hp 840 g6 6050A3022501-MB-A01
  • Blaze Tech
    Learner
    • 214
    • Ghana
    #421
    Originally posted by vilmar27@hotmail.com
    Please, could help me to remove the BIOS Password + Unlock the MPM for the below unit?
    System Board CT Number: PHWGH00WBDGT01
    SKU Number: 8QH17LP#AC4
    Serial Number: BRJ00000GT
    Feature Byte: 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAcydUdpdqfPfXhKhkjhk8.Ya
    Build ID: 19WWCFBT601#SAC4#DAC4
    Best Regards,
    Vilmar
    Write only 16mb
    • chinh
      • Mar 2020
      • 90
      • viet nam
      #422
      Originally posted by qayyum786
      try
      Thank you, the file worked fine
      • vilmar27@hotmail.com
        • May 2023
        • 30
        • Brasil
        #423
        Thanks a million Blaze Tech!
          • May 2023
          • 30
          • Brasil
          #424
          Hi Blaze Tech​,
          Please, only one more help. After I write the 16MB unlock bin file, I need to restore the factory defaults and/or restore security bios defaults after first boot or not?
          Tks,
          Vilmar
          • salawayon
            • Nov 2012
            • 578
            • philippines
            #425
            HP EliteBook 840 G6
            SN: 5CG01464XX
            with bios Password and DeviceFreeze problem. thanks
            • Blaze Tech
              Learner
              • 214
              • Ghana
              #426
              try
              • salawayon
                • Nov 2012
                • 578
                • philippines
                #427
                it's working and no END POINT Security problem. thank you for the fast response...
                  • 21562
                  Didn`t you try RCUnlocker ? https://www.badcaps.net/forum/troubl...=4#post1622423
                  • trunguntilyou
                    • Aug 2022
                    • 352
                    • Vietnam
                    #429
                    I tried to find out but couldn't find a solution to the "hp endpoint security controller problem" error. without the original bios,,, I wonder if someone has been able to fix this error without the original bios?
                    • rex98
                      • Feb 2023
                      • 1287
                      • Mandaue CEBU, Philippines
                      #430
                      Flash that both. be patient in first boot.
                      • salawayon
                        • Nov 2012
                        • 578
                        • philippines
                        #431
                        Sorry, I didn't tried. Never thought that RCUnlocker supported this model. What I was trying to avoid was the ENDPOINT SECURITY issue. But, after an hour "DEVICEFREEZE-1341" comes back.
                        • rex98
                          • Feb 2023
                          • 1287
                          #432
                          do not touch the EC only flash this main. RC unlocker can only be used in 16mb chips EC. it cannot removed Absolute lock/ Device Freeze.
                          first boot press f10 apply factory defaults and restart, 2nd boot reset security settings to defaults and exit.
                          use BCU. you can permanently disable Absolute lock in BCU.
                          here's your DMI:
                          Serial Number: 5CG01464XX
                          Product #/SKU: 7UA41UC#UUF
                          CT Number: PHWGH00WBDKLW4
                          Description: HP EliteBook 840 G6
                          BuildID: 19WWCFBT601#SUUF#DUUF
                          Feature Byte: 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfPhKhkjhk8.gn
                          • trunguntilyou
                            • Aug 2022
                            • 352
                            • Vietnam
                            #433
                            still shows "hp endpoint security controller problem",,, this bios also reboots repeatedly for me
                            • rex98
                              • Feb 2023
                              • 1287
                              #434
                              do you still have the original bios and ec?
                              • trunguntilyou
                                • Aug 2022
                                • 352
                                • Vietnam
                                #435
                                This is the bios when I first read it (I saw it had been changed and didn't work)
                                sn :5CG04240VN
                                • rex98
                                  • Feb 2023
                                  • 1287
                                  #436
                                  sn :5CG04240VN
                                  flash the original EC and this main.
                                  here's your DMI:
                                  Serial Number: 5CG04240VN
                                  Product #/SKU: 7UA64UC#UUF
                                  CT Number: PHWGL00WBEC07B
                                  BuildID: 19WWCFCT601#SUUF#DUUF
                                  Feature Byte: 3X476J6S6b7B7H7M7R7W7m7saBaEapaqauawbUbhdUdpdqfPgShKj4jhk8.dt
                                  • trunguntilyou
                                    • Aug 2022
                                    • 352
                                    • Vietnam
                                    #437
                                    here's your DMI:
                                    The file doesn't turn on, the power light flashes continuously,
                                    • salawayon
                                      • Nov 2012
                                      • 578
                                      • philippines
                                      #438
                                      here's your DMI:
                                      thank you for the file and effort... with regards to DMI i just input the data at BIOS SETUP-->MAIN-->SET MACHINE UNIQUE DATA, after entering all the required data this menu will become hidden. and for MPM i just kept on restarting the machine till it reach to "0".
                                      • user212dan
                                        • Jul 2017
                                        • 23
                                        #439
                                        Hi, can you help, no power on ?
                                        HP 840 g6
                                        SN:5CG0091FTR
                                        I've tryed few EC + main from older posts, it's power on ,but with Endpoint problem. Can you fix my files ?
                                        • hoaca388
                                          Badcaps
                                          • Jan 2022
                                          • 12232
                                          #440
                                          HP 840 g6
                                          SN:5CG0091FTR
                                          CCC
