hp 840 g6 6050A3022501-MB-A01
Last edited by Vesko356; 08-29-2021, 05:00 PM.----------------------------------------------------------------------------------------------------------------------------------------------------------
Become a Badcaps supporter
Thanks to all supporters.​
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae.. -
Re: HP 840 G6 BIOS locked
Thank you very much Vesko356 for your fast response and for the useful comments.
So I flashed de 16 Mb BIOS with the file you sent me which actually coincided with the guess I had after looking this thread (everything ok) and also, following your wise advice, I had the 32 Mb BIOS chip unsolderded in order to read it and back up it.
Unfortunately, the USB programmer didn't properly recognize the chip nor was able to read it saying "The chip is empty" (see images attached). I tryed several times changing the adapting PCB position but results were exactly the same. I had the chip resoldered again ... but same results
So my guess is that for some reason either the 25Q256 chip has died or perhaps the programmer is failing (which seems somehow unlikely cause it presumably read, erase, write and verify the 25Q128 chip). So I will try to have both chips soldered back to the motherboard, reassamble the laptop and try. I have a bad feeling thou ... lol =/
I'll report the results here but I have to travel tomorrow and I don't know when I will get to finish it.
In case the chip is K.O. which is your advice?
Thanks a lot.Last edited by SMDFlea; 04-07-2023, 01:46 PM.Comment
Re: hp 840 g6 6050A3022501-MB-A01
It's hard to damage the chip so easy (can only be damaged if soldered to the adapter in reverse polarity, in which case it can be damaged instantly, or can be overheated during desoldering), most likely it just can't be read by the programmer properly or it's not soldered as it should be to the adapter. Just put it back in place. it was a good idea to have a dump available from it just in case, but once you have difficulty with it it's not absolutely necessary, anyway with the file I've sent you things will be OK I'm 99.99% sure, so don't bother anymore, just flash 16MB chip only.Last edited by Vesko356; 08-30-2021, 03:09 PM.----------------------------------------------------------------------------------------------------------------------------------------------------------
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..Comment
Ok, good to know ;-)
I totally believe that it was well soldered to the adapter and in the right place. Perhaps it suffered overheating while desoldering, ESD damage (which seems not to be an important concern in the datasheet) or ... -hopefully, as you point out- it's just the programmer not reading it.
I'll try and report as soon as possible.
Thanx.
PD.- I owe you some beers or a dinner if you ever come to Madrid, Vesko ... for the glory of Paul Horowitz :-)))Comment
Last edited by Vesko356; 08-31-2021, 03:59 AM.----------------------------------------------------------------------------------------------------------------------------------------------------------
Last edited by SMDFlea; 04-07-2023, 01:46 PM.----------------------------------------------------------------------------------------------------------------------------------------------------------
If all is OK after these checks, but the laptop still does not turn ON, program both chips (or only 16MB one, if the 32MB is checked/verified and the content is the same as iinitial) again:Last edited by SMDFlea; 04-07-2023, 01:46 PM.----------------------------------------------------------------------------------------------------------------------------------------------------------
by snpetitHi,
i need some help :-/
i deleted in Bios the Admisnistrator password with old password, but after it didn't allow me to modify the User password. Now i can't boot, enter the bios or do anything. It asking at boot for password, old password don't work...
Could you please remove all password related stuff from this bios. A hate Asus....
Thanks in advance!...-
Channel: BIOS Requests ONLY!
by longmt1990Hi, i have a Panasonic Cf-W5 with the bios password, I tried remove cmos but problem didnot solve.
I uploaded the picture after remove cmos battery, It look like this is a Phoenix bios. The bios dump file in the link i attached
Please help me remove bios password.
Thank you so much-
by tlindiSublect line continuation: ... Jaguar IDS PC aka Panasonic
Ack
Ack
by justice171Hi BadCaps team,
I’m asking for a bit of community help with a Proline notebook that’s stuck with a Power-ON (BIOS) password. The laptop has very limited info available and I suspect it may be a local (South African) Proline board. Thought I’d check here in case anyone has seen this one before.
What I have:- Model: Proline NoteBook V146GNK
- Board: SU_GN100_MB_V12_20231120A
- Serial: GN10Q12124205W1588
- Notes: 12V main board. Very little documentation available.
What I’d like to request:- Has anyone dealt with this Proline board before or seen matching BIOS/firmware
Today, 09:41 PM -
by fx1982Hi everyone, can someone please help to remove bios Administrator password or decode as I failed miserably... Tried reading the password but it says wrong password. Thank you in advance!
It's a 2024 Asus Zephyrus G16
GU605MV
SN: S2NRCX035924088
CN: AEDW
MFD: 2024-02 36M
BIOS VERSION: 315...-
- Loading...
