HP ProBook 450 G3
  • dpanijan
    • Feb 2015
    • 5
    • Croatia
    #141
    Re: HP ProBook 450 G3
    Originally posted by skazide
    try this
    Unfortunatelly, not working and different versions on post screen and system informaiton screen, N78 Ver. 01.06 and N78 Ver. 01.60
    ... and "system is booting in Manufacturing Program mode, and serial is not correct.
    • peste
      • Dec 2016
      • 13434
      • ROMANIA
      #142
      try this..
      https://www.youtube.com/watch?v=9T57ktw8n3Y
      • dpanijan
        • Feb 2015
        • 5
        • Croatia
        #143
        Originally posted by peste
        I forgot to say, charging is still not working
        ... I thing I will deal with working BIOS, but will not upgrade it to last version.
        • skazide
          • Jul 2015
          • 143
          • morocco
          #144
          dmi injected try
          • Joztu
            • May 2022
            • 46
            • Nigeria
            #145
            Hello everyone, please I need a working bios file for HP 450 G3
            Board number: DAX63CMB6D1 REV D
            I've attached my old bios
            • loki1976
              • May 2023
              • 3
              • United Kingdom
              #146
              This might be late coming, but have same issue with forgotten bios password, laptop still operable but I can't install a new OS, modify an existing OS, run live cds etc. After researching the topic seems its 1, replacement motherboard, 2. desolder the bios chip, and either direct replacement, or place the old bios in a reader, dump the bios and using hex editor zero out the password and rewrite to bios, resolder into place. I'm wondering has anyone had any success using either DMIFIT and WNDMIFIT to create a smc.bin for this model. Apparently using the bios info, such as Serial number and UUID etc, you create a unique file for your laptop and it should reset the Bios. Attached is a guide HP had for employees on how to use these tools. Any help greatly appreciated
              • Vesko356
                VIP Moderator
                • Aug 2018
                • 4386
                • Bulgaria 🇧🇬
                #147
                Originally posted by loki1976
                This might be late coming, but...
                https://www.badcaps.net/forum/showth...60#post1226060
                Read the rules before posting:
                BIOS guides, methods, resources and tools
                Password removal by laptop brand
                Become a Badcaps supporter
                Thanks to all supporters.
                • loki1976
                  • May 2023
                  • 3
                  • United Kingdom
                  #148
                  Thanks for the reply. On the assumption that the SMC method was disabled through bios updates, would it not be true that in some cases, perhaps even my own, where the bios was not updated post 2019, that the SMC solution might indeed work?
                  • Vesko356
                    VIP Moderator
                    • Aug 2018
                    • 4386
                    • Bulgaria 🇧🇬
                    #149
                    Forget about smc.bin man, HP stopped providing it since 2019, no one here has the tool to generate smc.file file regardless of the bios version.
                    • loki1976
                      • May 2023
                      • 3
                      • United Kingdom
                      #150
                      I appreciate that. If there is a non-invasive solution that doesn't require soldering or replacing the motherboard, I'd like to thoroughly explore. But the tool to generate the SMC bin is available and I have it, It's called WNDMIFIT, which is explained in the pdf attached in my first post. This file/program was downloaded from this forum.
                      • Vesko356
                        VIP Moderator
                        • Aug 2018
                        • 4386
                        • Bulgaria 🇧🇬
                        #151
                        Enough off-topic! WNDMIFIT is not a tool for generating smc.bin files, and there is no other lazy method for unlocking the bios like password encryption from the dump for example or password generator because I expect you to ask that as well. In short "non-invasive solution that doesn't require soldering" does NOT exist for that model.
                        • mekvit
                          • Jun 2018
                          • 39
                          • nigeria
                          #152
                          Hp 450 g3 product information not valid
                          Hello, please i need help to remove product information not valid on HP 450 g3.
                          Motherboard number: DA0X63MB6H1 REV H,
                          I uploaded the bin file. THANKS.
                          • Nurshad
                            • Oct 2019
                            • 75
                            • bangladesh
                            #153
                            hp probook 450 g3 3 long beeps 2 short beeps Problem
                            Serial = 5CD625C81Q
                            AMD=GPU
                            bios help
                            • nilanthamaduranga
                              • Sep 2016
                              • 19
                              • srilanka
                              #154
                              thank you paste
                              its working well
                              • Kiurcher
                                • Sep 2023
                                • 3
                                Originally posted by jarek79
                                Thank you. It's working now!
                                So how did you use this .BIN file to successfully solve this issue? Is it dropped into the original firmware folder provided by HP? Is it apart of the BIOS update? How did you make it work?
                                I have the same issue. Looking to resolve it.
                                • Kiurcher
                                  • Sep 2023
                                  • 3
                                  Any takers on my question? I am curious as to what the process is that was taken for some in the room to solve their issues regarding the HP ProBook 450 G3.
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 12271
                                    #157
                                    Serial = 5CD625C81Q
                                    AMD=GPU
                                    bios help
                                    HP ProBook 450 G3 Notebook PC
                                    • hoaca388
                                      Badcaps
                                      • Jan 2022
                                      • 12271
                                      #158
                                      This is the content of the bios chip, you must use a programmer to write/read it.
                                      https://www.badcaps.net/forum/showthread.php?t=103526
                                      • Kiurcher
                                        • Sep 2023
                                        • 3
                                        Thank you for the reply. I will check the thread you provided so I can understand this process. Appreciate it.
                                        • sejid99412
                                          • Oct 2023
                                          • 3
                                          • vitez
                                          #160
                                          I have Hp 450 G3 motherboard DA0X63MB6H1 rev:H after flashing, my orange light comes on and does not respond to ignition, please help
                                          • Ahari
                                            by Ahari
                                            I...
                                            08-13-2025, 06:12 AM
                                          • Habble7
                                            by Habble7
                                            Suspected Cause:
                                            Troubleshooting Attempts:
                                            05-22-2025, 07:28 AM
                                          • studdy05
                                            Bricked HP Probook 450 G7 Bios questions
                                            by studdy05
                                            Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
                                            Ive got...
                                            07-08-2025, 09:24 PM
                                          • haitham sharabati
                                            [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                                            by haitham sharabati
                                            Hello engineers 😀,
                                            I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                                            🔧 Device Info:
                                            - Model: HP 15-da2007ne
                                            - Product Number: 8XF55EA#ABV
                                            - Serial Number: CND0338P0D
                                            - CPU: Intel Celeron N4000
                                            - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                                            💀 Problem:😅
                                            - Device shows “Administrator Password”...
                                            08-07-2025, 04:54 AM
                                          • Citymin
                                            by Citymin
                                            S/N : 5RNK9FFT70...
                                            08-05-2025, 05:12 AM
