near the RAM slot, I think.
          I'll looking for the programmer then I will give you news on this topic.
          Thank's for the moment
          • bugmenot90
            • Jan 2020
            • 9
            • Parma
            I finally did it.
            Here the .bin file and a .txt with infos (if necessary)
            Really, thank's a lot for the patience and the help Soon I'll upload the others locked bios by the other 4 zbook with the lock
            • RethoricalCheese
              • Mar 2013
              • 1519
              • Estonia
              Now follow this first post: https://www.badcaps.net/forum/showthread.php?t=79956
              Ignore the mazzif part, this wont work on your model.
              • bugmenot90
                • Jan 2020
                • 9
                • Parma
                sorry for the long wait. but for work reasons I had to pause the unlocking of the famous 5 zbooks that I own. Today I tried to save the bios, I used the tool to create the _unlocked file, but it gives me an error just before the writing phase. (I will attach photos to make my situation clearer)
                These are the steps I do, then tell me if I do everything correctly.
                1. I assembled the ch341a and connected the clamp on the bios chip. (1-2-3-4)
                2. I used ubuntu to recognize the programmer and chip model. (5)
                3. I used windows to read the bios and save it. (6)
                4. Then I should have used HPunlocker to generate the bios_unlocked file, but for commitments I had to leave the operation on hold.
                5. when I went home, I placed the clamp on the chip again, reread the chip with this result (7)
                I tried again and again to reposition the caliper but the chip was no longer read in any way, neither in ubuntu. what will i have done wrong?
                • Vesko356
                  VIP Moderator
                  • Aug 2018
                  • 4386
                  • Bulgaria 🇧🇬
                  Check the connection between the wires and the soic clip with the multimeter, the wires are very thin and it's possible some of the wires to be unsoldered from the clip end. I found two in mine clip unsoldered after a not so much use - it's just a cheap crappy clip.
                  Become a Badcaps supporter
                  Thanks to all supporters.​
                  • RethoricalCheese
                    • Mar 2013
                    • 1519
                    • Estonia
                    Did you remove battery and connect charger to laptop while programming?
                    • bugmenot90
                      • Jan 2020
                      • 9
                      • Parma
                      I had considered buying backup clips, I think I'll try again when they arrive
                      • bugmenot90
                        • Jan 2020
                        • 9
                        • Parma
                        no, actually I worked without battery and power charge. can it be due to that?
                        • RethoricalCheese
                          • Mar 2013
                          • 1519
                          • Estonia
                          yes, HP needs charger connected. And I usually disconnect battery.
                          Either just connect charger and then clip or..
                          connect charger, turn on laptop, turn off laptop and then connect clip.
                          It depends on your programmer which one works.
                          • bugmenot90
                            • Jan 2020
                            • 9
                            • Parma
                            I will try this method too and I will let you know if It works
                            Thanks for your Unlimited patience
                            • hopey
                              • Aug 2019
                              • 5
                              Hello together,
                              I followed the post for reading out the bios (bought the same programmer with clip). I tried it by reading out using flashrom on linux. I also used the method with disconnected battery and plugging in power before reading (that was the only chance to read something at all).
                              The problem is, that I was not able to read the same binary twice. So I'm not convinced to have the correct data.
                              Could there be something I missed?
                              Thanks for your answers!
                              Matthias
                              • lapfix
                                • Mar 2020
                                • 2742
                                • my workshop
                                Originally posted by hopey
                                Hello together,
                                Matthias
                                Desoldered the bios .Those clips are crap ,use a SPI bios programmer,such as a CH341A, with a sop8 clip, to make a backup of your bios chip
                                • karthikdme88
                                  • Jul 2020
                                  • Qatar
                                  Originally posted by bugmenot90
                                  I finally did it.
                                  How i can open .bin file ???
                                  • peste
                                    • Dec 2016
                                    • 12959
                                    • ROMANIA
                                    use the HxD program
                                    • krawat274
                                      • Jun 2020
                                      • 53
                                      • Poland
                                      Hello together,
                                      Matthias
                                      Hello. Just dont use clip, its not 100% working method. The best way for me, that I would recommend you, is just solder chip to programmer module. Second (even best) way, is put chip in adapter, like socket. Than you dont need solder anything, just puted chip into SOIC socket adapter, checked if springs of adapter touched chip legs and that's all.
                                      • futadmytro
                                        • Aug 2020
                                        • 62
                                        • Сполучені Штати
                                        HP zbook 15 g2 password
                                        Hello! pleace help to unlock bios password
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • tlindi
                                          Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
                                          by tlindi
                                          Sublect line continuation: ... Jaguar IDS PC aka Panasonic
                                          Ack
                                          Ack
                                          01-30-2025, 04:26 AM
                                        • Nopslide
                                          by Nopslide
                                          04-01-2024, 04:27 PM
                                        • BlackVisor
                                          How to Decode BIOS password for RedmiBook Pro15 2022 6800H
                                          by BlackVisor
                                          RedmiBook Pro 1542022 6800H
                                          SKU: TM2113-39463
                                          Model Number: RMA2204-AB
                                          CMIIT ID: 2022AP1835
                                          SN: 39463/22WD01355
                                          BIOS version: RMARB5B0P1010 20230628
                                          1. I bought this laptop from flea market, and the seller said that he had never set a password, however here is a password required when pressing F2 to enter BIOS.
                                          2. And after entering incorrrect password 3 times, there is no any useful information like "recovery code"
                                          3. I used universal bios backup tool, and dumped 8MB bin file, but hex code after "SystemSupervisorPw" is...
                                          01-14-2024, 06:35 AM
                                        • outsider
                                          Panasonic FZ-G1 MK5 - BIOS password returning
                                          by outsider
                                          Hello
                                          I removed the BIOS password thanks to the help of one of the friends of this forum.
                                          https://www.badcaps.net/forum/troubl...61#post3637661
                                          The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
                                          06-17-2025, 12:51 AM
