hp 840 g6 6050A3022501-MB-A01
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    #141
    Re: hp 840 g6 6050A3022501-MB-A01
    Originally posted by zalorpas
    However the starting address of the block to be overwrited seems to be different...
    Yes, it is.
    Starting address 226824 is OK for your dump.
    For some other dump it may be the same (as a pure coincidence) but it will most likely be at a different address.
    Become a Badcaps supporter
    Thanks to all supporters.​
    • zalorpas
      • Aug 2021
      • Spain
      #142
      Re: HP 840 G6 BIOS locked
      Thank you very much Vesko356 for your fast response and for the useful comments.
      So I flashed de 16 Mb BIOS with the file you sent me which actually coincided with the guess I had after looking this thread (everything ok) and also, following your wise advice, I had the 32 Mb BIOS chip unsolderded in order to read it and back up it.
      Unfortunately, the USB programmer didn't properly recognize the chip nor was able to read it saying "The chip is empty" (see images attached). I tryed several times changing the adapting PCB position but results were exactly the same. I had the chip resoldered again ... but same results
      So my guess is that for some reason either the 25Q256 chip has died or perhaps the programmer is failing (which seems somehow unlikely cause it presumably read, erase, write and verify the 25Q128 chip). So I will try to have both chips soldered back to the motherboard, reassamble the laptop and try. I have a bad feeling thou ... lol =/
      I'll report the results here but I have to travel tomorrow and I don't know when I will get to finish it.
      In case the chip is K.O. which is your advice?
      Thanks a lot.
        VIP Moderator
        • Aug 2018
        • 4386
        • Bulgaria 🇧🇬
        #143
        It's hard to damage the chip so easy (can only be damaged if soldered to the adapter in reverse polarity, in which case it can be damaged instantly, or can be overheated during desoldering), most likely it just can't be read by the programmer properly or it's not soldered as it should be to the adapter. Just put it back in place. it was a good idea to have a dump available from it just in case, but once you have difficulty with it it's not absolutely necessary, anyway with the file I've sent you things will be OK I'm 99.99% sure, so don't bother anymore, just flash 16MB chip only.
        • zalorpas
          • Aug 2021
          • Spain
          #144
          Ok, good to know ;-)
          I totally believe that it was well soldered to the adapter and in the right place. Perhaps it suffered overheating while desoldering, ESD damage (which seems not to be an important concern in the datasheet) or ... -hopefully, as you point out- it's just the programmer not reading it.
          I'll try and report as soon as possible.
          Thanx.
          PD.- I owe you some beers or a dinner if you ever come to Madrid, Vesko ... for the glory of Paul Horowitz :-)))
          • elbtonet
            • Nov 2019
            • 105
            • albania
            #145
            Hi friends ..need to unlock my 840 g6 bin file
            THANKS
              VIP Moderator
              • Aug 2018
              • 4386
              • Bulgaria 🇧🇬
              #146
              THANKS
              Upload your 16MB bios dump.
              • elbtonet
                • Nov 2019
                • 105
                • albania
                #147
                I searched for another bios chip ,but it has only this one 32mb
                  VIP Moderator
                  • Aug 2018
                  • 4386
                  • Bulgaria 🇧🇬
                  #148
                  Look more carefully
                  U366...
                  • elbtonet
                    • Nov 2019
                    • 105
                    • albania
                    #149
                    You were right my friend
                    thisis the right one i think thnks
                      VIP Moderator
                      • Aug 2018
                      • 4386
                      • Bulgaria 🇧🇬
                      #150
                      I know.
                      Try & leave feedback (flash only 16MB chip):
                      • ace.code
                        • Apr 2016
                        • 133
                        • Estonia
                        #151
                        someone pls unlock my bios
                        thnnnnx
                        • elbtonet
                          • Nov 2019
                          • 105
                          • albania
                          #152
                          Originally posted by Vesko356
                          I know.
                          Hi VESKO ..writed down the bin on my 16mb chip but it doesnt turn on the lapt at all... any idea
                            VIP Moderator
                            • Aug 2018
                            • 4386
                            • Bulgaria 🇧🇬
                            #153
                            thnnnnx
                            Try & leave feedbaack (flash 16MB chip only):
                              VIP Moderator
                              • Aug 2018
                              • 4386
                              • Bulgaria 🇧🇬
                              #154
                              Hmm should work, check (verify) the content of the chip, make sure both chips are soldered correctly to the booard. Check their locations have not been swapped by mistake (16MB must be on U366, 32MB must be placed on U365). Also make sure they are not soldered upside down - pin4 must be ground, pin8 must be +3.3V. Check that you have'nt (re)moved or damaged any smd component in the surrounding area!
                              If all is OK after these checks, but the laptop still does not turn ON, program both chips (or only 16MB one, if the 32MB is checked/verified and the content is the same as iinitial) again:
                              • elbtonet
                                • Nov 2019
                                • 105
                                • albania
                                #155
                                This dump u gave to me right now..worked like charm Thanks man made my day
                                please give my ************** i can donate something to uu
                                THANKS
                                  • 20898
                                  THANKS
                                  everything is for free here
                                  • elbtonet
                                    • Nov 2019
                                    • 105
                                    • albania
                                    #157
                                    thanks man.. didnt know how to be thankful
                                      VIP Moderator
                                      • Aug 2018
                                      • 4386
                                      • Bulgaria 🇧🇬
                                      #158
                                      THANKS
                                      You're very welcome. I'm really glad everything is OK. Congratulations! Have fun.
                                      • brontobyte
                                        • Jul 2021
                                        • 85
                                        #159
                                        Hello Friends, i need your help again to unlock this bios. I atached the original files 32mb and 16mb dump frum hp 840 g6. THANKS A LOT!
                                        • shabi
                                          Banned
                                          • May 2019
                                          • 147
                                          • pakistan
                                          #160
                                          just reprogram 16mb bios and enjoy
