hp 840 g6 6050A3022501-MB-A01
  • hoaca388
    Badcaps
    • Jan 2022
    • 11773
    #281
    Re: hp 840 g6 6050A3022501-MB-A01
    Originally posted by Dhaka Lab
    pls remove pass
    HP EliteBook 840 G6
    SERIAL : 5CG9493XZV
    SKU : 8NV12UC#ABA
    FEARTURE BYTE : 3X476J6S6b7B7H7M7R7W7m7saBaEapaqauawbUbhcAdUdpdqfPhKhkj4jhk8.E7
    BUILD ID : 19WWCFBT601#SABA#DABA
    • SD tech
      • May 2017
      • 14
      • ghana
      #282
      pls rebuild this bin for me, it is corrupt
      • hoaca388
        Badcaps
        • Jan 2022
        • 11773
        #283
        ???????? Where's your *.bin file ?
        • ranzoo
          • Jun 2015
          • 17
          • algeria
          #284
          help elitebook 840 g6
          help to remove pass from this dump pls
          • ranzoo
            • Jun 2015
            • 17
            • algeria
            #285
            Re: help elitebook 840 g6
            the file
            • hardware1
              • Sep 2021
              • 2933
              • N/A
              #286
              the file
              Here's your Unlocked file, hope it works fine.
              Next time you can do it using RCUnlocker tool.
              all donations are welcome,
              • tato77
                • Apr 2022
                • 5
                • colombia
                #287
                hi can you remove password, I tried rc unlocker but show error using de 32mb flash
                hp elitebook 840 g6
                sn:5CG9270F7R
                BUILD: 19WWCFAT602
                FEATURE BYTE: 3X476J6S657B7H7M7Q7W7m7saBaEapagauawbUbhcAdQdUdpdafAgShkink8
                thanks
                • peste
                  • Dec 2016
                  • 12841
                  • ROMANIA
                  #288
                  hp elitebook 840 g6
                  sn:5CG9270F7R
                  BUILD: 19WWCFAT602
                  thanks
                  use RCUNlocker on the 16MB bios..
                  • tato77
                    • Apr 2022
                    • 5
                    • colombia
                    #289
                    need to do something on the 32mb flash?
                    • hardware1
                      • Sep 2021
                      • 2933
                      • N/A
                      #290
                      Just use RCUnlocker with your 16MB and see what will happen.
                      Be careful, your 32MB file not good, you should read it again before doing anything.
                      • andreyhobi
                        • Apr 2020
                        • ukraine
                        #291
                          • 20966
                          Read the posts above, use RCUnlocker on the 16MB backup
                          https://www.badcaps.net/forum/showthread.php?t=103526
                          • ciber.agus
                            • Aug 2019
                            • argentina
                            #293
                            Hola alguien me podria desbloquear los .bin por favor
                              • 20966
                              Read post #292
                              • munir100
                                • Dec 2018
                                • 180
                                • uae
                                #295
                                HI EVER ONE HERE IS hp 840 g6 bios can me clean this bios problem is nodispaly
                                • alfredposadas09
                                  • Aug 2020
                                  • 343
                                  • Philippines
                                  #296
                                  hello can someone remove computrace + bios administrator password thanks
                                  • user54321
                                    • Aug 2018
                                    • 5
                                    Re: HP 840 G6 Bios Password
                                    Hello Peste.
                                    How did you remove password?
                                    • alfredposadas09
                                      • Aug 2020
                                      • 343
                                      • Philippines
                                      #298
                                      i have sucessfully removed my password in hp 840 g6 by getting the bios from the website and flash 16mb and 32mb.. upload ur original bios here and I will unlock it for you
                                      • smallvhin
                                        • Jul 2015
                                        • 182
                                        • philippines
                                        #299
                                        help to unlock this file master.
                                        thanks in advance
                                          • 20966
                                          thanks in advance
                                          See post #294
