Dell E6530 bios bin files please.
  • inkman
    • Sep 2019
    • 59
    Motherboard- Qala1 La-7762p. Rev 1.0(A00)
    Service tag- 1G36NX1
    Efeon Q64
    Efeon Q32.
    Please somebody help me with bin files for this motherboard.
    Its motherboard with Nvidia graphics.
    I have attached old bin files, Please advice me if they are faulty or corrupted.
  • peste
    • Dec 2016
    • 13924
    • ROMANIA
    Re: Dell E6530 bios bin files please.
    try...
    • inkman
      • Sep 2019
      • 59
      Thanks peste.
      I will flash it tonight and post the result.
      • inkman
        • Sep 2019
        • 59
        Originally posted by peste
        try...
        thank you for bin files.
        I have flashed bios and my laptop is working now.
        I do have one problem, the fan only runs when temp is around 70c.
        Do you think this is linked to bios or is it diferent problem, any solution
        to this problem will be welcomed.
        • inkman
          • Sep 2019
          • 59
          The problem with fan solved.
          I have installed nvidia driver and fan is working normally.
          • username77
            • Dec 2020
            • hungary
            try...
            I have a same issue, but this help, thx guys.
            • kwwsoft
              • Feb 2020
              • 4
              • Ukraine
              try...
              Motherboard- Qala1 La-7762p. Rev 1.0(A00) 2012-11-02
              works perfectly. thank you.
              • zenius
                by zenius
                12-08-2024, 06:13 AM
              • mikeybass
                by mikeybass
                04-23-2025, 04:30 PM
              • capoplays
                Help with BIOS update on Dell G15 5515 after chip replacement
                by capoplays
                Hey everyone,
                I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                When I check the BIOS using the F12 menu Flash...
                10-24-2025, 06:53 AM
              • Akhlz001
                by Akhlz001
                09-20-2025, 07:15 PM
              • Sathsul
                Dell Latitude 5431 issues with dumping bios
                by Sathsul
                So, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
                The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
                However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...
                10-28-2025, 07:49 AM
