HP ProBook 450 G3
  • dpanijan
    • Feb 2015
    • 5
    • Croatia
    #141
    Re: HP ProBook 450 G3
    Originally posted by skazide
    try this
    Unfortunatelly, not working and different versions on post screen and system informaiton screen, N78 Ver. 01.06 and N78 Ver. 01.60
    ... and "system is booting in Manufacturing Program mode, and serial is not correct.
    • peste
      • Dec 2016
      • 12371
      • ROMANIA
      #142
      try this..
      https://www.youtube.com/watch?v=9T57ktw8n3Y
      • dpanijan
        • Feb 2015
        • 5
        • Croatia
        #143
        Originally posted by peste
        I forgot to say, charging is still not working
        ... I thing I will deal with working BIOS, but will not upgrade it to last version.
        • skazide
          • Jul 2015
          • 142
          • morocco
          #144
          dmi injected try
          • Joztu
            • May 2022
            • 46
            • Nigeria
            #145
            Hello everyone, please I need a working bios file for HP 450 G3
            Board number: DAX63CMB6D1 REV D
            I've attached my old bios
            • loki1976
              • May 2023
              • 3
              • United Kingdom
              #146
              This might be late coming, but have same issue with forgotten bios password, laptop still operable but I can't install a new OS, modify an existing OS, run live cds etc. After researching the topic seems its 1, replacement motherboard, 2. desolder the bios chip, and either direct replacement, or place the old bios in a reader, dump the bios and using hex editor zero out the password and rewrite to bios, resolder into place. I'm wondering has anyone had any success using either DMIFIT and WNDMIFIT to create a smc.bin for this model. Apparently using the bios info, such as Serial number and UUID etc, you create a unique file for your laptop and it should reset the Bios. Attached is a guide HP had for employees on how to use these tools. Any help greatly appreciated
              • Vesko356
                VIP Moderator
                • Aug 2018
                • 4386
                • Bulgaria 🇧🇬
                #147
                Originally posted by loki1976
                This might be late coming, but...
                https://www.badcaps.net/forum/showth...60#post1226060
                Read the rules before posting:
                BIOS guides, methods, resources and tools
                Password removal by laptop brand
                Become a Badcaps supporter
                Thanks to all supporters.
                • loki1976
                  • May 2023
                  • 3
                  • United Kingdom
                  #148
                  Thanks for the reply. On the assumption that the SMC method was disabled through bios updates, would it not be true that in some cases, perhaps even my own, where the bios was not updated post 2019, that the SMC solution might indeed work?
                  • Vesko356
                    VIP Moderator
                    • Aug 2018
                    • 4386
                    • Bulgaria 🇧🇬
                    #149
                    Forget about smc.bin man, HP stopped providing it since 2019, no one here has the tool to generate smc.file file regardless of the bios version.
                    • loki1976
                      • May 2023
                      • 3
                      • United Kingdom
                      #150
                      I appreciate that. If there is a non-invasive solution that doesn't require soldering or replacing the motherboard, I'd like to thoroughly explore. But the tool to generate the SMC bin is available and I have it, It's called WNDMIFIT, which is explained in the pdf attached in my first post. This file/program was downloaded from this forum.
                      • Vesko356
                        VIP Moderator
                        • Aug 2018
                        • 4386
                        • Bulgaria 🇧🇬
                        #151
                        Enough off-topic! WNDMIFIT is not a tool for generating smc.bin files, and there is no other lazy method for unlocking the bios like password encryption from the dump for example or password generator because I expect you to ask that as well. In short "non-invasive solution that doesn't require soldering" does NOT exist for that model.
                        • mekvit
                          • Jun 2018
                          • 39
                          • nigeria
                          #152
                          Hp 450 g3 product information not valid
                          Hello, please i need help to remove product information not valid on HP 450 g3.
                          Motherboard number: DA0X63MB6H1 REV H,
                          I uploaded the bin file. THANKS.
                          • Nurshad
                            • Oct 2019
                            • 75
                            • bangladesh
                            #153
                            hp probook 450 g3 3 long beeps 2 short beeps Problem
                            Serial = 5CD625C81Q
                            AMD=GPU
                            bios help
                            • nilanthamaduranga
                              • Sep 2016
                              • 16
                              • srilanka
                              #154
                              thank you paste
                              its working well
                              • Kiurcher
                                • Sep 2023
                                • 3
                                Originally posted by jarek79
                                Thank you. It's working now!
                                So how did you use this .BIN file to successfully solve this issue? Is it dropped into the original firmware folder provided by HP? Is it apart of the BIOS update? How did you make it work?
                                I have the same issue. Looking to resolve it.
                                • Kiurcher
                                  • Sep 2023
                                  • 3
                                  Any takers on my question? I am curious as to what the process is that was taken for some in the room to solve their issues regarding the HP ProBook 450 G3.
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 11411
                                    • Viet Nam
                                    #157
                                    Serial = 5CD625C81Q
                                    AMD=GPU
                                    bios help
                                    HP ProBook 450 G3 Notebook PC
                                    • hoaca388
                                      Badcaps
                                      • Jan 2022
                                      • 11411
                                      • Viet Nam
                                      #158
                                      This is the content of the bios chip, you must use a programmer to write/read it.
                                      https://www.badcaps.net/forum/showthread.php?t=103526
                                      • Kiurcher
                                        • Sep 2023
                                        • 3
                                        Thank you for the reply. I will check the thread you provided so I can understand this process. Appreciate it.
                                        • sejid99412
                                          • Oct 2023
                                          • 3
                                          • vitez
                                          #160
                                          I have Hp 450 G3 motherboard DA0X63MB6H1 rev:H after flashing, my orange light comes on and does not respond to ignition, please help
                                          • Habble7
                                            by Habble7
                                            Suspected Cause:
                                            Troubleshooting Attempts:
                                            05-22-2025, 07:28 AM
                                          • DynaxSC
                                            by DynaxSC
                                            11-17-2023, 10:56 AM
                                          • solomost
                                            need bios dump for HP ProBook 640 G2
                                            by solomost
                                            HI I need bios dump for HP ProBook 640 G2 PLZ☺☺
                                            prblm: black screen caps lock blinking 5 times then fan spening
                                            CT: PFKCT00WB69310 REV : 1.20
                                            motherboard : HSB J Mv-6 94v-0 E89382
                                            03-21-2025, 06:22 AM
                                          • ktcar214
                                            Need help for HP ProBook 445R G6 Secure boot key removal from BIOS dump
                                            by ktcar214
                                            Hello.
                                            I tried to add a custom secure boot key (for secure booting Linux) to my bios, but after this, my laptop bricked. After adding secure boot key (via PowerShell) and enabling secure boot my laptop turns on, shows HP logo, and after 5 seconds it turns off and on, and it repeats forever.
                                            My goal is to either turn off secure boot or remove my custom key from BIOS dump.
                                            I'll attach my bios dump (version R79_011700) from my bios chip 25b127dsig, my keys (PK/KEK/db), and bios dump from another HP ProBook 445R G6(I found it on this forum. URL: https://www.ba...
                                            12-07-2021, 08:57 AM
                                          • grimacelord
                                            Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                                            by grimacelord
                                            This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                                            Motherboard model number: DA0PAMB46A1 REV: A
                                            Secondary motherboard model number: 0PAB
                                            SKU: 685K4UA
                                            Serial number is: 5CD3223BJP
                                            Recently reflashed this laptop with latest BIOS and once...
                                            05-07-2024, 08:06 AM
