hp 840 g6 6050A3022501-MB-A01
  • airblade
    • Jan 2019
    • 58
    • Home
    #321
    Re: hp 840 g6 6050A3022501-MB-A01
    Originally posted by binoyroy
    Check this...
    status, no power
    • nivirus2000
      • Apr 2017
      • 45
      can someone help me clean this up, i get no power only get a flashing status light on port.
      HP 6050A3022501-MB-A01
      As always thanks in advance
      • jatoi
        • Jan 2015
        • 84
        • pakistan
        #323
        please unlocked this bios
          VIP Moderator
          • Aug 2018
          • 4386
          • Bulgaria 🇧🇬
          #324
          Read the rules before posting:
          BIOS guides, methods, resources and tools
          Password removal by laptop brand
          Become a Badcaps supporter
          Thanks to all supporters.
          • nivirus2000
            • Apr 2017
            • 45
            can someone help me with my previous post please?
            seems i have a corrupt bios, i loaded it into MEAnalyzer with error "does not contain intel/graphics engine".
            i have tried to read the bios and verified it with same result.
            HP EliteBook 840 G6
            S/N 5CG9361JC3
            thanks.
            • fofonedelalune
              • Mar 2018
              • 9
              • Togo
              #326
              Re: HP 840 G6 Bios Password
              I have try this programme but I get other error : There is a problem with the HP Endpoint Security Controller on the unit. Please I need help
              • ogre4273
                • Mar 2022
                • 57
                • N/A
                #327
                hello I attached 4 dump files with 4 different reading speed (mhz) using EZP2019+ from my bios chip and they are not identical even if I read or dump with the same speed.
                May I know if they are corrupted and which .bin file I should flash. Is it possible that the bios chip itself is damaged because every time I read consecutively, it is always not identical with each other?
                Thank you for answering and checking!!
                • ogre4273
                  • Mar 2022
                  • 57
                  • N/A
                  #328
                  try flashing this..this bios is cleaned
                  • yuri3185pcnet
                    • Jul 2019
                    • 12
                    • Philippines
                    #329
                    Good day everyone..Can someone remove password and computerace on my hp elitebook 840 g6.. thanks your help will much appreciated..
                    • Stunt
                      • Oct 2019
                      • 203
                      • South Africa
                      #330
                      Hi Can you guys help me with Password remove from HP 840 G6?
                      i have tried other dumps in this post but the password it's still there
                      Thank you,
                        • 22159
                        Thank you,
                        Read post #324 ,you can try to unlock it yourself.
                          VIP Moderator
                          • Aug 2018
                          • 4386
                          • Bulgaria 🇧🇬
                          #332
                          Thank you,
                          Password removal by laptop brand:
                          https://www.badcaps.net/forum/showpo...42&postcount=4
                          3.6. HP
                          • Stunt
                            • Oct 2019
                            • 203
                            • South Africa
                            #333
                            3.6. HP
                            Hi guys i've managed to remove password on my bios.
                            But now i'm stuck with computrace i will appreciate if anybody is willing to help me remove it. Thanks in advance
                              VIP Moderator
                              • Aug 2018
                              • 4386
                              • Bulgaria 🇧🇬
                              #334
                              Upload a screenshot from the bios, also from the popup Computrace freeze screen.
                              • Stunt
                                • Oct 2019
                                • 203
                                • South Africa
                                #335
                                there is screenshot
                                  VIP Moderator
                                  • Aug 2018
                                  • 4386
                                  • Bulgaria 🇧🇬
                                  #336
                                  there is screenshot
                                  Did you restore security settings to factory default? If not, do it to see if anything changes.
                                  • Stunt
                                    • Oct 2019
                                    • 203
                                    • South Africa
                                    #337
                                    I did restore security settings to factory default but still the same
                                    • aldopc
                                      • Jul 2017
                                      • 477
                                      • Chilito
                                      #338
                                      Ready Bro falsh, and give me the result.
                                      • Stunt
                                        • Oct 2019
                                        • 203
                                        • South Africa
                                        #339
                                        Thanks now everything it's fine. I really appreciate your time
                                        • rex98
                                          • Feb 2023
                                          • 1296
                                          • Mandaue CEBU, Philippines
                                          #340
                                          Rebuild my dump please. no display
